06-04-2013, 03:48 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | E71 RM-346, after flash using usb imei 123456? now that my HTI box (Green) is dead, use usb to flash Nokia E71, did usb flashing do Backup all imei, simlock, certificates? because now after flash, my imei is gone and it became 123456? how to repair this problem, without HTI box, can i use usb connection only to repair/restore imei and simlock? i only see simlock backup in mxkey backup folder, i can't find imei backup, and is there a mxkey bb5 rpl service? kindly guide me step by step because my customer is demanding his phone back and i'm confuse on getting back the imei. thanks |
06-04-2013, 06:55 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | There is no way to damaged imei by just simple usb flashing. i suspect you are wrongly flash this phone by using mismatched firmware. About RAPIDO USB, same case like here. Full USB support just like on fbus only work on RAPU, BCM dan RAP3Gv4. give me a scan logs. |
06-04-2013, 22:30 | #3 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | this nokia came in alive condition, but the phonebook can't open, so i try to flash with usb flashing but after flash process, the handset is dead and this is the logs : ================================================== ================================================== Time : 28/05/2013 5:14:01 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 09/05/2013 20:05:14 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1346 MB Free) ================================================== ================================================== LastError: Error 0xFFFFFFFF Instance Closed. 0084132. Read of address 63306128 ================================================== ================================================== Time : 28/05/2013 5:14:17 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 09/05/2013 20:05:14 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1346 MB Free) ================================================== ================================================== Instance Closed. lash check: 0000B00D |MCU : C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-346\rm346_510.21.009_prd.c00 0000 >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004AC 1 of 1 > Nokia USB Flashing Generic:FFFFFFFF 1 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004AC 1 of 2 > Nokia USB Flashing Generic:000004AC 1 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000360 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000360 2 of 2 > Nokia USB Flashing Generic:00000360 2 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004D0 3 of 3 > Nokia USB Flashing Generic:FFFFFFFF 3 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004D0 3 of 3 > Nokia USB Flashing Generic:FFFFFFFF 3 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004D0 3 of 2 > Nokia USB Flashing Generic:000004D0 3 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004D0 3 of 3 > Nokia USB Flashing Generic:000004D0 3 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000490 4 of 4 > Nokia USB Flashing Generic:FFFFFFFF 4 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed 0003027C |[USBSTOR]Access violation at address 10085126. Read of address 63306128 Method: Bulk, SingleAsic, Cold 000004AC |BeginEraseFlash: 2 000004AC |> RAP NAND device. 000004AC |#CMT : 3 sector(s) CMT FLASH,MuxOneNAND area #[00040000-007FFFFF] CMT FLASH,MuxOneNAND area #[00A00000-0759FFFF] CMT FLASH,MuxOneNAND area #[0F1C0000-0F8BFFFF] 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |#CMT : 3 sector(s) CMT FLASH,MuxOneNAND area #[00040000-007FFFFF] CMT FLASH,MuxOneNAND area #[00A00000-0759FFFF] CMT FLASH,MuxOneNAND area #[0F1C0000-0F8BFFFF] 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |Erase complete. 000004AC |Begin flash programming: C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-346\rm346_510.21.009_prd.c00 000004AC |fileSize: 0x43D41C8 000004AC |availMem: 0x4F15E000 000004AC |[WriteBlock] Handling file with huge size 000004AC |Master ASIC set to CMT 000004AC |CMT NAND writing block [00000000], size 0x200 000004AC |CMT NAND writing block [00000200], size 0x200 000004AC |CMT NAND writing block [00020000], size 0x200 000004AC |CMT NAND writing block [00080000], size 0x400 000004AC |CMT NAND writing block [00080800], size 0x2200 000004AC |CMT NAND writing block [00083600], size 0x600 000004AC |CMT NAND writing block [00084400], size 0x15800 000004AC |38F312750F686F9FC9B1B3778774A195,52570A2086C79E69 65175815B5388535CDD5C6F7 000004AC |CAEEBB65D3C48E6DC73B49DC5063A2EE,52570A2086C79E69 65175815B5388535CDD5C6F7 000004AC |CMT Writing PaPubKeysHash (PAPUBKEYS, RAP Certificate 101 v1) 000004AC |F2D76DFAFD66C7F195F278417DF05888,52570A2086C79E69 65175815B5388535CDD5C6F7 000004AC |479C6DDE3942E12C429C1D6ADED80371,52570A2086C79E69 65175815B5388535CDD5C6F7 000004AC |B8C3ADECFC997FCD8081D3DEAF870B8C,52570A2086C79E69 65175815B5388535CDD5C6F7 000004AC |CMT NAND writing block [000C0400], size 0x200 000004AC |CMT NAND writing block [00400400], size 0x20000 000004AC |CMT NAND writing block [00420400], size 0x20000 000004AC |CMT NAND writing block [00440400], size 0x20000 000004AC |CMT NAND writing block [00460400], size 0x20000 000004AC |CMT NAND writing block [00480400], size 0x20000 000004AC |CMT NAND writing block [004A0400], size 0x20000 000004AC |CMT NAND writing block [004C0400], size 0x20000 000004AC |CMT NAND writing block [004E0400], size 0x15A00 000004AC |CMT NAND writing block [00500400], size 0x20000 000004AC |CMT NAND writing block [00520400], size 0x20000 000004AC |CMT NAND writing block [00540400], size 0x20000 000004AC |CMT NAND writing block [00560400], size 0x20000 000004AC |CMT NAND writing block [00580400], size 0x20000 000004AC |CMT NAND writing block [005A0400], size 0x20000 000004AC |CMT NAND writing block [005C0400], size 0x20000 000004AC |CMT NAND writing block [005E0400], size 0x20000 000004AC |CMT NAND writing block [00600400], size 0x20000 000004AC |CMT NAND writing block [00620400], size 0x20000 000004AC |CMT NAND writing block [00640400], size 0x20000 000004AC |CMT NAND writing block [00660400], size 0x20000 000004AC |CMT NAND writing block [00680400], size 0x20000 000004AC |CMT NAND writing block [006A0400], size 0x20000 000004AC |CMT NAND writing block [006C0400], size 0x20000 000004AC |CMT NAND writing block [006E0400], size 0x20000 000004AC |CMT NAND writing block [00700400], size 0x20000 000004AC |CMT NAND writing block [00720400], size 0x20000 000004AC |CMT NAND writing block [00740400], size 0x20000 000004AC |CMT NAND writing block [00760400], size 0x10200 000004AC |CMT NAND writing block [00A00400], size 0x20000 000004AC |CMT NAND writing block [00A20400], size 0x20000 000004AC |CMT NAND writing block [00A40400], size 0x20000 000004AC |CMT NAND writing block [00A60400], size 0x20000 000004AC |CMT NAND writing block [00A80400], size 0x20000 000004AC |CMT NAND writing block [00AA0400], size 0x20000 000004AC |CMT NAND writing block [00AC0400], size 0x20000 000004AC |CMT NAND writing block [00AE0400], size 0x20000 000004AC |CMT NAND writing block [00B00400], size 0x20000 000004AC |CMT NAND writing block [00B20400], size 0x20000 000004AC |CMT NAND writing block [00B40400], size 0x20000 000004AC |CMT NAND writing block [00B60400], size 0x20000 000004AC |CMT NAND writing block [00B80400], size 0x20000 000004AC |CMT NAND writing block [00BA0400], size 0x20000 000004AC |CMT NAND writing block [00BC0400], size 0x20000 000004AC |CMT NAND writing block [00BE0400], size 0x20000 000004AC |CMT NAND writing block [00C00400], size 0x20000 000004AC |CMT NAND writing block [00C20400], size 0x20000 000004AC |CMT NAND writing block [00C40400], size 0x20000 000004AC |CMT NAND writing block [00C60400], size 0x20000 000004AC |CMT NAND writing block [00C80400], size 0x20000 000004AC |CMT NAND writing block [00CA0400], size 0x20000 000004AC |CMT NAND writing block [00CC0400], size 0x20000 000004AC |CMT NAND writing block [00CE0400], size 0x20000 000004AC |CMT NAND writing block [00D00400], size 0x20000 000004AC |CMT NAND writing block [00D20400], size 0x20000 000004AC |CMT NAND writing block [00D40400], size 0x20000 000004AC |CMT NAND writing block [00D60400], size 0x20000 000004AC |CMT NAND writing block [00D80400], size 0x20000 000004AC |CMT NAND writing block [00DA0400], size 0x20000 000004AC |CMT NAND writing block [00DC0400], size 0x20000 000004AC |CMT NAND writing block [00DE0400], size 0x20000 000004AC |CMT NAND writing block [00E00400], size 0x20000 000004AC |CMT NAND writing block [00E20400], size 0x20000 000004AC |CMT NAND writing block [00E40400], size 0x20000 000004AC |CMT NAND writing block [00E60400], size 0x20000 000004AC |CMT NAND writing block [00E80400], size 0x20000 000004AC |CMT NAND writing block [00EA0400], size 0x20000 000004AC |CMT NAND writing block [00EC0400], size 0x20000 000004AC |CMT NAND writing block [00EE0400], size 0x20000 000004AC |CMT NAND writing block [00F00400], size 0x20000 000004AC |CMT NAND writing block [00F20400], size 0x20000 000004AC |CMT NAND writing block [00F40400], size 0x20000 000004AC |CMT NAND writing block [00F60400], size 0x20000 000004AC |CMT NAND writing block [00F80400], size 0x20000 000004AC |CMT NAND writing block [00FA0400], size 0x20000 000004AC |CMT NAND writing block [00FC0400], size 0x20000 000004AC |CMT NAND writing block [00FE0400], size 0x20000 000004AC |CMT NAND writing block [01000400], size 