E71 reset phone lock doent works Version Info: MCU SW version: V 100.71.821.4 06-06-08 RM-346 (c) Nokia HW version: 0910 RFIC version: 17141715 DSP version: L07w15PB_08w20 APE SW Core version: 100.07.76 APE Variant version: 100.07.76100.07.76_v215_20.02 APE Test version: RM346ENO7411718214.029 Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 WLAN ID: 00 AE 29 1A FC 22 Bluetooth ID: 00 22 FC 19 CB EE Product Info: Production serial number: SIK206207 Product code: 0568687 Basic production code: 0552256 Product specific data: 000000000000000000000000000000000000 Long production SN: 0 Serial Numbers: IMEI plain: 354855024058702 IMEI spare to net: 3A 45 58 05 42 50 78 IMEI SV to net: 33 45 58 05 42 50 78 00 F1 NCK Codes: #pw+294943294949577+1# Other Info: Model: Nokia E71 (Smartphone) CS type: GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA VIII Battery voltage: 4616 mV Battery current: 72 mA BSI: 4.8 KOhm Imei net: 35xxxxxxxxxxxx Version: SIMLOCK SERVER Provider: Hutchison 3G Australia Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050600042465540 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN BLOCK2: 1=OPEN BLOCK3: 1=OPEN Counter already blocked. FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.717 s i try 12345 it didn't works |
Power on the phone,wait for 5 minutes and try. If it doesn`t work,read user code and try it same way. br. |
Yours is 1st Method, Already 2nd Method not works, So Encrypted Code can't be remove with your Method. See this: Quote:
The only option is to Tick Factory Reset after Flash & Flash it with Latest Firmware will solve it. BR, ZUBER |
solved 100% try iT:) http://imageshack.us/a/img839/9228/54248576.jpg BR. Arsalan gsm2000:) |
Code: FULL FACTORY... OK |
downlaod file mcu,ppm,cnt,mmc,cnt and check all then flash here the result Code: Version from phone: 100.07.76 |
Try to usb flash before full backup must. BR. Arsalan gsm2000. |
