Old 06-03-2010, 09:04   #1 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
Lightbulb E63 security failed (any solution for this?
help me master............
Old 06-03-2010, 09:06   #2 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
Phone Type: RM-437 (Nokia E63)
SW Version: V ICPR71_08w44.1 30-10-08 RM-437 (c) Nokia
Imei plain: 35931902690559-7
Product Code: 0568890
ApeCoreSw: 100.21.110
ApeVariant: 100.21.110, ApeTest: RM437ENO8745718441.011
Language Pack:
- not available.
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 359319026905597
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 06-03-2010, 09:07   #3 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
only security test fail.......
you need Super SD Auth and write pm 1 & 309
The Following User Says Thank You to jaleelkuttikkar For This Useful Post:
Old 06-03-2010, 09:26   #4 (permalink)
UNLOCK PARK ® SUPPORT's Avatar
Member: 562024
Sonork: +971506319003
Thanks Meter: 135
Yes do this
Mahadi
Old 06-03-2010, 09:27   #5 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
ok i will try now master
i will report to u again the result
br
leong
Old 06-03-2010, 09:28   #6 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V ICPR71_08w44.1 30-10-08 RM-437 (c) Nokia
Using cached productData[0F600001FE7C00526741549C54BE122487258598] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 06-03-2010, 09:28   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
do pmm auth if this phone is never got any SD repaired before, and write 1+309 pm.
else, do super sd auth as described above by our friends.
Old 06-03-2010, 09:29   #8 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
above is the result master
Old 06-03-2010, 09:33   #9 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
ll try pmm auth now
i will try do pmm auth now
i will send the result later
Old 06-03-2010, 09:33   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
what is the caused of this problem before?
Old 06-03-2010, 09:33   #11 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...Connection timed out
Old 06-03-2010, 09:35   #12 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
the problem can not sms
then i format system
then ui setting
the phone be like above
security failed
br
Old 06-03-2010, 09:38   #13 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 06-03-2010, 09:39   #14 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
Socket error (10054): Connection reset by peer
Old 06-03-2010, 11:23   #15 (permalink)
leong_ic's Avatar
Member: 1277441
Sonork: 100.1601680
Thanks Meter: 8
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0F600001FE7C00526741549C54BE122487258598
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-25-1999 15:50
Page generated in 0.24657 seconds with 9 queries