0x20000 000004AC |CMT NAND writing block [01020400], size 0x20000 000004AC |CMT NAND writing block [01040400], size 0x20000 000004AC |CMT NAND writing block [01060400], size 0x20000 000004AC |CMT NAND writing block [01080400], size 0x20000 000004AC |CMT NAND writing block [010A0400], size 0x20000 000004AC |CMT NAND writing block [010C0400], size 0x20000 000004AC |CMT NAND writing block [010E0400], size 0x20000 000004AC |CMT NAND writing block [01100400], size 0x20000 000004AC |CMT NAND writing block [01120400], size 0x20000 000004AC |CMT NAND writing block [01140400], size 0x20000 000004AC |CMT NAND writing block [01160400], size 0x20000 000004AC |CMT NAND writing block [01180400], size 0x20000 000004AC |CMT NAND writing block [011A0400], size 0x20000 000004AC |CMT NAND writing block [011C0400], size 0x20000 000004AC |CMT NAND writing block [011E0400], size 0x20000 000004AC |CMT NAND writing block [01200400], size 0x20000 000004AC |CMT NAND writing block [01220400], size 0x20000 000004AC |CMT NAND writing block [01240400], size 0x20000 000004AC |CMT NAND writing block [01260400], size 0x20000 000004AC |CMT NAND writing block [01280400], size 0x20000 000004AC |CMT NAND writing block [012A0400], size 0x20000 000004AC |CMT NAND writing block [012C0400], size 0x20000 000004AC |CMT NAND writing block [012E0400], size 0x20000 000004AC |CMT NAND writing block [01300400], size 0x20000 000004AC |CMT NAND writing block [01320400], size 0x20000 000004AC |CMT NAND writing block [01340400], size 0x20000 000004AC |CMT NAND writing block [01360400], size 0x20000 000004AC |CMT NAND writing block [01380400], size 0x20000 000004AC |CMT NAND writing block [013A0400], size 0x20000 000004AC |CMT NAND writing block [013C0400], size 0x20000 000004AC |CMT NAND writing block [013E0400], size 0x20000 000004AC |CMT NAND writing block [01400400], size 0x5600 000004AC |CMT NAND writing block [01600400], size 0x20000 000004AC |CMT NAND writing block [01620400], size 0x20000 000004AC |CMT NAND writing block [01640400], size 0x20000 000004AC |CMT NAND writing block [01660400], size 0x20000 000004AC |CMT NAND writing block [01680400], size 0x20000 000004AC |CMT NAND writing block [016A0400], size 0x20000 000004AC |CMT NAND writing block [016C0400], size 0x20000 000004AC |CMT NAND writing block [016E0400], size 0x20000 000004AC |CMT NAND writing block [01700400], size 0x20000 000004AC |CMT NAND writing block [01720400], size 0x20000 000004AC |CMT NAND writing block [01740400], size 0x20000 000004AC |CMT NAND writing block [01760400], size 0x20000 000004AC |CMT NAND writing block [01780400], size 0x20000 000004AC |CMT NAND writing block [017A0400], size 0x20000 000004AC |CMT NAND writing block [017C0400], size 0x20000 000004AC |CMT NAND writing block [017E0400], size 0x20000 000004AC |CMT NAND writing block [01800400], size 0x20000 000004AC |CMT NAND writing block [01820400], size 0x20000 000004AC |CMT NAND writing block [01840400], size 0x20000 000004AC |CMT NAND writing block [01860400], size 0x20000 000004AC |CMT NAND writing block [01880400], size 0x20000 000004AC |CMT NAND writing block [018A0400], size 0x20000 000004AC |CMT NAND writing block [018C0400], size 0x20000 000004AC |CMT NAND writing block [018E0400], size 0x20000 000004AC |CMT NAND writing block [01900400], size 0x20000 000004AC |CMT NAND writing block [01920400], size 0x20000 000004AC |CMT NAND writing block [01940400], size 0x20000 000004AC |CMT NAND writing block [01960400], size 0x20000 000004AC |CMT NAND writing block [01980400], size 0x20000 000004AC |CMT NAND writing block [019A0400], size 0x20000 000004AC |CMT NAND writing block [019C0400], size 0x20000 000004AC |CMT NAND writing block [019E0400], size 0x20000 000004AC |CMT NAND writing block [01A00400], size 0x20000 000004AC |CMT NAND writing block [01A20400], size 0x20000 000004AC |CMT NAND writing block [01A40400], size 0x20000 000004AC |CMT NAND writing block [01A60400], size 0x20000 000004AC |CMT NAND writing block [01A80400], size 0x20000 000004AC |CMT NAND writing block [01AA0400], size 0x20000 000004AC |CMT NAND writing block [01AC0400], size 0x20000 000004AC |CMT NAND writing block [01AE0400], size 0x20000 000004AC |CMT NAND writing block [01B00400], size 0x20000 000004AC |CMT NAND writing block [01B20400], size 0x20000 000004AC |CMT NAND writing block [01B40400], size 0x20000 000004AC |CMT NAND writing block [01B60400], size 0x20000 000004AC |CMT NAND writing block [01B80400], size 0x20000 000004AC |CMT NAND writing block [01BA0400], size 0x20000 000004AC |CMT NAND writing block [01BC0400], size 0x20000 000004AC |CMT NAND writing block [01BE0400], size 0x20000 000004AC |CMT NAND writing block [01C00400], size 0x20000 000004AC |CMT NAND writing block [01C20400], size 0x20000 000004AC |CMT NAND writing block [01C40400], size 0x20000 000004AC |CMT NAND writing block [01C60400], size 0x20000 000004AC |CMT NAND writing block [01C80400], size 0x20000 000004AC |CMT NAND writing block [01CA0400], size 0x20000 000004AC |CMT NAND writing block [01CC0400], size 0x20000 000004AC |CMT NAND writing block [01CE0400], size 0x20000 000004AC |CMT NAND writing block [01D00400], size 0x20000 000004AC |CMT NAND writing block [01D20400], size 0x20000 000004AC |CMT NAND writing block [01D40400], size 0x20000 000004AC |CMT NAND writing block [01D60400], size 0x20000 000004AC |CMT NAND writing block [01D80400], size 0x20000 000004AC |CMT NAND writing block [01DA0400], size 0x20000 000004AC |CMT NAND writing block [01DC0400], size 0x20000 000004AC |CMT NAND writing block [01DE0400], size 0x20000 000004AC |CMT NAND writing block [01E00400], size 0x20000 000004AC |CMT NAND writing block [01E20400], size 0x20000 000004AC |CMT NAND writing block [01E40400], size 0x20000 000004AC |CMT NAND writing block [01E60400], size 0x20000 000004AC |CMT NAND writing block [01E80400], size 0x20000 000004AC |CMT NAND writing block [01EA0400], size 0x20000 000004AC |CMT NAND writing block [01EC0400], size 0x20000 000004AC |CMT NAND writing block [01EE0400], size 0x20000 000004AC |CMT NAND writing block [01F00400], size 0x20000 000004AC |CMT NAND writing block [01F20400], size 0x20000 000004AC |CMT NAND writing block [01F40400], size 0x20000 000004AC |CMT NAND writing block [01F60400], size 0x20000 000004AC |CMT NAND writing block [01F80400], size 0x20000 000004AC |CMT NAND writing block [01FA0400], size 0x20000 000004AC |CMT NAND writing block [01FC0400], size 0x20000 000004AC |CMT NAND writing block [01FE0400], size 0x20000 000004AC |CMT NAND writing block [02000400], size 0x20000 000004AC |CMT NAND writing block [02020400], size 0x20000 000004AC |CMT NAND writing block [02040400], size 0x20000 000004AC |CMT NAND writing block [02060400], size 0x20000 000004AC |CMT NAND writing block [02080400], size 0x20000 000004AC |CMT NAND writing block [020A0400], size 0x20000 000004AC |CMT NAND writing block [020C0400], size 0x20000 000004AC |CMT NAND writing block [020E0400], size 0x20000 000004AC |CMT NAND writing block [02100400], size 0x20000 000004AC |CMT NAND writing block [02120400], size 0x20000 000004AC |CMT NAND writing block [02140400], size 0x20000 000004AC |CMT NAND writing block [02160400], size 0x20000 000004AC |CMT NAND writing block [02180400], size 0x20000 000004AC |CMT NAND writing block [021A0400], size 0x20000 000004AC |CMT NAND writing block [021C0400], size 0x20000 000004AC |CMT NAND writing block [021E0400], size 0x20000 000004AC |CMT NAND writing block [02200400], size 0x20000 000004AC |CMT NAND writing block [02220400], size 0x20000 000004AC |CMT NAND writing block [02240400], size 0x20000 000004AC |CMT NAND writing block [02260400], size 0x20000 000004AC |CMT NAND writing block [02280400], size 0x20000 000004AC |CMT NAND writing block [022A0400], size 0x20000 000004AC |CMT NAND writing block [022C0400], size 0x20000 000004AC |CMT NAND writing block [022E0400], size 0x20000 000004AC |CMT NAND writing block [02300400], size 0x20000 000004AC |CMT NAND writing block [02320400], size 0x20000 000004AC |CMT NAND writing block [02340400], size 0x20000 000004AC |CMT NAND writing block [02360400], size 0x20000 000004AC |CMT NAND writing block [02380400], size 0x20000 000004AC |CMT NAND writing block [023A0400], size 0x20000 000004AC |CMT NAND writing block [023C0400], size 0x20000 000004AC |CMT NAND writing block [023E0400], size 0x20000 000004AC |CMT NAND writing block [02400400], size 0x20000 000004AC |CMT NAND writing block [02420400], size 0x20000 000004AC |CMT NAND writing block [02440400], size 0x20000 000004AC |CMT NAND writing block [02460400], size 0x20000 000004AC |CMT NAND writing block [02480400], size 0x20000 000004AC |CMT NAND writing block [024A0400], size 0x20000 000004AC |CMT NAND writing block [024C0400], size 0x20000 000004AC |CMT NAND writing block [024E0400], size 0x20000 000004AC |CMT NAND writing block [02500400], size 0x20000 000004AC |CMT NAND writing block [02520400], size 0x20000 000004AC |CMT NAND writing block [02540400], size 0x20000 000004AC |CMT NAND writing block [02560400], size 0x20000 000004AC |CMT NAND writing block [02580400], size 0x20000 000004AC |CMT NAND writing block [025A0400], size 0x20000 000004AC |CMT NAND writing block [025C0400], size 0x20000 000004AC |CMT NAND writing block [025E0400], size 0x20000 000004AC |CMT NAND writing block [02600400], size 0x20000 000004AC |CMT NAND writing block [02620400], size 0x20000 000004AC |CMT NAND writing block [02640400], size 0x20000 000004AC |CMT NAND writing block [02660400], size 0x20000 000004AC |CMT NAND writing block [02680400], size 0x20000 000004AC |CMT NAND writing block [026A0400], size 0x20000 000004AC |CMT NAND writing block [026C0400], size 0x20000 000004AC |CMT NAND writing block [026E0400], size 0x20000 000004AC |CMT NAND writing block [02700400], size 0x20000 000004AC |CMT NAND writing block [02720400], size 0x20000 000004AC |CMT NAND writing block [02740400], size 0x20000 000004AC |CMT NAND writing block [02760400], size 0x20000 000004AC |CMT NAND writing block [02780400], size 0x20000 000004AC |CMT NAND writing block [027A0400], size 0x20000 000004AC |CMT NAND writing block [027C0400], size 0x20000 000004AC |CMT NAND writing block [027E0400], size 0x20000 000004AC |CMT NAND writing block [02800400], size 0x20000 000004AC |CMT NAND writing block [02820400], size 0x20000 000004AC |CMT NAND writing block [02840400], size 0x20000 000004AC |CMT NAND writing block [02860400], size 0x20000 000004AC |CMT NAND writing block [02880400], size 0x20000 000004AC |CMT NAND writing block [028A0400], size 0x20000 000004AC |CMT NAND writing block [028C0400], size 0x20000 000004AC |CMT NAND writing block [028E0400], size 0x20000 000004AC |CMT NAND writing block [02900400], size 0x20000 000004AC |CMT NAND writing block [02920400], size 0x20000 000004AC |CMT NAND writing block [02940400], size 0x20000 000004AC |CMT NAND writing block [02960400], size 0x20000 000004AC |CMT NAND writing block [02980400], size 0x20000 000004AC |CMT NAND writing block [029A0400], size 0x20000 000004AC |CMT NAND writing block [029C0400], size 0x20000 000004AC |CMT NAND writing block [029E0400], size 0x20000 000004AC |CMT NAND writing block [02A00400], size 0x20000 000004AC |CMT NAND writing block [02A20400], size 0x20000 000004AC |CMT NAND writing block [02A40400], size 0x20000 000004AC |CMT NAND writing block [02A60400], size 0x20000 000004AC |CMT NAND writing block [02A80400], size 0x20000 000004AC |CMT NAND writing block [02AA0400], size 0x20000 000004AC |CMT NAND writing block [02AC0400], size 0x20000 000004AC |CMT NAND writing block [02AE0400], size 0x20000 000004AC |CMT NAND writing block [02B00400], size 0x20000 000004AC |CMT NAND writing block [02B20400], size 0x20000 000004AC |CMT NAND writing block [02B40400], size 0x20000 000004AC |CMT NAND writing block [02B60400], size 0x20000 000004AC |CMT NAND writing block [02B80400], size 0x20000 000004AC |CMT NAND writing block [02BA0400], size 0x20000 000004AC |CMT NAND writing block [02BC0400], size 0x20000 000004AC |CMT NAND writing block [02BE0400], size 0x20000 000004AC |CMT NAND writing block [02C00400], size 0x20000 000004AC |CMT NAND writing block [02C20400], size 0x20000 000004AC |CMT NAND writing block [02C40400], size 0x20000 000004AC |CMT NAND writing block [02C60400], size 0x20000 000004AC |CMT NAND writing block [02C80400], size 0x20000 000004AC |CMT NAND writing block [02CA0400], size 0x20000 000004AC |CMT NAND writing block [02CC0400], size 0x20000 000004AC |CMT NAND writing block [02CE0400], size 0x20000 000004AC |CMT NAND writing block [02D00400], size 0x20000 000004AC |CMT NAND writing block [02D20400], size 0x20000 000004AC |CMT NAND writing block [02D40400], size 0x20000 000004AC |CMT NAND writing block [02D60400], size 0x20000 000004AC |CMT NAND writing block [02D80400], size 0x20000 000004AC |CMT NAND writing block [02DA0400], size 0x20000 000004AC |CMT NAND writing block [02DC0400], size 0x20000 000004AC |CMT NAND writing block [02DE0400], size 0x20000 000004AC |CMT NAND writing block [02E00400], size 0x20000 000004AC |CMT NAND writing block [02E20400], size 0x20000 000004AC |CMT NAND writing block [02E40400], size 0x20000 000004AC |CMT NAND writing block [02E60400], size 0x20000 000004AC |CMT NAND writing block [02E80400], size 0x20000 000004AC |CMT NAND writing block [02EA0400], size 0x20000 000004AC |CMT NAND writing block [02EC0400], size 0x20000 000004AC |CMT NAND writing block [02EE0400], size 0x20000 000004AC |CMT NAND writing block [02F00400], size 0x20000 000004AC |CMT NAND writing block [02F20400], size 0x20000 000004AC |CMT NAND writing block [02F40400], size 0x20000 000004AC |CMT NAND writing block [02F60400], size 0x20000 000004AC |CMT NAND writing block [02F80400], size 0x20000 000004AC |CMT NAND writing block [02FA0400], size 0x20000 000004AC |CMT NAND writing block [02FC0400], size 0x20000 000004AC |CMT NAND writing block [02FE0400], size 0x20000 000004AC |CMT NAND writing block [03000400], size 0x20000 000004AC |CMT NAND writing block [03020400], size 0x20000 000004AC |CMT NAND writing block [03040400], size 0x20000 000004AC |CMT NAND writing block [03060400], size 0x20000 000004AC |CMT NAND writing block [03080400], size 0x20000 000004AC |CMT NAND writing block [030A0400], size 0x20000 000004AC |CMT NAND writing block [030C0400], size 0x20000 000004AC |CMT NAND writing block [030E0400], size 0x20000 000004AC |CMT NAND writing block [03100400], size 0x20000 000004AC |CMT NAND writing block [03120400], size 0x20000 000004AC |CMT NAND writing block [03140400], size 0x20000 000004AC |CMT NAND writing block [03160400], size 0x20000 000004AC |CMT NAND writing block [03180400], size 0x20000 000004AC |CMT NAND writing block [031A0400], size 0x20000 000004AC |CMT NAND writing block [031C0400], size 0x20000 000004AC |CMT NAND writing block [031E0400], size 0x20000 000004AC |CMT NAND writing block [03200400], size 0x20000 000004AC |CMT NAND writing block [03220400], size 0x20000 000004AC |CMT NAND writing block [03240400], size 0x20000 000004AC |CMT NAND writing block [03260400], size 0x20000 000004AC |CMT NAND writing block [03280400], size 0x20000 000004AC |CMT NAND writing block [032A0400], size 0x20000 000004AC |CMT NAND writing block [032C0400], size 0x20000 000004AC |CMT NAND writing block [032E0400], size 0x20000 000004AC |CMT NAND writing block [03300400], size 0x20000 000004AC |CMT NAND writing block [03320400], size 0x20000 000004AC |CMT NAND writing block [03340400], size 0x20000 000004AC |CMT NAND writing block [03360400], size 0x20000 000004AC |CMT NAND writing block [03380400], size 0x20000 000004AC |CMT NAND writing block [033A0400], size 0x20000 000004AC |CMT NAND writing block [033C0400], size 0x20000 000004AC |CMT NAND writing block [033E0400], size 0x20000 000004AC |CMT NAND writing block [03400400], size 0x20000 000004AC |CMT NAND writing block [03420400], size 0x20000 000004AC |CMT NAND writing block [03440400], size 0x20000 000004AC |CMT NAND writing block [03460400], size 0x20000 000004AC |CMT NAND writing block [03480400], size 0x20000 000004AC |CMT NAND writing block [034A0400], size 0x20000 000004AC |CMT NAND writing block [034C0400], size 0x20000 000004AC |CMT NAND writing block [034E0400], size 0x20000 000004AC |CMT NAND writing block [03500400], size 0x20000 000004AC |CMT NAND writing block [03520400], size 0x20000 000004AC |CMT NAND writing block [03540400], size 0x20000 000004AC |CMT NAND writing block [03560400], size 0x20000 000004AC |CMT NAND writing block [03580400], size 0x20000 000004AC |CMT NAND writing block [035A0400], size 0x20000 000004AC |CMT NAND writing block [035C0400], size 0x20000 000004AC |CMT NAND writing block [035E0400], size 0x20000 000004AC |CMT NAND writing block [03600400], size 0x20000 000004AC |CMT NAND writing block [03620400], size 0x20000 000004AC |CMT NAND writing block [03640400], size 0x20000 000004AC |CMT NAND writing block [03660400], size 0x20000 000004AC |CMT NAND writing block [03680400], size 0x20000 000004AC |CMT NAND writing block [036A0400], size 0x20000 000004AC |CMT NAND writing block [036C0400], size 0x20000 000004AC |CMT NAND writing block [036E0400], size 0x20000 000004AC |CMT NAND writing block [03700400], size 0x20000 000004AC |CMT NAND writing block [03720400], size 0x20000 000004AC |CMT NAND writing block [03740400], size 0x20000 000004AC |CMT NAND writing block [03760400], size 0x20000 000004AC |CMT NAND writing block [03780400], size 0x20000 000004AC |CMT NAND writing block [037A0400], size 0x20000 000004AC |CMT NAND writing block [037C0400], size 0x20000 000004AC |CMT NAND writing block [037E0400], size 0x20000 000004AC |CMT NAND writing block [03800400], size 0x20000 000004AC |CMT NAND writing block [03820400], size 0x20000 000004AC |CMT NAND writing block [03840400], size 0x20000 000004AC |CMT NAND writing block [03860400], size 0x20000 000004AC |CMT NAND writing block [03880400], size 0x20000 000004AC |CMT NAND writing block [038A0400], size 0x20000 000004AC |CMT NAND writing block [038C0400], size 0x20000 000004AC |CMT NAND writing block [038E0400], size 0x20000 000004AC |CMT NAND writing block [03900400], size 0x20000 000004AC |CMT NAND writing block [03920400], size 0x20000 000004AC |CMT NAND writing block [03940400], size 0x20000 000004AC |CMT NAND writing block [03960400], size 0x20000 000004AC |CMT NAND writing block [03980400], size 0x20000 000004AC |CMT NAND writing block [039A0400], size 0x20000 000004AC |CMT NAND writing block [039C0400], size 0x20000 000004AC |CMT NAND writing block [039E0400], size 0x20000 000004AC |CMT NAND writing block [03A00400], size 0x20000 000004AC |CMT NAND writing block [03A20400], size 0x20000 000004AC |CMT NAND writing block [03A40400], size 0x20000 000004AC |CMT NAND writing block [03A60400], size 0x20000 000004AC |CMT NAND writing block [03A80400], size 0x20000 000004AC |CMT NAND writing block [03AA0400], size 0x20000 000004AC |CMT NAND