Old 02-06-2010, 18:09   #1 (permalink)
Member: 1175310
Thanks Meter: 3
E65 start up failed after sd repair and SUPER SD Auth PM 1 and 309[SOLVED]
Hi, this is my e65 blue screen that after full erase, dongrade with last version acord product code, write RPL and PM Auth full PM, he goes alive but SD failed, now i write full PM, repair simlock RPL, Repair SD, and SUPER SD Auth write PM 1 and 309, now is all ok but when i try with a Sim card start up failed contact retailer.
MxKey log
Phone Type: RM-208 (Nokia E65)
SW Version: V 2.0615.30 13-09-07 RM-208 (c) Nokia.
Imei plain: 356961018******
Product Code: 0557906
ApeCoreSw: 2.0633.65.01 03-10-07 RM-208 (c)Nokia
ApeVariant: 2.0633.65.01_v292.20 03-10-07 RM-208 (c)Nokia
ContentPack: 2.0633.65.01.20 24-10-2007 292U
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2007-12-11T09:04:08+02:00
SW Version: 2.0633.65.01
Variant Version: 001
ProductProfile:
Simlock: E65_0557906_pdm.bin
Imei net: 356961018******
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Self test log
Phone Type: RM-208
SW version: V 2.0615.30 13-09-07 RM-208 (c) Nokia.
ID Test name Startup Result
88 TAHVOINT Y passed
46 UEM_CBUS_IF Y passed
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
90 PWR_KEY N passed
2 CURRENT_CONS N passed
20 BACKUP_BATT N passed
39 WARRANTY N passed
58 CMT_APE_WAKEUP N passed
56 SLEEPCLK_FREQ N passed
96 HOOKINT N passed
101 BTEMP N passed
108 EXT_DEVICE N passed
86 CDSP_RF_BB_IF N passed
83 CDSP_RF_SUPPLY N passed
85 CDSP_TX_IQ N passed
74 CDSP_TXC_DATA N passed
82 CDSP_PWR_DETECTOR_BIAS N passed
79 CDSP_RX_PLL_PHASE_LOCK N passed
80 CDSP_TX_PLL_PHASE_LOCK N !not ready
75 CDSP_WCDMA_TX_POWER N !not ready
81 CDSP_RX_IQ_LOOP_BACK N !not ready
77 CDSP_GSM_TX_POWER N !not ready
6 IR_LOOP N !not ready
7 KEYBOARD_STUCK N !not ready
21 LPRF_IF N !not ready
22 CAMERA_IF N !not ready
44 LPRF_AUDIO_LINES N !not ready
59 MAIN_LCD_IF N !not ready
71 BT_WAKEUP N !not ready
72 WLAN N !not ready
92 BT_WLAN_COEXISTENCE N !not ready
All is ok but the phone only start up offline, when i try with SIM start up failed again.
Could someone advise me what I must do now?
Thanks in advance
The Following User Says Thank You to miklaus35 For This Useful Post:
Old 02-06-2010, 18:17   #2 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
bro did you try with hand formate ???/
The Following User Says Thank You to waqas_ali601200 For This Useful Post:
Old 02-06-2010, 18:24   #3 (permalink)
Member: 1175310
Thanks Meter: 3
No, i haven't tried it, how can i do it? is "*+5+pwr" for e65?
thanks in advance
Old 02-06-2010, 18:27   #4 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
star key + send key + 3 key + power on
Old 02-06-2010, 18:29   #5 (permalink)
Member: 1175310
Thanks Meter: 3
Thank you, now I try it i comment result
Old 02-06-2010, 18:39   #6 (permalink)
ismabdi's Avatar
Member: 461554
Thanks Meter: 55
E61 format by hand please i need it
regards
Old 02-06-2010, 18:47   #7 (permalink)
Member: 1175310
Thanks Meter: 3
Nothing happens, may be that I am doing it badly, but I have tried it several times.
