02-18-2010, 19:33 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | depend on your phone frimware version Code: -2680 (RH-392) -> V04.56,V04.91,V05.28,V56.17,V06.17 -2680s-2b (RH-393) -> V04.56,V56.17 br, |
02-18-2010, 19:45 | #5 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | o no,no need to reflash - with mx v3.3 rev1.6 unlock is impossible, only with mx v3.2 rev5.4 is possible ( tested with HWK and Jaf boxes). After mx 3.2 rev5.4 all other updates is bad to unlock for dct4+ ( also tested with hwk and jaf) Last edited by raychevski; 02-18-2010 at 19:53. |
The Following 2 Users Say Thank You to raychevski For This Useful Post: |
02-18-2010, 20:56 | #6 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Valencia, Spain
Member: 867007 Status: Offline Thanks Meter: 42 | i just unlocked a 2680s (rm-392 v.4.91) today with mxkey 3.3 rev1.6p without problems, first time failed to unlock but second time after selected ASIC 11 in unlock tab the phone was unlocked. (using UFS as interface). |
02-18-2010, 21:09 | #7 (permalink) | |
Member: 4813 Status: Offline Thanks Meter: 401 | Quote:
test and post result Last edited by raychevski; 02-18-2010 at 21:18. | |
02-26-2010, 12:13 | #15 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | mobileEx 3.2 rev5.4 Using device: UFS_USB V2.8 (c) SarasSoft 2007. RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35687402995812_BA CK.rpl" Processing file: rm392__06.17.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 11.81 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0002348A:3B8ADA60 Area [01000000-0101FFFF] erased in 1.172 s Area [01020000-01CFFFFF] erased in 2 min 0.281 s Flash programming ... Programming completed in 1 min 11.609 s File Processed in 3 min 22.515 s Processing file: rm392__06.17_ISM_002.image_ek_globul_bg_grey as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 3.88 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0002348A:C5A4DA78 Area [02180000-02E7FFFF] erased in 4 min 0.078 s Area [02E80000-02FBFFFF] erased in 23.282 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 25.359 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.016 s File Processed in 5 min 10.531 s Processing file: rm392__06.17.ppm_ek as PPM [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH - COMBO FLASH - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0002348A:2984DA60 Area [01D00000-0217FFFF] erased in 56.359 s Flash programming ... Programming completed in 13.703 s File Processed in 1 min 17.094 s Flashing completed in 10 min 8.078 s After Flash Processing ... Updating Product Code OK. Reseting Factory Values OK. PhoneType:RM-392 SwVersion: V 06.17 10-03-09 RM-392 (c) Nokia MCU file: rm392__06.17.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 3 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0002348A:3B8ADA60 Area [01000000-0101FFFF] erased in 1.187 s Area [01080000-0109FFFF] erased in 1.188 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0002348A:3B8ADA60 Area [01000000-0101FFFF] erased in 1.172 s Area [01080000-0109FFFF] erased in 1.187 s Programming ... Programming completed. Completed in 44.672 s Phone Type: RM-392 (Nokia 2680s) SW Version: V 06.17 10-03-09 RM-392 (c) Nokia Imei plain: 35687402995812-9 Imei OTP: 35687402995812 Product Code: 0579757 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: EK Language Pack: English,Bulgarian,German Imei net: 35687402995812 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 11 min 6.796 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 5.985 s mobileEx 3.3 rev1.6 is bad for unlock |
unlock 2680s 5.28 not unlock | gadzetxp | Cyclonebox | 3 | 04-01-2009 22:58 |
Unlock 2680s problem | artech2 | J.A.F. Plus | 1 | 01-18-2009 01:23 |
how to unlock 2680s-2? | neoBIT666 | HWK | 2 | 11-14-2008 15:03 |