writing block [03AC0400], size 0x20000 000004AC |CMT NAND writing block [03AE0400], size 0x20000 000004AC |CMT NAND writing block [03B00400], size 0x20000 000004AC |CMT NAND writing block [03B20400], size 0x20000 000004AC |CMT NAND writing block [03B40400], size 0x20000 000004AC |CMT NAND writing block [03B60400], size 0x20000 000004AC |CMT NAND writing block [03B80400], size 0x20000 000004AC |CMT NAND writing block [03BA0400], size 0x20000 000004AC |CMT NAND writing block [03BC0400], size 0x20000 000004AC |CMT NAND writing block [03BE0400], size 0x20000 000004AC |CMT NAND writing block [03C00400], size 0x20000 000004AC |CMT NAND writing block [03C20400], size 0x20000 000004AC |CMT NAND writing block [03C40400], size 0x20000 000004AC |CMT NAND writing block [03C60400], size 0x20000 000004AC |CMT NAND writing block [03C80400], size 0x20000 000004AC |CMT NAND writing block [03CA0400], size 0x20000 000004AC |CMT NAND writing block [03CC0400], size 0x20000 000004AC |CMT NAND writing block [03CE0400], size 0x20000 000004AC |CMT NAND writing block [03D00400], size 0x20000 000004AC |CMT NAND writing block [03D20400], size 0x20000 000004AC |CMT NAND writing block [03D40400], size 0x20000 000004AC |CMT NAND writing block [03D60400], size 0x20000 000004AC |CMT NAND writing block [03D80400], size 0x20000 000004AC |CMT NAND writing block [03DA0400], size 0x20000 000004AC |CMT NAND writing block [03DC0400], size 0x20000 000004AC |CMT NAND writing block [03DE0400], size 0x20000 000004AC |CMT NAND writing block [03E00400], size 0x20000 000004AC |CMT NAND writing block [03E20400], size 0x20000 000004AC |CMT NAND writing block [03E40400], size 0x20000 000004AC |CMT NAND writing block [03E60400], size 0x20000 000004AC |CMT NAND writing block [03E80400], size 0x20000 000004AC |CMT NAND writing block [03EA0400], size 0x20000 000004AC |CMT NAND writing block [03EC0400], size 0x20000 000004AC |CMT NAND writing block [03EE0400], size 0x20000 000004AC |CMT NAND writing block [03F00400], size 0x20000 000004AC |CMT NAND writing block [03F20400], size 0x20000 000004AC |CMT NAND writing block [03F40400], size 0x20000 000004AC |CMT NAND writing block [03F60400], size 0x20000 000004AC |CMT NAND writing block [03F80400], size 0x20000 000004AC |CMT NAND writing block [03FA0400], size 0x20000 000004AC |CMT NAND writing block [03FC0400], size 0x20000 000004AC |CMT NAND writing block [03FE0400], size 0x20000 000004AC |CMT NAND writing block [04000400], size 0x20000 000004AC |CMT NAND writing block [04020400], size 0x20000 000004AC |CMT NAND writing block [04040400], size 0x20000 000004AC |CMT NAND writing block [04060400], size 0x20000 000004AC |CMT NAND writing block [04080400], size 0x20000 000004AC |CMT NAND writing block [040A0400], size 0x20000 000004AC |CMT NAND writing block [040C0400], size 0x20000 000004AC |CMT NAND writing block [040E0400], size 0x20000 000004AC |CMT NAND writing block [04100400], size 0x20000 000004AC |CMT NAND writing block [04120400], size 0x20000 000004AC |CMT NAND writing block [04140400], size 0x20000 000004AC |CMT NAND writing block [04160400], size 0x20000 000004AC |CMT NAND writing block [04180400], size 0x20000 000004AC |CMT NAND writing block [041A0400], size 0x20000 000004AC |CMT NAND writing block [041C0400], size 0x20000 000004AC |CMT NAND writing block [041E0400], size 0x20000 000004AC |CMT NAND writing block [04200400], size 0x20000 000004AC |CMT NAND writing block [04220400], size 0x20000 000004AC |CMT NAND writing block [04240400], size 0x20000 000004AC |CMT NAND writing block [04260400], size 0x20000 000004AC |CMT NAND writing block [04280400], size 0x20000 000004AC |CMT NAND writing block [042A0400], size 0x20000 000004AC |CMT NAND writing block [042C0400], size 0x20000 000004AC |CMT NAND writing block [042E0400], size 0x20000 000004AC |CMT NAND writing block [04300400], size 0x20000 000004AC |CMT NAND writing block [04320400], size 0x20000 000004AC |CMT NAND writing block [04340400], size 0x20000 000004AC |CMT NAND writing block [04360400], size 0x20000 000004AC |CMT NAND writing block [04380400], size 0x20000 000004AC |CMT NAND writing block [043A0400], size 0x20000 000004AC |CMT NAND writing block [043C0400], size 0x20000 000004AC |CMT NAND writing block [043E0400], size 0x20000 000004AC |CMT NAND writing block [04400400], size 0x20000 000004AC |CMT NAND writing block [04420400], size 0x20000 000004AC |CMT NAND writing block [04440400], size 0x20000 000004AC |CMT NAND writing block [04460400], size 0x20000 000004AC |CMT NAND writing block [04480400], size 0x20000 000004AC |CMT NAND writing block [044A0400], size 0x20000 000004AC |CMT NAND writing block [044C0400], size 0x20000 000004AC |CMT NAND writing block [044E0400], size 0x20000 000004AC |CMT NAND writing block [04500400], size 0x20000 000004AC |CMT NAND writing block [04520400], size 0x20000 000004AC |CMT NAND writing block [04540400], size 0x20000 000004AC |CMT NAND writing block [04560400], size 0x20000 000004AC |CMT NAND writing block [04580400], size 0x20000 000004AC |CMT NAND writing block [045A0400], size 0x20000 000004AC |CMT NAND writing block [045C0400], size 0x20000 000004AC |CMT NAND writing block [045E0400], size 0x20000 000004AC |CMT NAND writing block [04600400], size 0x20000 000004AC |CMT NAND writing block [04620400], size 0x20000 000004AC |CMT NAND writing block [04640400], size 0x20000 000004AC |CMT NAND writing block [04660400], size 0x20000 000004AC |CMT NAND writing block [04680400], size 0x20000 000004AC |CMT NAND writing block [046A0400], size 0x20000 000004AC |CMT NAND writing block [046C0400], size 0x20000 000004AC |CMT NAND writing block [046E0400], size 0x20000 000004AC |CMT NAND writing block [04700400], size 0x20000 000004AC |CMT NAND writing block [04720400], size 0x20000 000004AC |CMT NAND writing block [04740400], size 0x20000 000004AC |CMT NAND writing block [04760400], size 0x20000 000004AC |CMT NAND writing block [04780400], size 0x20000 000004AC |CMT NAND writing block [047A0400], size 0x20000 000004AC |CMT NAND writing block [047C0400], size 0x20000 000004AC |CMT NAND writing block [047E0400], size 0x20000 000004AC |CMT NAND writing block [04800400], size 0x20000 000004AC |CMT NAND writing block [04820400], size 0x20000 000004AC |CMT NAND writing block [04840400], size 0x20000 000004AC |CMT NAND writing block [04860400], size 0x20000 000004AC |CMT NAND writing block [04880400], size 0x20000 000004AC |CMT NAND writing block [048A0400], size 0x20000 000004AC |CMT NAND writing block [048C0400], size 0x20000 000004AC |CMT NAND writing block [048E0400], size 0x20000 000004AC |CMT NAND writing block [04900400], size 0x20000 000004AC |CMT NAND writing block [04920400], size 0x20000 000004AC |CMT NAND writing block [04940400], size 0x20000 000004AC |CMT NAND writing block [04960400], size 0x20000 000004AC |CMT NAND writing block [04980400], size 0x20000 000004AC |CMT NAND writing block [049A0400], size 0x20000 000004AC |CMT NAND writing block [049C0400], size 0x20000 000004AC |CMT NAND writing block [049E0400], size 0xEC00 000004AC |Programming completed. 000004AC |Processing file: #rm346_510.21.009_prd.v26 000004AC |HdrSize: 0x169 000004AC |Sector to Erase: 000004AC |BeginEraseFlash: 2 000004AC |> RAP NAND device. 000004AC |#CMT : 1 sector(s) CMT FLASH,MuxOneNAND area #[05420000-0759FFFF] 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |#CMT : 1 sector(s) CMT FLASH,MuxOneNAND area #[05420000-0759FFFF] 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |Erase complete. 000004AC |Begin flash programming: C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-346\rm346_510.21.009_prd.v26 000004AC |fileSize: 0x1FF5A74 000004AC |availMem: 0x4F15E000 000004AC |[WriteBlock] Handling file with huge size 000004AC |Master ASIC set to CMT 000004AC |CMT NAND writing block [05420400], size 0x20000 000004AC |CMT NAND writing block [05440400], size 0x20000 000004AC |CMT NAND writing block [05460400], size 0x20000 000004AC |CMT NAND writing block [05480400], size 0x20000 000004AC |CMT NAND writing block [054A0400], size 0x20000 000004AC |CMT NAND writing block [054C0400], size 0x20000 000004AC |CMT NAND writing block [054E0400], size 0x20000 000004AC |CMT NAND writing block [05500400], size 0x20000 000004AC |CMT NAND writing block [05520400], size 0x20000 000004AC |CMT NAND writing block [05540400], size 0x20000 000004AC |CMT NAND writing block [05560400], size 0x20000 000004AC |CMT NAND writing block [05580400], size 0x20000 000004AC |CMT NAND writing block [055A0400], size 0x20000 000004AC |CMT NAND writing block [055C0400], size 0x20000 000004AC |CMT NAND writing block [055E0400], size 0x20000 000004AC |CMT NAND writing block [05600400], size 0x20000 000004AC |CMT NAND writing block [05620400], size 0x20000 000004AC |CMT NAND writing block [05640400], size 0x20000 000004AC |CMT NAND writing block [05660400], size 0x20000 000004AC |CMT NAND writing block [05680400], size 0x20000 000004AC |CMT NAND writing block [056A0400], size 0x20000 000004AC |CMT NAND writing block [056C0400], size 0x20000 000004AC |CMT NAND writing block [056E0400], size 0x20000 000004AC |CMT NAND writing block [05700400], size 0x20000 000004AC |CMT NAND writing block [05720400], size 0x20000 000004AC |CMT NAND writing block [05740400], size 0x20000 000004AC |CMT NAND writing block [05760400], size 0x20000 000004AC |CMT NAND writing block [05780400], size 0x20000 000004AC |CMT NAND writing block [057A0400], size 0x20000 