Thanks anyway
Old 02-06-2010, 18:48   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
try this
goto service - quick fix - BB5 RAP3NAND Erase User Area.
maybe need ENO frimware to repair
What is ENO software:
ENO software handles all basic functions inside the device.
It is required to be flashed into the device when Combo Memory is Changed
due to by some wrong operations like; Downgrade Phone wrongly,
Flash with wrong Firmware, Erase Phone with wrong file or
Phone is on White or Blank display.
After flash with ENO Firmware your phone will be normalized and
then you simply flash again with correct firmware package,
select any product code according to your choice and press Flash button.
hopefully help
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 02-06-2010, 18:50   #9 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
star key + send key + 3 key + power on for e61 alsoo
Old 02-06-2010, 18:56   #10 (permalink)
Member: 1175310
Thanks Meter: 3
Originally Posted by MobileEx-Team View Post
try this
hopefully help
br,
I have tried but ...
Language Pack:
- not available.
SIMLOCK_TEST passed
ProductProfile:
Counter: 0/3, 0/10
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 6CC077C5A5FDCB1A840451F74E65B6F24818****
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1680000C8A964F50E4D971E581D8ABC1D43*****
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0266638E9C2164FC6B5194ED596A6A251C699896
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 0098 01A1 - 0090 0095 [Toshiba ] type: NAND,APE
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 0266638E9C2164FC6B5194ED596A6A251C699896
Not Supported, reason: this is not RAP3NAND phone !
No ENO firmware for E65, thanks anyway
Old 02-06-2010, 18:58   #11 (permalink)
Member: 384775
Sonork: 100.1605469
Thanks Meter: 159
i think you must recover certificate.
The Following User Says Thank You to cemalefendi For This Useful Post:
Old 02-06-2010, 19:02   #12 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
milus bro meet me on yahoo //.. i will help u using mx-key with team viwer
waqaas_ali6012003
Old 02-06-2010, 19:03   #13 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
if software ways already taken
sound like HW problem
but try with diferent frimware version
br,
Old 02-06-2010, 19:10   #14 (permalink)
Member: 1175310
Thanks Meter: 3
Phone test/ Various/ BB5 Certificate Validation
APE Data :
ASIC MODE ID: 00
PUBLIC ID: 6CC077C5A5FDCB1A840451F74E65B6F24818419C
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1680000C8A964F50E4D971E581D8ABC1D436B003
ASIC MODE ID: 00
Reading RAP NPC (0x190 bytes)
Original Product Code: 0557906
Reading RAP VARIANT (0x0 bytes)
VARIANT empty !
Reading RAP CCC (0x160 bytes)
CCC seems to be valid
Reading RAP HWC (0xD4 bytes)
HWC seems to be valid
Imei&Security/ Imei rebuild/ Recover Cert
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Begin Certificate Request ...
Connecting to server ...OK, Login ...
Query done with status: OK
Updating PRODUCTCODE (0557906)... OK
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Certificate programmed successfully !
But all same.
Can i do format System with Mxkey?
Thanks in advance
Old 02-06-2010, 20:40   #15 (permalink)
Member: 1175310
Thanks Meter: 3
br,
This is the good solution, i reflash with the same version with mxkey but failed
Flashing terminated with error(s) in 8 min 50.297 s
RX Buffer: 010266638E9C2164FC6B5194ED596A6A251C6998960600
i have tried to reflash with jaf software the same version firmware
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-208\rm208_m128_h20_ka_prod_206336501_c00_combined. bin
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-208\rm208_m128_h20_ka_prod_206336501_v292_20_varia nt.bin
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-208\rm208_2.0633.65.01.20_u292.bin
APE Variant file: NONE
Languages in ppm: English,
Manual mode selected, version can't be checked!
Booting phone...
FAST PHONE detected!
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
Asic Public ID: 6CC077C5A5FDCB1A840451F74E65B6F2481*****
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101003000
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 1680000C8A964F50E4D971E581D8ABC1D43*****
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
CMT Boot File: C:\Archivos de programa\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Archivos de programa\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
APE Boot: C:\Archivos de programa\ODEON\JAF\Flash\helen3_2nd.fg
Loader version: 01.23.00 -> Revision: 0000
Patching APE boot step1...
