02-10-2010, 02:43 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | E65 sd error Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 4.0615.2 05-06-08 RM-208 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F ERROR: Missing SD BLOCK or PM corrupted ! need to repair sd data how it could be done thanks in advance |
02-10-2010, 03:29 | #2 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | Phone Type: RM-208 (Nokia E65) SW Version: V 4.0615.2 05-06-08 RM-208 (c) Nokia. Imei plain: 35326201113581-0 Product Code: 0515722 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353262011135810 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-10-2010, 03:40 | #3 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | you can make all back up section then after that repair SD then repair supper dungle key your problem solve |
02-10-2010, 03:42 | #4 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F ERROR: Missing SD BLOCK or PM corrupted ! this is the error with repair sd |
02-10-2010, 04:51 | #8 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | the phone is not gettin' network now what could be done up here.... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 4.0615.2 05-06-08 RM-208 (c) Nokia. ApeCoreSw: 4.0633.74.00 04-09-08 RM-208 (c)Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 44, size 182 bytes written. Section: 2 - Key: 0, size 440 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 64 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 26, size 132 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 2 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 1 bytes written. - Key: 16, size 1 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 1 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 1 bytes written. - Key: 47, size 16 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 20 bytes written. - Key: 51, size 10 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 20 bytes written. - Key: 54, size 10 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 1 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 1 bytes written. - Key: 61, size 1 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 1 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 32 bytes written. - Key: 67, size 32 bytes written. - Key: 68, size 2 bytes written. - Key: 69, size 2 bytes written. - Key: 70, size 2 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 2 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 2 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 2 bytes written. - Key: 79, size 2 bytes written. - Key: 80, size 2 bytes written. - Key: 81, size 2 bytes written. - Key: 82, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 2 bytes written. - Key: 85, size 2 bytes written. - Key: 86, size 2 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 2 bytes written. - Key: 89, size 2 bytes written. - Key: 90, size 2 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 2 bytes written. - Key: 93, size 2 bytes written. - Key: 94, size 2 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 2 bytes written. - Key: 97, size 2 bytes written. - Key: 98, size 2 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 2 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 2 bytes written. - Key: 103, size 2 bytes written. - Key: 104, size 2 bytes written. - Key: 105, size 2 bytes written. - Key: 106, size 2 bytes written. - Key: 107, size 2 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 2 bytes written. - Key: 110, size 2 bytes written. - Key: 111, size 2 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 2 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 4 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 4 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 4 bytes written. - Key: 121, size 16 bytes written. - Key: 122, size 4 bytes written. - Key: 123, size 2 bytes written. - Key: 124, size 2 bytes written. - Key: 125, size 1436 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 17 - Key: 0, size 4 bytes written. Section: 26 - Key: 0, size 16 bytes written. - Key: 1, size 68 bytes written. Section: 31 - Key: 4, size 12 bytes written. Section: 44 - Key: 0, size 1 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. - Key: 2, size 24 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 92 - Key: 0, size 20 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 117 - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 42 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Section: 313 - Key: 0, size 615 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 334 - Key: 0, size 1 bytes written. Completed in 5.907 s |
02-11-2010, 11:55 | #9 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 4.0615.2 05-06-08 RM-208 (c) Nokia. ApeCoreSw: 4.0633.74.00 04-09-08 RM-208 (c)Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F ERROR: Missing SD BLOCK or PM corrupted ! |
3110c showing SD error while sd is ok | xim360 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-18-2010 13:29 |
3110 repair sd error | askaralikp | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-15-2010 08:36 |
5130c after repair sd erRor and sl crrupted | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-03-2010 13:55 |
6300 after repair sd error | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-03-2010 13:33 |
n73 calculate sd error | 65211355 | Universalbox | 8 | 12-12-2009 19:29 |