000004AC |CMT NAND writing block [057C0400], size 0x20000 000004AC |CMT NAND writing block [057E0400], size 0x20000 000004AC |CMT NAND writing block [05800400], size 0x20000 000004AC |CMT NAND writing block [05820400], size 0x20000 000004AC |CMT NAND writing block [05840400], size 0x20000 000004AC |CMT NAND writing block [05860400], size 0x20000 000004AC |CMT NAND writing block [05880400], size 0x20000 000004AC |CMT NAND writing block [058A0400], size 0x20000 000004AC |CMT NAND writing block [058C0400], size 0x20000 000004AC |CMT NAND writing block [058E0400], size 0x20000 000004AC |CMT NAND writing block [05900400], size 0x20000 000004AC |CMT NAND writing block [05920400], size 0x20000 000004AC |CMT NAND writing block [05940400], size 0x20000 000004AC |CMT NAND writing block [05960400], size 0x20000 000004AC |CMT NAND writing block [05980400], size 0x20000 000004AC |CMT NAND writing block [059A0400], size 0x20000 000004AC |CMT NAND writing block [059C0400], size 0x20000 000004AC |CMT NAND writing block [059E0400], size 0x20000 000004AC |CMT NAND writing block [05A00400], size 0x20000 000004AC |CMT NAND writing block [05A20400], size 0x20000 000004AC |CMT NAND writing block [05A40400], size 0x20000 000004AC |CMT NAND writing block [05A60400], size 0x20000 000004AC |CMT NAND writing block [05A80400], size 0x20000 000004AC |CMT NAND writing block [05AA0400], size 0x20000 000004AC |CMT NAND writing block [05AC0400], size 0x20000 000004AC |CMT NAND writing block [05AE0400], size 0x20000 000004AC |CMT NAND writing block [05B00400], size 0x20000 000004AC |CMT NAND writing block [05B20400], size 0x20000 000004AC |CMT NAND writing block [05B40400], size 0x20000 000004AC |CMT NAND writing block [05B60400], size 0x20000 000004AC |CMT NAND writing block [05B80400], size 0x20000 000004AC |CMT NAND writing block [05BA0400], size 0x20000 000004AC |CMT NAND writing block [05BC0400], size 0x20000 000004AC |CMT NAND writing block [05BE0400], size 0x20000 000004AC |CMT NAND writing block [05C00400], size 0x20000 000004AC |CMT NAND writing block [05C20400], size 0x20000 000004AC |CMT NAND writing block [05C40400], size 0x20000 000004AC |CMT NAND writing block [05C60400], size 0x20000 000004AC |CMT NAND writing block [05C80400], size 0x20000 000004AC |CMT NAND writing block [05CA0400], size 0x20000 000004AC |CMT NAND writing block [05CC0400], size 0x20000 000004AC |CMT NAND writing block [05CE0400], size 0x20000 000004AC |CMT NAND writing block [05D00400], size 0x20000 000004AC |CMT NAND writing block [05D20400], size 0x20000 000004AC |CMT NAND writing block [05D40400], size 0x20000 000004AC |CMT NAND writing block [05D60400], size 0x20000 000004AC |CMT NAND writing block [05D80400], size 0x20000 000004AC |CMT NAND writing block [05DA0400], size 0x20000 000004AC |CMT NAND writing block [05DC0400], size 0x20000 000004AC |CMT NAND writing block [05DE0400], size 0x20000 000004AC |CMT NAND writing block [05E00400], size 0x20000 000004AC |CMT NAND writing block [05E20400], size 0x20000 000004AC |CMT NAND writing block [05E40400], size 0x20000 000004AC |CMT NAND writing block [05E60400], size 0x20000 000004AC |CMT NAND writing block [05E80400], size 0x20000 000004AC |CMT NAND writing block [05EA0400], size 0x20000 000004AC |CMT NAND writing block [05EC0400], size 0x20000 000004AC |CMT NAND writing block [05EE0400], size 0x20000 000004AC |CMT NAND writing block [05F00400], size 0x20000 000004AC |CMT NAND writing block [05F20400], size 0x20000 000004AC |CMT NAND writing block [05F40400], size 0x20000 000004AC |CMT NAND writing block [05F60400], size 0x20000 000004AC |CMT NAND writing block [05F80400], size 0x20000 000004AC |CMT NAND writing block [05FA0400], size 0x20000 000004AC |CMT NAND writing block [05FC0400], size 0x20000 000004AC |CMT NAND writing block [05FE0400], size 0x20000 000004AC |CMT NAND writing block [06000400], size 0x20000 000004AC |CMT NAND writing block [06020400], size 0x20000 000004AC |CMT NAND writing block [06040400], size 0x20000 000004AC |CMT NAND writing block [06060400], size 0x20000 000004AC |CMT NAND writing block [06080400], size 0x20000 000004AC |CMT NAND writing block [060A0400], size 0x20000 000004AC |CMT NAND writing block [060C0400], size 0x20000 000004AC |CMT NAND writing block [060E0400], size 0x20000 000004AC |CMT NAND writing block [06100400], size 0x20000 000004AC |CMT NAND writing block [06120400], size 0x20000 000004AC |CMT NAND writing block [06140400], size 0x20000 000004AC |CMT NAND writing block [06160400], size 0x20000 000004AC |CMT NAND writing block [06180400], size 0x20000 000004AC |CMT NAND writing block [061A0400], size 0x20000 000004AC |CMT NAND writing block [061C0400], size 0x20000 000004AC |CMT NAND writing block [061E0400], size 0x20000 000004AC |CMT NAND writing block [06200400], size 0x20000 000004AC |CMT NAND writing block [06220400], size 0x20000 000004AC |CMT NAND writing block [06240400], size 0x20000 000004AC |CMT NAND writing block [06260400], size 0x20000 000004AC |CMT NAND writing block [06280400], size 0x20000 000004AC |CMT NAND writing block [062A0400], size 0x20000 000004AC |CMT NAND writing block [062C0400], size 0x20000 000004AC |CMT NAND writing block [062E0400], size 0x20000 000004AC |CMT NAND writing block [06300400], size 0x20000 000004AC |CMT NAND writing block [06320400], size 0x20000 000004AC |CMT NAND writing block [06340400], size 0x20000 000004AC |CMT NAND writing block [06360400], size 0x20000 000004AC |CMT NAND writing block [06380400], size 0x20000 000004AC |CMT NAND writing block [063A0400], size 0x20000 000004AC |CMT NAND writing block [063C0400], size 0x20000 000004AC |CMT NAND writing block [063E0400], size 0x20000 000004AC |CMT NAND writing block [06400400], size 0x20000 000004AC |CMT NAND writing block [06420400], size 0x20000 000004AC |CMT NAND writing block [06440400], size 0x20000 000004AC |CMT NAND writing block [06460400], size 0x20000 000004AC |CMT NAND writing block [06480400], size 0x20000 000004AC |CMT NAND writing block [064A0400], size 0x20000 000004AC |CMT NAND writing block [064C0400], size 0x20000 000004AC |CMT NAND writing block [064E0400], size 0x20000 000004AC |CMT NAND writing block [06500400], size 0x20000 000004AC |CMT NAND writing block [06520400], size 0x20000 000004AC |CMT NAND writing block [06540400], size 0x20000 000004AC |CMT NAND writing block [06560400], size 0x20000 000004AC |CMT NAND writing block [06580400], size 0x20000 000004AC |CMT NAND writing block [065A0400], size 0x20000 000004AC |CMT NAND writing block [065C0400], size 0x20000 000004AC |CMT NAND writing block [065E0400], size 0x20000 000004AC |CMT NAND writing block [06600400], size 0x20000 000004AC |CMT NAND writing block [06620400], size 0x20000 000004AC |CMT NAND writing block [06640400], size 0x20000 000004AC |CMT NAND writing block [06660400], size 0x20000 000004AC |CMT NAND writing block [06680400], size 0x20000 000004AC |CMT NAND writing block [066A0400], size 0x20000 000004AC |CMT NAND writing block [066C0400], size 0x20000 000004AC |CMT NAND writing block [066E0400], size 0x20000 000004AC |CMT NAND writing block [06700400], size 0x20000 000004AC |CMT NAND writing block [06720400], size 0x20000 000004AC |CMT NAND writing block [06740400], size 0x20000 000004AC |CMT NAND writing block [06760400], size 0x20000 000004AC |CMT NAND writing block [06780400], size 0x20000 000004AC |CMT NAND writing block [067A0400], size 0x20000 000004AC |CMT NAND writing block [067C0400], size 0x20000 000004AC |CMT NAND writing block [067E0400], size 0x20000 000004AC |CMT NAND writing block [06800400], size 0x20000 000004AC |CMT NAND writing block [06820400], size 0x20000 000004AC |CMT NAND writing block [06840400], size 0x20000 000004AC |CMT NAND writing block [06860400], size 0x20000 000004AC |CMT NAND writing block [06880400], size 0x20000 000004AC |CMT NAND writing block [068A0400], size 0x20000 000004AC |CMT NAND writing block [068C0400], size 0x20000 000004AC |CMT NAND writing block [068E0400], size 0x20000 000004AC |CMT NAND writing block [06900400], size 0x20000 000004AC |CMT NAND writing block [06920400], size 0x20000 000004AC |CMT NAND writing block [06940400], size 0x20000 000004AC |CMT NAND writing block [06960400], size 0x20000 000004AC |CMT NAND writing block [06980400], size 0x20000 000004AC |CMT NAND writing block [069A0400], size 0x20000 000004AC |CMT NAND writing block [069C0400], size 0x20000 000004AC |CMT NAND writing block [069E0400], size 0x20000 000004AC |CMT NAND writing block [06A00400], size 0x20000 000004AC |CMT NAND writing block [06A20400], size 0x20000 000004AC |CMT NAND writing block [06A40400], size 0x20000 000004AC |CMT NAND writing block [06A60400], size 0x20000 000004AC |CMT NAND writing block [06A80400], size 0x20000 000004AC |CMT NAND writing block [06AA0400], size 0x20000 000004AC |CMT NAND writing block [06AC0400], size 0x20000 000004AC |CMT NAND writing block [06AE0400], size 0x20000 000004AC |CMT NAND writing block [06B00400], size 0x20000 000004AC |CMT NAND writing block [06B20400], size 0x20000 000004AC |CMT NAND writing block [06B40400], size 0x20000 000004AC |CMT NAND writing block [06B60400], size 0x20000 000004AC |CMT NAND writing block [06B80400], size 0x20000 000004AC |CMT NAND writing block [06BA0400], size 0x20000 000004AC |CMT NAND writing block [06BC0400], size 0x20000 000004AC |CMT NAND writing block [06BE0400], size 0x20000 000004AC |CMT NAND writing block [06C00400], size 0x20000 000004AC |CMT