04-01-2012, 12:39 | #1 (permalink) |
Insane Poster Join Date: Mar 2010
Member: 1268192 Status: Offline Thanks Meter: 8 | E63 flashing ok but phone dead (ANSWERED) Version from file: 500.21.009 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: xxxxxxx Using device: HTI, FW ver: 00.50, SN: 0xxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_3515020457xxxx_BA CK.rpl). CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 11B0010A5E178E52860E41259AEC38EBFFB60E4C ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.50.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.50.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Processing MCU file: rm437_500.21.009_prd.c00 [BB5,XSR 1.5] size: 15.31 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 122.56 MB CMT FLASH,MuxOneNAND area [00040000-007FFFFF] CMT FLASH,MuxOneNAND area [00A00000-0759FFFF] CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D9C25399 [RAP Certificate 137 v.1] sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS*CORE block sent Prog.status for Asic CMT ... NAND: Status reported bad blocks. Programming completed in 38.782 s Processing PPM file: rm437_500.21.009_prd.v27 [BB5,XSR 1.5] size: 13.97 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 33.56 MB CMT FLASH,MuxOneNAND area [05420000-0759FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFX block sent Prog.status for Asic CMT ... NAND: Status reported bad blocks. Programming completed in 40.078 s Processing CNT file: RM437_ENO_008.07.45_100.71.920.a01.fpsx [BB5,XSR 1.5] size: 1.51 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 64 KB Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS*ENO block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4.546 s Processing CNT file: sofie_erase_y_drive.fpsx [BB5,XSR 1.5] size: 236 Bytes Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Erase size: 1.62 MB CMT FLASH,MuxOneNAND area [0F020000-0F1BFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 0.094 s Processing CNT file: rm437_500.21.009.51U [BB5,XSR 1.5] size: 14.75 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 64 KB Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Programming completed in 44.047 s Total time for flashing process(boot+erase+write) was 2 min 20.218 s Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.5 24-05-10 RM-437 (c) Nokia ApeCoreSw: 500.21.009 Imei plain: 35150204577408-0 Product code: 0590140 Battery voltage: 4916 mV, current: 56 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351502045774080 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.875 s THis is the log of E63. FLashing is ok. but phone is dead. phone become very slow. so i flashed but now phon e is dead. pse help me |
04-01-2012, 14:00 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. Status reported bad blocks. so give some heat to flash ic & phone will be on. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
