Old 05-31-2011, 17:52   #1 (permalink)
Member: 1012165
Thanks Meter: 116
e66 phone code removal sol. when f-bus does'nt check
help all i have a nokia e66 with phone code problem,i have flashed it with usb both jaf & mx-key log below,the phone does not check on f-bus pls help
mx-key
______________
MXKEY Serial: [FT S........] - C080AFB3
Driver: NMWCD, ver: 7.1.32.62, NTMP ver:
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Processing MCU file: rm343_500.21.009_prd.c00
[BB5,XSR 1.5] size: 68.79 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3144593B
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
CMT EM0 ID: 00000295
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 010001050D7D005251D2FE8E5FB7908211A7DB28
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: 4B9B75103E691FF8
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, XSR: 0x1FDF4F bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 19D1024E
Verifying communication to device OK.
Partitioning....
Partitioning complete
Erase size: 122.56 MB
CMT MuxOneNAND area [00040000-007FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 (RAP Certificate 102 v1) sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
Programming completed in 2 min 7.250 s
Processing PPM file: rm343_500.21.009_prd.v05
[BB5,XSR 1.5] size: 30.91 MB
Erase size: 33.56 MB
CMT MuxOneNAND area [05420000-0759FFFF]
CMT SOS+ROFX block sent
Programming completed in 1 min 1.094 s
Processing CNT file: RM343_ENO_0741.10_08wk42.a26.fpsx
[BB5,XSR 1.5] size: 1.54 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103, 4003192101051103, 400C192101051103
Erase size: 64 KB
APE SOSENO
CMT SOS*ENO block sent
Programming completed in 3.828 s
Processing CNT file: dawn_erase_y_drive.fpsx
[BB5,XSR 1.5] size: 236 Bytes
Erase size: 1.62 MB
CMT MuxOneNAND area [0F020000-0F1BFFFF]
Processing CNT file: rm343_500.21.009.02U
[BB5,XSR 1.5] size: 15.79 MB
Erase size: 64 KB
Programming completed in 32.047 s
Total time for flashing process(boot+erase+write) was 4 min 46.968 s
Waiting for device boot up ...
Phone not found, retrying ...
jaf
________
JAF version 1.98.61
Detected PKEY: 90009B62
Card life counter: 99.99%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Fast phone flashing selected.
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-343\rm343_500.21.009_prd.c00
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-343\rm343_500.21.009_prd.v05
Languages in ppm: English,German,Russian,Bulgarian,Romanian,Ukrainia n
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-343\rm343_500.21.009.08U
Phone Type:
Phone Type:
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-343\rm343_500.21.009.02U
Backing up CRT...
Detected P-KEY: 90009B62
Init usb communication...
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 006.044.048
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 0600
Selecting CMT flash...Result: 0000
Phone is in flash mode...
CMT blocks: 975, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-343\rm343_500.21.009_prd.c00...
Erasing cmt zone 00040000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00A00000 - 0759FFFF ... Erase result: 0000
Erasing cmt zone 0F1C0000 - 0F8BFFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-343\rm343_500.21.009_prd.v05...
Erasing cmt zone 05420000 - 0759FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-343\rm343_500.21.009.02U...
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS*CORE
Sending CMT HASH for SOS+ROFS
Sending CMT HASH for SOS+ROFX
Write result 27: 1700
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
Phone not found...
DCT4/BB5 counter: 752
Done!
[IMG]file:///C:/DOCUME%7E1/user/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
Old 06-08-2011, 01:32   #2 (permalink)
Member: 1012165
Thanks Meter: 116
help all i still need a sol. to this problem pls, how can i remove the code from this phone?
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 21:17
Page generated in 0.23229 seconds with 8 queries
