Old 01-21-2012, 11:18   #1 (permalink)
Member: 528793
Thanks Meter: 9
e71 failed "RSA_VERIFY_FAILED" (ANSWERED)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08590DA
Using device: HTI, FW ver: 00.50, SN: 00000317
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Phone type: RM-346 (Nokia E71)
SW version: V ICPR71_09w22.9 16-10-09 RM-346 (c) Nokia
ApeCoreSw: 400.21.013
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0D500115AC9B005285760C8B3AD23E28D7131643
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
PRIVATE ID: 3C81117CA60CC67B95E216BFA8D149F19687AD52
E-FUSE: E6E6914D
SEC ROM CRC: 3E691FF8
Restarting phone ...
Verifying secure data ...OK
HASH: A55B279D360F51A0BCC17B92FBFB1B6B0A755CEF
Verifying RSA signature ...failed "RSA_VERIFY_FAILED"
Old 01-21-2012, 13:16   #2 (permalink)
Member: 528793
Thanks Meter: 9
e71 problem read hash
Old 01-21-2012, 22:10   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
please post buscheck logs
Old 01-23-2012, 12:05   #4 (permalink)
Member: 528793
Thanks Meter: 9
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Original Imei: 35271004568152
Original Product code: 0593445
Bluetooth ID: D4CBAFB0076E
SIMLOCK PA identifier:
[0] PA_SL2
[1] PA_SL3
Imei plain: 35271004568152-3
Product code: 0559571
Battery voltage: 4161 mV, current: 113 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Old 01-23-2012, 15:07   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
that's why i ask user to post buscheck logs.
unlocking and repairing is two different thing.
on your case, you will need to repair it's simlock.
Damaged SL3 simlock, damaged any BB5 IMEI:
presss restore IMEI if you have any backup.
and if no:
contact Fast Unlocking
make deal and send to him your .ask file.
ignore logs or version on picture, just an example
Page generated in 0.19678 seconds with 10 queries