NAND writing block [06C20400], size 0x20000 000004AC |CMT NAND writing block [06C40400], size 0x20000 000004AC |CMT NAND writing block [06C60400], size 0x20000 000004AC |CMT NAND writing block [06C80400], size 0x20000 000004AC |CMT NAND writing block [06CA0400], size 0x20000 000004AC |CMT NAND writing block [06CC0400], size 0x20000 000004AC |CMT NAND writing block [06CE0400], size 0x20000 000004AC |CMT NAND writing block [06D00400], size 0x20000 000004AC |CMT NAND writing block [06D20400], size 0x20000 000004AC |CMT NAND writing block [06D40400], size 0x20000 000004AC |CMT NAND writing block [06D60400], size 0x20000 000004AC |CMT NAND writing block [06D80400], size 0x20000 000004AC |CMT NAND writing block [06DA0400], size 0x20000 000004AC |CMT NAND writing block [06DC0400], size 0x20000 000004AC |CMT NAND writing block [06DE0400], size 0x20000 000004AC |CMT NAND writing block [06E00400], size 0x20000 000004AC |CMT NAND writing block [06E20400], size 0x20000 000004AC |CMT NAND writing block [06E40400], size 0x20000 000004AC |CMT NAND writing block [06E60400], size 0x20000 000004AC |CMT NAND writing block [06E80400], size 0x20000 000004AC |CMT NAND writing block [06EA0400], size 0x20000 000004AC |CMT NAND writing block [06EC0400], size 0x20000 000004AC |CMT NAND writing block [06EE0400], size 0x20000 000004AC |CMT NAND writing block [06F00400], size 0x20000 000004AC |CMT NAND writing block [06F20400], size 0x15800 000004AC |CMT NAND writing block [00000000], size 0x20000 000004AC |CMT NAND writing block [00020000], size 0x20000 000004AC |CMT NAND writing block [00040000], size 0x20000 000004AC |CMT NAND writing block [00060000], size 0x20000 000004AC |CMT NAND writing block [00080000], size 0x20000 000004AC |CMT NAND writing block [000A0000], size 0x20000 000004AC |CMT NAND writing block [000C0000], size 0x20000 000004AC |CMT NAND writing block [000E0000], size 0x20000 000004AC |CMT NAND writing block [00100000], size 0x20000 000004AC |CMT NAND writing block [00120000], size 0x20000 000004AC |CMT NAND writing block [00140000], size 0x20000 000004AC |CMT NAND writing block [00160000], size 0x20000 000004AC |CMT NAND writing block [00180000], size 0x20000 000004AC |CMT NAND writing block [001A0000], size 0x20000 000004AC |CMT NAND writing block [001C0000], size 0x20000 000004AC |CMT NAND writing block [001E0000], size 0x20000 000004AC |CMT NAND writing block [00200000], size 0x20000 000004AC |CMT NAND writing block [00220000], size 0x20000 000004AC |CMT NAND writing block [00240000], size 0x20000 000004AC |CMT NAND writing block [00260000], size 0x20000 000004AC |CMT NAND writing block [00280000], size 0x20000 000004AC |CMT NAND writing block [002A0000], size 0x20000 000004AC |CMT NAND writing block [002C0000], size 0x20000 000004AC |CMT NAND writing block [002E0000], size 0x20000 000004AC |CMT NAND writing block [00300000], size 0x20000 000004AC |CMT NAND writing block [00320000], size 0x20000 000004AC |CMT NAND writing block [00340000], size 0x20000 000004AC |CMT NAND writing block [00360000], size 0x20000 000004AC |CMT NAND writing block [00380000], size 0x20000 000004AC |CMT NAND writing block [003A0000], size 0x20000 000004AC |CMT NAND writing block [003C0000], size 0x20000 000004AC |CMT NAND writing block [003E0000], size 0x20000 000004AC |CMT NAND writing block [00400000], size 0x20000 000004AC |CMT NAND writing block [00420000], size 0x20000 000004AC |CMT NAND writing block [00440000], size 0x20000 000004AC |CMT NAND writing block [00460000], size 0x20000 000004AC |CMT NAND writing block [00480000], size 0x20000 000004AC |CMT NAND writing block [004A0000], size 0x20000 000004AC |CMT NAND writing block [004C0000], size 0x1D800 000004AC |Programming completed. 000004AC |Processing file: #leevi_erase_y_drive.fpsx 000004AC |HdrSize: 0xF4 000004AC |Sector to Erase: 000004AC |BeginEraseFlash: 2 000004AC |> RAP NAND device. 000004AC |#CMT : 1 sector(s) CMT FLASH,MuxOneNAND area #[0F020000-0F1BFFFF] 000004AC |#CMT : 1 sector(s) CMT FLASH,MuxOneNAND area #[0F020000-0F1BFFFF] 000004AC |Erase complete. 000004AC |Begin flash programming: C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-346\leevi_erase_y_drive.fpsx 000004AC |fileSize: 0xF4 000004AC |availMem: 0x4F15E000 000004AC |[WriteBlock] Handling file with huge size 000004AC |Master ASIC set to CMT 000004AC |Programming completed. 000004AC |Processing file: #rm346_510.21.009.03U 000004AC |HdrSize: 0x122 000004AC |Sector to Erase: 000004AC |BeginEraseFlash: 2 000004AC |> RAP NAND device. 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |#CMT : 1 sector(s) Format Partition(NAND) 000004AC |Erase complete. 000004AC |Begin flash programming: C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-346\rm346_510.21.009.03U 000004AC |fileSize: 0x168C384 000004AC |availMem: 0x4F15E000 000004AC |[WriteBlock] Handling file with huge size 000004AC |Master ASIC set to CMT 000004AC |CMT NAND writing block [00000000], size 0x20000 000004AC |CMT NAND writing block [00020000], size 0x20000 000004AC |CMT NAND writing block [00040000], size 0x20000 000004AC |CMT NAND writing block [00060000], size 0x20000 000004AC |CMT NAND writing block [00080000], size 0x20000 000004AC |CMT NAND writing block [000A0000], size 0x20000 000004AC |CMT NAND writing block [000C0000], size 0x20000 000004AC |CMT NAND writing block [000E0000], size 0x20000 000004AC |CMT NAND writing block [00100000], size 0x20000 000004AC |CMT NAND writing block [00120000], size 0x20000 000004AC |CMT NAND writing block [00140000], size 0x20000 000004AC |CMT NAND writing block [00160000], size 0x20000 000004AC |CMT NAND writing block [00180000], size 0x20000 000004AC |CMT NAND writing block [001A0000], size 0x20000 000004AC |CMT NAND writing block [001C0000], size 0x20000 000004AC |CMT NAND writing block [001E0000], size 0x20000 000004AC |CMT NAND writing block [00200000], size 0x20000 000004AC |CMT NAND writing block [00220000], size 0x20000 000004AC |CMT NAND writing block [00240000], size 0x20000 000004AC |CMT NAND writing block [00260000], size 0x20000 000004AC |CMT NAND writing block [00280000], size 0x20000 000004AC |CMT NAND writing block [002A0000], size 0x20000 000004AC |CMT NAND writing block [002C0000], size 0x20000 000004AC |CMT NAND writing block [002E0000], size 0x20000 000004AC |CMT NAND writing block [00300000], size 0x20000 000004AC |CMT NAND writing block [00320000], size 0x20000 000004AC |CMT NAND writing block [00340000], size 0x20000 000004AC |CMT NAND writing block [00360000], size 0x20000 000004AC |CMT NAND writing block [00380000], size 0x20000 000004AC |CMT NAND writing block [003A0000], size 0x20000 000004AC |CMT NAND writing block [003C0000], size 0x20000 000004AC |CMT NAND writing block [003E0000], size 0x20000 000004AC |CMT NAND writing block [00400000], size 0x20000 000004AC |CMT NAND writing block [00420000], size 0x20000 000004AC |CMT NAND writing block [00440000], size 0x20000 000004AC |CMT NAND writing block [00460000], size 0x20000 000004AC |CMT NAND writing block [00480000], size 0x20000 000004AC |CMT NAND writing block [004A0000], size 0x20000 000004AC |CMT NAND writing block [004C0000], size 0x20000 000004AC |CMT NAND writing block [004E0000], size 0x20000 000004AC |CMT NAND writing block [00500000], size 0x20000 000004AC |CMT NAND writing block [00520000], size 0x20000 000004AC |CMT NAND writing block [00540000], size 0x20000 000004AC |CMT NAND writing block [00560000], size 0x20000 000004AC |CMT NAND writing block [00580000], size 0x20000 000004AC |CMT NAND writing block [005A0000], size 0x20000 000004AC |CMT NAND writing block [005C0000], size 0x20000 000004AC |CMT NAND writing block [005E0000], size 0x20000 000004AC |CMT NAND writing block [00600000], size 0x20000 000004AC |CMT NAND writing block [00620000], size 0x20000 000004AC |CMT NAND writing block [00640000], size 0x20000 000004AC |CMT NAND writing block [00660000], size 0x20000 000004AC |CMT NAND writing block [00680000], size 0x20000 000004AC |CMT NAND writing block [006A0000], size 0x20000 000004AC |CMT NAND writing block [006C0000], size 0x20000 000004AC |CMT NAND writing block [006E0000], size 0x20000 000004AC |CMT NAND writing block [00700000], size 0x20000 000004AC |CMT NAND writing block [00720000], size 0x20000 000004AC |CMT NAND writing block [00740000], size 0x20000 000004AC |CMT NAND writing block [00760000], size 0x20000 000004AC |CMT NAND writing block [00780000], size 0x20000 000004AC |CMT NAND writing block [007A0000], size 0x20000 000004AC |CMT NAND writing block [007C0000], size 0x20000 000004AC |CMT NAND writing block [007E0000], size 0x20000 000004AC |CMT NAND writing block [00800000], size 0x20000 000004AC |CMT NAND writing block [00820000], size 0x20000 000004AC |CMT NAND writing block [00840000], size 0x20000 000004AC |CMT NAND writing block [00860000], size 0x20000 000004AC |CMT NAND writing block [00880000], size 0x20000 000004AC |CMT NAND writing block [008A0000], size 0x20000 000004AC |CMT NAND writing block [008C0000], size 0x20000 000004AC |CMT NAND writing block [008E0000], size 0x20000 000004AC |CMT NAND writing block [00900000], size 0x20000 000004AC |CMT NAND writing block [00920000], size 0x20000 000004AC |CMT NAND writing block [00940000], size 0x20000 000004AC |CMT NAND writing block [00960000], size 0x20000 000004AC |CMT NAND writing block [00980000], size 0x20000 000004AC |CMT NAND writing block [009A0000], size 0x20000 000004AC |CMT NAND writing block [009C0000], size 0x20000 000004AC |CMT NAND writing block [009E0000], size 0x20000 000004AC |CMT NAND writing block [00A00000], size 0x20000 000004AC |CMT NAND writing block [00A20000], size 0x20000 000004AC |CMT NAND writing block [00A40000], size 0x20000 000004AC |CMT NAND writing block [00A60000], size 0x20000 000004AC |CMT NAND writing block [00A80000], size 0x20000 000004AC |CMT NAND writing block [00AA0000], size 0x20000 000004AC |CMT NAND writing block [00AC0000], size 0x20000 000004AC |CMT NAND writing block [00AE0000], size 0x20000 000004AC |CMT NAND writing block [00B00000], size 0x20000 000004AC |CMT NAND writing block [00B20000], size 0x20000 000004AC |CMT NAND writing block [00B40000], size 0x20000 000004AC |CMT NAND writing block [00B60000], size 0x20000 000004AC |CMT NAND writing block [00B80000], size 0x20000 000004AC |CMT NAND writing block [00BA0000], size 0x20000 000004AC |CMT NAND writing block [00BC0000], size 0x20000 000004AC |CMT NAND writing block [00BE0000], size 0x20000 000004AC |CMT NAND writing block [00C00000], size 0x20000 000004AC |CMT NAND writing block [00C20000], size 0x20000 000004AC |CMT NAND writing block [00C40000], size 0x20000 000004AC |CMT NAND writing block [00C60000], size 0x20000 000004AC |CMT NAND writing block [00C80000], size 0x20000 000004AC |CMT NAND writing block [00CA0000], size 0x20000 000004AC |CMT NAND writing block [00CC0000], size 0x20000 000004AC |CMT NAND writing block [00CE0000], size 0x20000 000004AC |CMT NAND writing block [00D00000], size 0x20000 000004AC |CMT NAND writing block [00D20000], size 0x20000 000004AC |CMT NAND writing block [00D40000], size 0x20000 000004AC |CMT NAND writing block [00D60000], size 0x20000 000004AC |CMT NAND writing block [00D80000], size 0x20000 000004AC |CMT NAND writing block [00DA0000], size 0x20000 000004AC |CMT NAND writing block [00DC0000], size 0x20000 000004AC |CMT NAND writing block [00DE0000], size 0x20000 000004AC |CMT NAND writing block [00E00000], size 0x20000 000004AC |CMT NAND writing block [00E20000], size 0x20000 000004AC |CMT NAND writing block [00E40000], size 0x20000 000004AC |CMT NAND writing block [00E60000], size 0x20000 000004AC |CMT NAND writing block [00E80000], size 0x20000 000004AC |CMT NAND writing block [00EA0000], size 0x20000 000004AC |CMT NAND writing block [00EC0000], size 0x20000 000004AC |CMT NAND writing block [00EE0000], size 0x20000 000004AC |CMT NAND writing block [00F00000], size 0x20000 000004AC |CMT NAND writing block [00F20000], size 0x20000 000004AC |CMT NAND writing block [00F40000], size 0x20000 000004AC |CMT NAND writing block [00F60000], size 0x20000 000004AC |CMT NAND writing block [00F80000], size 0x20000 000004AC |CMT NAND writing block [00FA0000], size 0x20000 000004AC |CMT NAND writing block [00FC0000], size 0x20000 000004AC |CMT NAND writing block [00FE0000], size 0x20000 000004AC |CMT NAND writing block [01000000], size 0x20000 000004AC |CMT NAND writing block [01020000], size 0x20000 000004AC |CMT NAND writing block [01040000], size 0x20000 000004AC |CMT NAND writing block [01060000], size 0x20000 000004AC |CMT NAND writing block [01080000], size 0x20000 000004AC |CMT NAND writing block [010A0000], size 0x20000 000004AC |CMT NAND writing block [010C0000], size 0x20000 000004AC |CMT NAND writing block [010E0000], size 0x20000 000004AC |CMT NAND writing block [01100000], size 0x20000 000004AC |CMT NAND writing block [01120000], size 0x20000 000004AC |CMT NAND writing block [01140000], size 0x20000 000004AC |CMT NAND writing block [01160000], size 0x20000 000004AC |CMT NAND writing block [01180000], size 0x20000 000004AC |CMT NAND writing block [011A0000], size 0x20000 000004AC |CMT NAND writing block [011C0000], size 0x20000 000004AC |CMT NAND writing block [011E0000], size 0x20000 000004AC |CMT NAND writing block [01200000], size 0x20000 000004AC |CMT NAND writing block [01220000], size 0x20000 000004AC |CMT NAND writing block [01240000], size 0x20000 000004AC |CMT NAND writing block [01260000], size 0x20000 000004AC |CMT NAND writing block [01280000], size 0x20000 000004AC |CMT NAND writing block [012A0000], size 0x20000 000004AC |CMT NAND writing block [012C0000], size 0x20000 000004AC |CMT NAND writing block [012E0000], size 0x20000 000004AC |CMT NAND writing block [01300000], size 0x20000 000004AC |CMT NAND writing block [01320000], size 0x20000 000004AC |CMT NAND writing block [01340000], size 0x20000 000004AC |CMT NAND writing block [01360000], size 0x20000 000004AC |CMT NAND writing block [01380000], size 0x20000 000004AC |CMT NAND writing block [013A0000], size 0x20000 000004AC |CMT NAND writing block [013C0000], size 0x20000 000004AC |CMT NAND writing block [013E0000], size 0x20000 000004AC |CMT NAND writing block [01 |
06-04-2013, 22:39 | #4 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | 000004AC |CMT NAND writing block [01400000], size 0x20000 000004AC |CMT NAND writing block [01420000], size 0x20000 000004AC |CMT NAND writing block [01440000], size 0x20000 000004AC |CMT NAND writing block [01460000], size 0x20000 000004AC |CMT NAND writing block [01480000], size 0x20000 000004AC |CMT NAND writing block [014A0000], size 0x20000 000004AC |CMT NAND writing block [014C0000], size 0x20000 000004AC |CMT NAND writing block [014E0000], size 0x20000 000004AC |CMT NAND writing block [01500000], size 0x20000 000004AC |CMT NAND writing block [01520000], size 0x20000 000004AC |CMT NAND writing block [01540000], size 0x20000 000004AC |CMT NAND writing block [01560000], size 0x20000 000004AC |CMT NAND writing block [01580000], size 0x20000 000004AC |CMT NAND writing block [015A0000], size 0x20000 000004AC |CMT NAND writing block [015C0000], size 0x20000 000004AC |CMT NAND writing block [015E0000], size 0x20000 000004AC |CMT NAND writing block [01600000], size 0x20000 000004AC |CMT NAND writing block [01620000], size 0x20000 000004AC |CMT NAND writing block [01640000], size 0x20000 000004AC |CMT NAND writing block [01660000], size 0x20000 000004AC |CMT NAND writing block [01680000], size 0xB000 000004AC |Programming completed. 000004AC |UsbRebootFromFlashMode->begin (D0) 000004AC |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} FFFFFFFF |UsbRebootFromFlashMode->end (D0) FFFFFFFF |boot: D9 0 4 FFFFFFFF |boot.dwErr: 0 FFFFFFFF |HdrSize: 0x20270D FFFFFFFF |BootTryCount: 0 FFFFFFFF |USB_ROM FFFFFFFF |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 000004D0 |USB: BB5 Get terminal challenge request->begin 000004D0 |USB: BB5 Get terminal challenge request->end (0 1) 000004D0 |USB: BB5 Get terminal challenge response->begin 000004D0 |USB: BB5 Get terminal challenge response->end (1, 96) 000004D0 |bootResult: 01 000004D0 |BB5UsbOpenSendLoader->begin 000004D0 |UsbFlashingMethod: D9 0 0 3 000004D0 |HdrSize: 0x20270D 000004D0 |SearchSecondaryBoot->begin: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\Usb\ [400C192101031103] 000004D0 |XG223_v11_usb2nd.fg 000004D0 | ->BootL String not match. 000004D0 |BCM21351_usb2nd.fg 000004D0 | ->BootL String match (BB5) 000004D0 |RAP3Gv40_2nd.fg 000004D0 | ->BootL String match (BB5) 000004D0 |RAPIDOv11_2nd.fg 000004D0 | ->BootL String match (BB5) 000004D0 |SearchBootCode ->ok: RAPIDOv11_2nd.fg 000004D0 |SearchSecondaryBoot->end: 1 000004D0 |ldrVersion: 11.14.0 000004D0 |HdrSize: 0x151F4 000004D0 |XG223_v11_usbalg.fg 000004D0 |BCM21351_XSR16_usbalg.fg 000004D0 |RAP3Gv40_XSR17_alg.fg 000004D0 |RAPIDOv11_XSR15_alg.fg 000004D0 | ->ASICID match 000004D0 | ->FlashL String match (XSR 1.5) 000004D0 |SearchAlgorithm ->ok: RAPIDOv11_XSR15_alg.fg 000004D0 |ldrVersion: 11.14.0 000004D0 |Sending flash loader->begin 000004D0 |address: 0x08005000, size: 00000060 000004D0 |CERT: PASUBTOC 000004D0 |address: 0x080070C0, size: 00002AC0 000004D0 |CERT: ALG 000004D0 |address: 0x0800B000, size: 00000400 000004D0 |address: 0x0800B400, size: 00004000 000004D0 |address: 0x0800F400, size: 00004000 000004D0 |address: 0x08013400, size: 00004000 000004D0 |address: 0x08017400, size: 00004000 000004D0 |address: 0x0801B400, size: 00004000 000004D0 |address: 0x0801F400, size: 00004000 000004D0 |address: 0x08023400, size: 00004000 000004D0 |address: 0x08027400, size: 00004000 000004D0 |address: 0x0802B400, size: 00004000 000004D0 |address: 0x0802F400, size: 00004000 000004D0 |address: 0x08033400, size: 00000A80 000004D0 |Sending flash loader->end 000004D0 |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 000004D0 |BB5UsbOpenSendLoader->end 000004D0 |Reading CERT: CMT NPC 000004D0 |Master ASIC set to CMT 000004D0 |Erasing CERT: CMT NPC 000004D0 |RebootFromFlashMode->begin (D0) 000004D0 |UsbRebootFromFlashMode->begin (D0) FFFFFFFF |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} FFFFFFFF |UsbRebootFromFlashMode->end (D0) FFFFFFFF |RebootFromFlashMode->end FFFFFFFF |boot: D4 0 4 FFFFFFFF |boot.dwErr: 0 FFFFFFFF |HdrSize: 0x20270D FFFFFFFF |BootTryCount: 0 FFFFFFFF |USB_ROM FFFFFFFF |BootTryCount: 1 FFFFFFFF |USB_ROM FFFFFFFF |BootTryCount: 2 ================================================== ================================================== Time : 28/05/2013 7:51:38 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 09/05/2013 20:05:14 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1318 MB Free) ================================================== ================================================== Instance Closed. ]Access violation at address 10085126. Read of address 63306128 002A026C |[USBSTOR]Access violation