07-22-2011, 15:17 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Ivory coast Age: 47
Member: 28749 Status: Offline Thanks Meter: 48 | E7 dead after usb flashing(ANSWERED) i want to add french language in nokia E7 and now the phone dead!!! can you help me. i replace battery and retry but this is log: MXKEY Serial: [FT SCR2000 0] - C0810011 Driver: NMWCD, ver: 7.1.32.62 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Processing MCU file: RM-626_014.002_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 142.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 82D2E2 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 0E50001456D60344F274EBE05B7DD15CC4EAF611 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,NOR,asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 82D2E2 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x0 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x0 bytes). Reading CMT HWC (0x0 bytes). Invalid Certificate Data, backup will not be created. Error saving backup ! CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 508.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0FC7FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 8EABFDA6 [RAP Certificate v1 248] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 27.437 s Processing PPM file: RM-626_014.002_08.01_French_AZ_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 40.73 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 67.50 MB CMT FLASH,MuxOneNAND area [0A580000-0E8FFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 7.829 s Processing PPM file: RM-626_014.002_00.01_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 4.80 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 19.50 MB CMT FLASH,MuxOneNAND area [0E900000-0FC7FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.153 s Processing CNT file: RM-626_014.002_U01.01_79.92_prd.uda.fpsx [BB5,XSR 1.6] size: 89.45 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 484.50 MB CMT FLASH,MuxOneNAND area [0FC80000-2E0FFFFF] Flash programming ... Error while programming [00] at 0x0FC80000, Result: 0000 thx |
09-15-2011, 13:15 | #6 (permalink) |
Registered User Join Date: Jun 2004 Age: 46
Member: 68983 Status: Offline Thanks Meter: 55 | MXKEY Serial: [FT SCR2000 0] - C0812A35 Driver: nmwcdnsuc, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: RM-626_014.002_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 142.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3739C341 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 10D00001EB5D57402130FBBDEE432E8DD1E50F7D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0020 0068 - 0000 0031 [ST LH28F160BG] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0068 - 0000 0031 [ST LH28F160BG] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3739C341 Verifying communication to device OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 508.06 MB CMT MuxOneNAND area [00040000-0007FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 8EABFDA6B8A757034233978C16A93B892CE2D4FA (RAP Certificate v1 248) sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 22.000 s Processing PPM file: RM-626_014.002_28.01_MEA_A_ArabicQwerty_79.92_prd.rof s2.fpsx [BB5,XSR 1.6] size: 38.30 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 67.50 MB CMT MuxOneNAND area [0A580000-0E8FFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 5.922 s Processing CNT file: RM-626_014.002_U10.01_79.92_prd.uda.fpsx [BB5,XSR 1.6] size: 96.07 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 484.50 MB CMT MuxOneNAND area [0FC80000-2E0FFFFF] Flash programming ... Error while programming [00] at 0x0FC80000, Result: 0000 |
09-16-2011, 07:16 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
all guys who have problem here are not using the latest update. sync: on server latest stable version = end users version. | |
12-20-2011, 23:44 | #15 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Morocco
Member: 77862 Status: Offline Thanks Meter: 15 | please Help Phone Power Off after flash & c'ant make full flash, always not start write CNT files ??? i was do synchronize but nothing change What i can do ? MXKEY [FT SCR2000 0], SN: C080A6DE Using device: USB ROM Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) Processing MCU file: RM-626_025.007_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 124.20 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ADE9838 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1BA0020A49D70344C96721B1120D20E22E2A50FA CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ADE9838 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 508.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0FC7FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 8EABFDA6 [RAP Certificate v1 248] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 25.406 s Processing PPM file: RM-626_025.007_32.01_MEA_C_ArabicQwerty_79.92_prd.rof s2.fpsx [BB5,XSR 1.6] size: 44.49 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 67.50 MB CMT FLASH,MuxOneNAND area [0A580000-0E8FFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 9.000 s Processing PPM file: RM-626_025.007_C05.01_MEA_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 15.80 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 19.50 MB CMT FLASH,MuxOneNAND area [0E900000-0FC7FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.031 s Processing CNT file: RM626_APE_ONLY_ENO_11w15_v0.033.fpsx [BB5,XSR 1.6] size: 4.15 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.890 s Processing CNT file: RM-626_025.007_U02.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 137.94 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 484.50 MB CMT FLASH,MuxOneNAND area [0FC80000-2E0FFFFF] Flash programming ... Error while programming [00] at 0x0FC80000, Result: 0000 |
5110 v 6.0 after unlocking problem with net | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 16:11 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
