Old 02-26-2010, 17:22   #1 (permalink)
Registered User
Member: 617315
Sonork: Skopje Nord Macedonia
Thanks Meter: 22
E71 just blinking after unlock procedure!!![SOLVED]
I have one E71 that i try to unlock and at some stage of the process i got a 'access violation' error, and after that i've got Simlock Corrupted.
I made full RPL backup(all section) and full PM backup before unlocking. And now the phone just blinks and can't go in local mode!
I reflash it but,again the same.
some advice????
thanx in advance!!
Old 02-26-2010, 17:49   #2 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
somebody to help me,how i can solve this??
how to enter in local mode and to try to write back the backups i have???
thanx
Old 02-26-2010, 17:55   #3 (permalink)
:: Micron ::'s Avatar
Member: 252289
Thanks Meter: 107
Write RPL backup .... it should work
Old 02-26-2010, 18:03   #4 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
I can't because the phone can't go in local mode,when i try it,I'm getting this error: 'Error unable to detect product !'
Old 02-26-2010, 19:21   #5 (permalink)
Member: 258446
Thanks Meter: 26
First save your full backup RPL and PM to safe folder to avoid over writing it.
Second Bus check and post logs here
Third ( waiting mode) flash phone original software same version.
Old 02-26-2010, 19:36   #6 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
This is the log when I click 'bus check':
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1BD00104EC7A005258DC040B7D0F2031A1B28851
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
Original Imei: 354208033*****
Original Product code: 0573672
Phone not responding !
Old 02-26-2010, 19:47   #7 (permalink)
Member: 773516
Sonork: 100.1583311
Thanks Meter: 69
dont use bus cheek use scan to connect d phone
Old 02-26-2010, 19:53   #8 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
when i press scan nothing happens, it can't go in local mode and I'm just getting this 'Phone not responding !'.
Old 02-26-2010, 19:57   #9 (permalink)
p4padne's Avatar
Member: 870153
Sonork: 100.1594619
Thanks Meter: 28
Flash with UFS , then write RPL with Mx-key...post the result
Old 02-26-2010, 20:17   #10 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
Originally Posted by oOXTCOo View Post
i can tell you how to repair it.
1.) make cmt backup (i use always jaf for this, dont know where and if exists option in mx key, but i think somewhere it will exists just search).
this backup can be made with death phones too, cause its done in flashmode.
this backup help you after the repair, to restore your imei back.
2.) now erease the phone or just use empty ncp and write to phone.
at this point phone should again enter local mode.
3.) now repair your simlocks and sd.
EDIT: I SEE YOU HAVE PM BACKUP, JUST WRITE THIS BACK AT THIS POINT INSTEAD OF REPAIR,
TO HAVE ORIGINAL DATA BACK.
4.) write back cmt imei backup to restore your imei.
5.) if you have now any problem like security test fail, make sx4 auth and write pm1 and 309.
phone should be okay again...
Does NPC data is the same with CMT data?
does that file look like this,this is my NPC backup:
[CERT_PROG_DATA_OUT_CMT]
NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303537333637324300000000
NPC_DATA_2=000000000000000000000000061202989CA71C4 AF99F0E00646F7242000000001BD00104EC7A0052
NPC_DATA_3=58DC040B7D0F2031A1B2885152570A2086C79E6 965175815B5388535CDD5C6F73AB9EA7F5B4EC021
NPC_DATA_4=25B3027045C9A9BAC5417F74000000000000000 000000000000000000300000047534D0000000000
NPC_DATA_5=3345020833184825FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF574C414E5F494400
NPC_DATA_6=C77A9BCF2500000000000000000000000000000 000000000000000000000000042545F4944000000
NPC_DATA_7=E74B9BCF2500000000000000000000000000000 000000000000000000000000084003BB504115D3B
NPC_DATA_8=6F8CE1C8FA0A13170A9B86AD38833E3455C36BF EB1B6C0D73CED2BC263A52B03A1B1F0333612F7AD
NPC_DATA_9=8D70B1E0F111EC0654FCF563A3666AF3DE7FFC7 495108342212C812B0BD1EEC821C8A3B73CA37639
NPC_DATA_10=E5E40EDC45CB1267D7A44E3FEEFA9216E4691F 71785C1BD532DEA6199B1693FDFA1E9E753D615489
CHECKSUM=-1
[CERT_PROG_DATA_OUT_APE]
CHECKSUM=-1
And I have the full RPL backup too.
