01-09-2012, 06:53 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Tirunelveli, Tamil nadu, India Age: 38
Member: 1323194 Status: Offline Thanks Meter: 61 | E71 Flashing problem (SOLVED) MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C083----- Using device: HTI, FW ver: 00.50, SN: 00000947 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B40010B689C005228D08FB2231187B6A47612A4 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT S***ested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7 Processing MCU file: rm346_510.21.009_prd.c00 [BB5,XSR 1.5] size: 67.83 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 122.56 MB CMT FLASH,MuxOneNAND area [00040000-007FFFFF] CMT FLASH,MuxOneNAND area [00A00000-0759FFFF] CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 52570A20 [RAP Certificate 101 v1] sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS*CORE block sent CMT SOS+ROFS block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 3 min 1.656 s Processing PPM file: rm346_510.21.009_prd.v27 [BB5,XSR 1.5] size: 24.05 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 33.56 MB CMT FLASH,MuxOneNAND area [05420000-0759FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFX block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 6.625 s Processing CNT file: RM346_ENO_0741.10_08wk42.a36.fpsx [BB5,XSR 1.5] size: 1.53 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103, 4003192101051103, 400C192101051103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 64 KB Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS*ENO block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4.312 s Processing CNT file: leevi_erase_y_drive.fpsx [BB5,XSR 1.5] size: 244 Bytes Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 400C192101031105 Erase size: 1.62 MB CMT FLASH,MuxOneNAND area [0F020000-0F1BFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Programming completed in 0.000 s Processing CNT file: rm346_510.21.009.55U [BB5,XSR 1.5] size: 15.17 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 64 KB Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 42.734 s Total time for flashing process(boot+erase+write) was 5 min 5.078 s |
01-09-2012, 09:13 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | 1. Download last version http://forum.gsmhosting.com/vbb/f550...hread-1410959/ 2. use FBUS: ignore different logs and mxkey version, just an example |
The Following 2 Users Say Thank You to gbluez For This Useful Post: |
01-09-2012, 16:08 | #4 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | try to reflash once more. if keypad still error, means HW problem. - start self test, see keyboard stuck result. |
The Following User Says Thank You to gbluez For This Useful Post: |
12-08-2012, 08:45 | #6 (permalink) | |
No Life Poster Join Date: Apr 2010
Member: 1276771 Status: Offline Thanks Meter: 33 | Quote:
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