Patching APE boot step2...
Patching APE boot step3...
APE Boot Ready
APE Flash ID: 01A10098 <=> SAMSUNG -> Type not in database
APE Flash Data: 14141414141414141414141414141414
APE Loader: C:\Archivos de programa\ODEON\JAF\Flash\h3_xsr15_flash_alg.fg
Loader version: 01.2E.00 -> Revision: 0000
Patching APE loader step1...
Patching APE loader step2...
Patching APE loader step3...
APE Loader Ready...
Operation took 0 minutes 7 seconds...
Sending CNF Data...
Sending CRT data...
Erasing...
Operation took 0 minutes 38 seconds...
Writing...
Stage 1
Sending APE HASH for KEYS
Sending CMT HASH for NOLO
Sending APE HASH for X-LOADER
Sending CMT HASH for KEYS
Sending APE HASH for PRIMAPP
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
Sending APE HASH for SOS+LOADER
Sending CMT PUB KEYS...
Sending CMT HASH for ADL
Sending APE HASH for ADL
Sending CMT HASH for DSP0
Sending APE HASH for SOS+XZIP
Sending APE HASH for PASUBTOC
Sending APE PUB KEYS...
Sending APE HASH for SOS*CORE
Sending CMT HASH for MCUSW
Stage 2
Booting phone...
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
Asic Public ID: 6CC077C5A5FDCB1A840451F74E65B6F24818419C
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
APE Flash Data: A2A2A2A2A2A2A2A2A2A2A2A2A2A2A2A2
APE Loader Ready...
Sending CNF Data...
Sending CRT data...
Stage 1
Stage 2
Booting phone...
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
APE Loader Ready...
Sending CNF Data...
Sending CRT data...
Stage 1
Stage 2
FAST MODE finish!
Operation took 4 minutes 9 seconds...
Reseting phone...
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-208\rm208_m128_h20_ka_prod_206336501_v292_20_varia nt.bin
Booting phone...
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
APE Flash Data: 3D3D3D3D3D3D3D3D3D3D3D3D3D3D3D3D
APE Loader Ready...
Operation took 0 minutes 6 seconds...
Sending CNF Data...
Erasing...
Operation took 0 minutes 0 seconds...
Writing...
Booting phone...
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
APE Loader Ready...
Sending CNF Data...
FAST MODE finish!
Operation took 3 minutes 27 seconds...
Reseting phone...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-208\rm208_2.0633.65.01.20_u292.bin
Booting phone...
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
APE Loader Ready...
No erase block detected! Erase will be skiped!
Writing...
Operation took 0 minutes 26 seconds...
Reseting phone...
Done!
Total time: 9 Minutes, 3 Seconds
DCT4/BB5 counter: 15
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-208, Software version: 2.0615.30
IMEI: 356961018******
APE Ver: (null)
Variant Ver: (null)
Done!
Changing mode...
Done!
And my dead blue screen E65 full works again, Thank you very much to all those who have helped and specially Mr. Manole and the whole team of Mx-Key, because without " SD Repair" and " SUPER SD Auth ", my e65 would be dead.
Best Regards
The Following 2 Users Say Thank You to miklaus35 For This Useful Post:
n78 phone start up failed how to repair .:M@ster:. Nokia Base Band 5 ( BB-5 ) 0 05-25-2009 22:16
n73 phone start up failed after after write rpl unlock & flash Nokia Base Band 5 ( BB-5 ) 3 09-16-2008 21:58
Phone start up failed after unlock. alejandroveliki BB5BOX 30 12-14-2007 11:22
n95 Phone Start-up Failed. after downgrade sege Nokia Base Band 5 ( BB-5 ) 5 09-28-2007 08:03
plz help me wt n73 start up failed after rpl abcrino50 MT-BOX 16 06-23-2007 20:08
Page generated in 0.37268 seconds with 10 queries