Old 02-26-2010, 21:28   #11 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 157
What about ENO file??
Old 02-26-2010, 23:06   #12 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
it will not work, because he have failed at unlocking process.
and if phone not enters local mode, means he have demaged pm308... (complete erased, wrong data, to mutch data, empty data).
but yes, after all if he have done all steps and still have no local mode, he should flash eno too, because maybe he have already flashed to v400 and i got many e71 after update to v400 cant enter local mode.
but all seems for me that pm308 field is corrupted.
(i had this problem many many times).
ohh, i forget...
for e71 exits a special erase file... (will not work with empty npc or normal erease files).
if i find it on my home computer i post it here.
but if you know how, its very easy to repair it fully.
i search now the erase file and post it if i find it on my home pc.
EDIT: HERE IS THE RIGHT EREASE FILE... ERASE IT WITH THIS AND AFTER, UPDATE FIRMWARE...
then phone enters local mode again...
then write back pm308 backup and CMT IMEI...
your are done and phone is 100% working again!
thanx a lot bro for your help, I'll try it tomorrow morning,i'm finish for today.
tanx a lot again!
Old 02-26-2010, 23:39   #13 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
some easy ways ,
need to try
goto
SERVICE -> quick fix -> do "BB5 Downgrade FIX"
@hari
txs for supporting our section
br,
Old 02-27-2010, 09:38   #14 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
ohh, i forget...
I erase it with that file,and flash it with sw.version 300.21.012, but again can't go in local mode,here is the log from the flashing:
Processing file: rm346_300.21.012_prd.c00 as MCU
[BB5,XSR 1.5] size: 64.33 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Storing certificate ...OK
Partitioning ...OK
Total erase size: 64.00 KB
CMT ONENAND area [00040000-007FFFFF]
CMT ONENAND area [00A00000-0759FFFF]
CMT ONENAND area [0F1C0000-0F8BFFFF]
Format NAND
Format NAND
Format NAND
erased in 0.829 s
Flash programming ...
CMT PAPUBKEYS: 52570A2086C79E6965175815B5388535CDD5C6F7 (RAP Certificate 101 v1) written.
Programming completed in 6 min 4.437 s
Processing file: rm346_300.21.012_prd.v16 as PPM
[BB5,XSR 1.5] size: 29.01 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
CMT ONENAND area [05420000-0759FFFF]
Format NAND
erased in 0.344 s
Programming completed in 2 min 47.422 s
Processing file: RM346_ENO_0741.10_08wk42.a36.fpsx as CNT
[BB5,XSR 1.5] size: 1.53 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103, 4003192101051103, 400C192101051103
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
APE SOSENO
erased in 0.282 s
Programming completed in 9.172 s
Processing file: leevi_erase_y_drive.fpsx as CNT
[BB5,XSR 1.5] size: 244 Bytes
Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 400C192101031105
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 1.62 MB
CMT ONENAND area [0F020000-0F1BFFFF]
erased in 0.079 s
Programming completed in 0.360 s
Processing file: rm346_300.21.012.02U as CNT
[BB5,XSR 1.5] size: 8.57 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Format NAND
erased in 1.281 s
Programming completed in 50.390 s
Flashing completed in 10 min 58.391 s
Total time to process is 12 min 14.625 s
Old 02-27-2010, 09:51   #15 (permalink)
Registered User
Member: 617315
Thanks Meter: 22
and this is the erase log:
Total erase size: 256.00 MB
CMT NOR area [00000000-0FFFFFFF] erased in 0.156 s
warning : erase sector address out of chip bound.
5320 XpressMusic just blink after flash Syed Nokia Base Band 5 ( BB-5 ) 17 02-01-2010 10:09
K750i just blinking after start up ZOLTAR Sony Ericsson Hardware Repair 3 12-03-2008 17:23
x60 just blink after full flash ! ..:HGSM:.. Infinity-Box 8 03-27-2006 13:22
a35 just blinks after trying to change imei magnet x1x to x45/x50 4 12-15-2002 14:24
A300 just blinking after trying to openline flash VLSI, Conexant, Skyworks and Old Models 1 09-27-2002 05:11
Page generated in 0.25270 seconds with 9 queries
