Old 10-05-2012, 01:44   #1 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 213
E71 reset phone lock doent works
Version Info:
MCU SW version: V 100.71.821.4 06-06-08 RM-346 (c) Nokia
HW version: 0910
RFIC version: 17141715
DSP version: L07w15PB_08w20
APE SW Core version: 100.07.76
APE Variant version: 100.07.76100.07.76_v215_20.02
APE Test version: RM346ENO7411718214.029
Retu version: 15
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
WLAN ID: 00 AE 29 1A FC 22
Bluetooth ID: 00 22 FC 19 CB EE
Product Info:
Production serial number: SIK206207
Product code: 0568687
Basic production code: 0552256
Product specific data: 000000000000000000000000000000000000
Long production SN: 0
Serial Numbers:
IMEI plain: 354855024058702
IMEI spare to net: 3A 45 58 05 42 50 78
IMEI SV to net: 33 45 58 05 42 50 78 00 F1
NCK Codes: #pw+294943294949577+1#
Other Info:
Model: Nokia E71 (Smartphone)
CS type: GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA VIII
Battery voltage: 4616 mV
Battery current: 72 mA
BSI: 4.8 KOhm
Imei net: 35xxxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Hutchison 3G Australia Pty. Ltd. , Country: Australia
Counter: 0/3, 0/10
CONFIG_DATA: 5050600042465540
PROFILE_BITS: 8000000000000000
BLOCK1: 1=OPEN
BLOCK2: 1=OPEN
BLOCK3: 1=OPEN
Counter already blocked.
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 2.717 s
i try 12345 it didn't works
Old 10-05-2012, 02:38   #2 (permalink)
Member: 211475
Thanks Meter: 11
Power on the phone,wait for 5 minutes and try.
If it doesn`t work,read user code and try it same way.
br.
Old 10-05-2012, 09:29   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
br.
Bro.
Yours is 1st Method,
Already 2nd Method not works,
So Encrypted Code can't be remove with your Method.
See this:
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
When Both Method not works for Encrypted Code,
The only option is to Tick Factory Reset after Flash & Flash it with Latest Firmware will solve it.
BR,
ZUBER
Old 10-05-2012, 19:18   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
Originally Posted by chris2007 View Post
Version Info:
HW version: 0910
Retu version: 15
Tahvo version: 22
APE HW version: 256
Product Info:
Serial Numbers:
Other Info:
BSI: 4.8 KOhm
Counter: 0/3, 0/10
BLOCK1: 1=OPEN
BLOCK2: 1=OPEN
BLOCK3: 1=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
solved 100% try iT
BR.
Arsalan gsm2000
Old 10-06-2012, 00:52   #5 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 213
Originally Posted by gsm-2000 View Post
solved 100% try iT
BR.
Arsalan gsm2000
i was try this with no luck
FULL FACTORY... OK
Completed in 2.078 s
FULL FACTORY... OK
Completed in 0.969 s
FULL FACTORY... OK
Completed in 1.094 s
FULL FACTORY... OK
Completed in 1.203 s
FULL FACTORY... OK
Completed in 1.156 s
Old 10-10-2012, 22:09   #6 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 213
downlaod file mcu,ppm,cnt,mmc,cnt and check all then flash here the result
Version from phone: 100.07.76
Version from file: 300.21.012
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: xxxxxxxx
Using device: HTI, FW ver: 00.50, SN: xxxxxxxx
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1120020D49A50158DC69C8C874CD627E27799A0F
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
ERROR: Packet Error(0xAA), code 0xC0000002
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 11.34.0 revision: 2.0 size: 0x3B80
 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000  - 0000 0000  type: RAM, asic:CMT
Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
Storage2: 0400 0000  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040  - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5]  version: 11.34.0 revision: 2.0 size: 0x8FE30
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 11.10.0 revision: 2.0 size: 0x3B80
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
ERROR: Configuration request failed !
Read Certificate failed.
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\BB5_35xxxxxxxxxxxxx_BACK.rpl"
Unknown ID !
Error getting boot info !
ERROR: bootstrap failed!
Task failed at (0800000A)!!!
 Last RX buffer: 88 13 00 00 E8 03 00 00 E8 03 00 00
Old 10-11-2012, 15:03   #7 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC_DATA is empty.
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
Unknown ID !
Try to usb flash before full backup must.
BR.
Arsalan gsm2000.
Page generated in 0.30495 seconds with 7 queries
