Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member ![]() ![]() Join Date: Oct 2005 Location: GSM world
Member: 191786 Status: Offline Thanks Meter: 1 | E66 security test fail Phone Type: RM-345 (Nokia E66) SW Version: V ICPR71_09w22.10 22-10-09 RM-345 (c) Nokia Imei plain: 35294402014763-6 Product Code: 0564815 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 352944020147636 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to radu_m For This Useful Post: |
![]() | #4 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,773 | SECURITY_TEST failed! with "SUPER SD auth" ![]() and write PM [1] and [309] area if not help ,try read carefully this thread [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair Quote:
can you post the log for this phone ? br, Last edited by Andra; 02-25-2010 at 17:24. | |
![]() | #5 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2004 Location: ISLAND Age: 48
Member: 80036 Status: Offline Thanks Meter: 25 | thank u 4 ur atention here is my log SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0BB000161DB40158F6FB8D9E94949BD5A2A439EE ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 Original Imei: 352942023xxxxx Original Product code: 0566775 Phone Type: RM-343 (Nokia E66) SW Version: V ICPR71_09w04 20-01-09 RM-343 (c) Nokia Imei plain: 352942023xxxxx-2 Product Code: 0557965 ApeCoreSw: 210.21.007 ApeVariant: 210.21.007, ApeTest: RM343ENO74110842.a24 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 352942023xxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
![]() | #6 (permalink) |
Member: 80036 Status: Offline Thanks Meter: 25 | btw now when i try to repair simlock it showing Access violation at adress 02759B62. Read of adress 0660A53C. and the programm stop and freeze what it means? thanks Imei net: 35294202315xxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Backup already exist. Using device: J.A.F, FW ver: 01.B2 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot [rapidov11_2nd.fg](0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x11C4 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending KEYS [SL20] (0x1A20 bytes) ...OK Calculating LOCK data ...OK Unlocked PM saved to "C:\mobileEx\3.3\data\backup\35294202315xxxx_UNLOC KED.PM" Writing Unlocked PM ... OK Completed in 23.343 s Restarting phone ... |
![]() | #7 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,773 | my instruction order you to make SIMLOCK repair ?? please follow this post carefully . E66 security test fail br, |
![]() | #8 (permalink) |
Member: 80036 Status: Offline Thanks Meter: 25 | i do like u said but nothing same problem pm than super sd than write pm1 pm309 fields after this same security test failed i try to downgrade from 400 to 200 version but is same please advice where is my mistake? thanks could it be my pm is not good? did u have a good rm343 pm here only 1 and 309 fields? thanks again |
![]() | #9 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,773 | so you need this if these steps still not fix the phone, please do BB5 Cert Validation Code: Usefull to identify SECURITY_TEST problem specially if SUPERDONGLE is valid Button located to [Phone Test->Various] [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, |
![]() | #10 (permalink) |
Member: 80036 Status: Offline Thanks Meter: 25 | Reading RAP NPC (0x190 bytes) Original Product Code: 0566775 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x160 bytes) Product Code: 0569307 Product Code missmatch ! Reading RAP HWC (0xD4 bytes) Product Code: 0569307 Product Code missmatch ! ok how to fix this? please be patient i'm new with mxkey thanks for ur help here |
![]() | #11 (permalink) | |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,773 | Quote:
just want help with some clue with easy step. "one shot,one kill" ![]() after get this , do Super SD auth and write PM like this post E66 security test fail br, | |
![]() | #12 (permalink) | |
Member: 80036 Status: Offline Thanks Meter: 25 | Quote:
many times but nothing changed download 3 pm files of this phone but nothing something else to test? can be my pm's are not good? what can be? | |
![]() | #13 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,773 | it can be. just try looking normal phone in same type arround of you. then read PM file open as notepad and delete [308] and [120] area. do Super SD Auth and write PM edited. br, |
N73 security test fail start up fail | mobile_mania | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 03-14-2013 20:33 |
succes full repair phone startup failed and security test failed | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-12-2010 14:17 |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
Please HELP security test -Failed | rakishi | Universalbox | 0 | 01-18-2007 23:45 |