at address 10085126. Read of address 63306128 002A026C |[USBSTOR]Access violation at address 10085126. Read of address 63306128 002A026C |[USBSTOR]Access violation at address 10085126. Read of address 63306128 002A026C |doSynchronizeImportantFiles->begin ================================================== ================================================== Time : 28/05/2013 8:09:15 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 09/05/2013 20:05:14 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1328 MB Free) ================================================== ================================================== Instance Closed. lash check: 0000B00D |MCU : C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-346\rm346_510.21.009_prd.c00 0000 >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000588 1 of 1 > Nokia USB Flashing Generic:FFFFFFFF 1 of 1 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 2 > :00000000 0 of 2 -> closed 003602A8 |[USBSTOR]Access violation at address 10085126. Read of address 63306128 B00D |FastFlash : 1 0000B00D |SkipUPP : 0 0000B00D |SkipErase : 0 0000B00D |EraseWhole: 0 0000B00D |LangOnly : 0 0000B00D |FlsOption : 2 0000B00D |Downgrade : 0 0000B00D |Processing file: #rm346_510.21.009_prd.c00 0000B00D |HdrSize: 0x20270D 0000B00D |Sector to Erase: 0000B00D |boot: D9 1 4 0000B00D |boot.dwErr: 0 0000B00D |HdrSize: 0x20270D 0000B00D |BootTryCount: 0 0000B00D |USB_ROM 0000B00D |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 00000588 |USB: BB5 Get terminal challenge request->begin 00000588 |USB: BB5 Get terminal challenge request->end (0 1) 00000588 |USB: BB5 Get terminal challenge response->begin 00000588 |USB: BB5 Get terminal challenge response->end (1, 96) 00000588 |bootResult: 01 00000588 |BB5UsbOpenSendLoader 00000588 |BB5UsbOpenSendLoader->begin 00000588 |UsbFlashingMethod: D9 0 0 3 00000588 |HdrSize: 0x20270D 00000588 |SearchSecondaryBoot->begin: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\Usb\ [400C192101031103] 00000588 |BCM21351_usb2nd.fg 00000588 | ->BootL String match (BB5) 00000588 |RAP3Gv40_2nd.fg 00000588 | ->BootL String match (BB5) 00000588 |RAPIDOv11_2nd.fg 00000588 | ->BootL String match (BB5) 00000588 |SearchBootCode ->ok: RAPIDOv11_2nd.fg 00000588 |SearchSecondaryBoot->end: 1 00000588 |ldrVersion: 12.8.0 00000588 |HdrSize: 0x15FCB 00000588 |BCM21351_XSR16_usbalg.fg 00000588 |RAP3Gv40_XSR17_alg.fg 00000588 |RAPIDOv11_XSR15_alg.fg 00000588 | ->ASICID match 00000588 | ->FlashL String match (XSR 1.5) 00000588 |SearchAlgorithm ->ok: RAPIDOv11_XSR15_alg.fg 00000588 |ldrVersion: 12.8.0 00000588 |Sending flash loader->begin 00000588 |address: 0x08005000, size: 00000060 00000588 |CERT: PASUBTOC 00000588 |address: 0x080070C0, size: 00002AC0 00000588 |CERT: ALG 00000588 |address: 0x0800B000, size: 00000400 00000588 |address: 0x0800B400, size: 00004000 00000588 |address: 0x0800F400, size: 00004000 00000588 |address: 0x08013400, size: 00004000 00000588 |address: 0x08017400, size: 00004000 00000588 |address: 0x0801B400, size: 00004000 00000588 |address: 0x0801F400, size: 00004000 00000588 |address: 0x08023400, size: 00004000 00000588 |address: 0x08027400, size: 00004000 00000588 |address: 0x0802B400, size: 00004000 00000588 |address: 0x0802F400, size: 00000180 00000588 |Sending flash loader->end 00000588 |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 00000588 |BB5UsbOpenSendLoader->end 00000588 |RPL backup skipped due to usb limitation 00000588 |[UsbFlashing] Method: Bulk, SingleAsic, Cold 00000588 |BeginEraseFlash: 2 00000588 |> RAP NAND device. 00000588 |#CMT : 3 sector(s) CMT FLASH,MuxOneNAND area #[00040000-007FFFFF] CMT FLASH,MuxOneNAND area #[00A00000-0759FFFF] CMT FLASH,MuxOneNAND area #[0F1C0000-0F8BFFFF] 00000588 |#CMT : 1 sector(s) Format Partition(NAND) 00000588 |#CMT : 1 sector(s) Format Partition(NAND) 00000588 |#CMT : 1 sector(s) Format Partition(NAND) 00000588 |#CMT : 3 sector(s) CMT FLASH,MuxOneNAND area #[00040000-007FFFFF] CMT FLASH,MuxOneNAND area #[00A00000-0759FFFF] CMT FLASH,MuxOneNAND area #[0F1C0000-0F8BFFFF] 00000588 |#CMT : 1 sector(s) Format Partition(NAND) 00000588 |#CMT : 1 sector(s) Format Partition(NAND) 00000588 |#CMT : 1 sector(s) Format Partition(NAND) 00000588 |Erase complete. 00000588 |Begin flash programming: C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-346\rm346_510.21.009_prd.c00 00000588 |fileSize: 0x43D41C8 00000588 |availMem: 0x4E549000 00000588 |[WriteBlock] Handling file with huge size 00000588 |Master ASIC set to CMT 00000588 |CMT NAND writing block [00000000], size 0x200 00000588 |CMT NAND writing block [00000200], size 0x200 00000588 |CMT NAND writing block [00020000], size 0x200 00000588 |CMT NAND writing block [00080000], size 0x400 00000588 |CMT NAND writing block [00080800], size 0x2200 00000588 |CMT NAND writing block [00083600], size 0x600 00000588 |CMT NAND writing block [00084400], size 0x15800 00000588 |38F312750F686F9FC9B1B3778774A195,52570A2086C79E69 65175815B5388535CDD5C6F7 00000588 |CAEEBB65D3C48E6DC73B49DC5063A2EE,52570A2086C79E69 65175815B5388535CDD5C6F7 00000588 |CMT Writing PaPubKeysHash (PAPUBKEYS, RAP Certificate 101 v1) 00000588 |F2D76DFAFD66C7F195F278417DF05888,52570A2086C79E69 65175815B5388535CDD5C6F7 00000588 |479C6DDE3942E12C429C1D6ADED80371,52570A2086C79E69 65175815B5388535CDD5C6F7 00000588 |B8C3ADECFC997FCD8081D3DEAF870B8C,52570A2086C79E69 65175815B5388535CDD5C6F7 00000588 |CMT NAND writing block [000C0400], size 0x200 00000588 |CMT NAND writing block [00400400], size 0x20000 00000588 |CMT NAND writing block [00420400], size 0x20000 00000588 |CMT NAND writing block [00440400], size 0x20000 00000588 |CMT NAND writing block [00460400], size 0x20000 00000588 |CMT NAND writing block [00480400], size 0x20000 00000588 |CMT NAND writing block [004A0400], size 0x20000 00000588 |CMT NAND writing block [004C0400], size 0x20000 00000588 |CMT NAND writing block [004E0400], size 0x15A00 00000588 |CMT NAND writing block [00500400], size 0x20000 00000588 |CMT NAND writing block [00520400], size 0x20000 00000588 |CMT NAND writing block [00540400], size 0x20000 00000588 |CMT NAND writing block [00560400], size 0x20000 00000588 |CMT NAND writing block [00580400], size 0x20000 00000588 |CMT NAND writing block [005A0400], size 0x20000 00000588 |CMT NAND writing block [005C0400], size 0x20000 00000588 |CMT NAND writing block [005E0400], size 0x20000 00000588 |CMT NAND writing block [00600400], size 0x20000 00000588 |CMT NAND writing block [00620400], size 0x20000 00000588 |CMT NAND writing block [00640400], size 0x20000 00000588 |CMT NAND writing block [00660400], size 0x20000 00000588 |CMT NAND writing block [00680400], size 0x20000 00000588 |CMT NAND writing block [006A0400], size 0x20000 00000588 |CMT NAND writing block [006C0400], size 0x20000 00000588 |CMT NAND writing block [006E0400], size 0x20000 00000588 |CMT NAND writing block [00700400], size 0x20000 00000588 |CMT NAND writing block [00720400], size 0x20000 00000588 |CMT NAND writing block [00740400], size 0x20000 00000588 |CMT NAND writing block [00760400], size 0x10200 00000588 |CMT NAND writing block [00A00400], size 0x20000 00000588 |CMT NAND writing block [00A20400], size 0x20000 00000588 |CMT NAND writing block [00A40400], size 0x20000 00000588 |CMT NAND writing block [00A60400], size 0x20000 00000588 |CMT NAND writing block [00A80400], size 0x20000 00000588 |CMT NAND writing block [00AA0400], size 0x20000 00000588 |CMT NAND writing block [00AC0400], size 0x20000 00000588 |CMT NAND writing block [00AE0400], size 0x20000 00000588 |CMT NAND writing block [00B00400], size 0x20000 00000588 |CMT NAND writing block [00B20400], size 0x20000 00000588 |CMT NAND writing block [00B40400], size 0x20000 00000588 |CMT NAND writing block [00B60400], size 0x20000 00000588 |CMT NAND writing block [00B80400], size 0x20000 00000588 |CMT NAND writing block [00BA0400], size 0x20000 00000588 |CMT NAND writing block [00BC0400], size 0x20000 00000588 |CMT NAND writing block [00BE0400], size 0x20000 00000588 |CMT NAND writing block [00C00400], size 0x20000 00000588 |CMT NAND writing block [00C20400], size 0x20000 00000588 |CMT NAND writing block [00C40400], size 0x20000 00000588 |CMT NAND writing block [00C60400], size 0x20000 00000588 |Programming failed. ================================================== ================================================== Time : 28/05/2013 19:33:50 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 09/05/2013 20:05:14 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1406 MB Free) ================================================== ================================================== Instance Closed. ]Access violation at address 10084132. Read of address 63306128 >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed 0004026C |[USBSTOR]Access violation at address 10084132. Read of address 63306128 ================================================== ================================================== Time : 28/05/2013 19:40:37 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 09/05/2013 20:05:14 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1400 MB Free) ================================================== ================================================== Instance Closed. ]Access violation at address 10084132. Read of address 63306128 >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed 000502A6 |[USBSTOR]Access violation at address 10084132. Read of address 63306128 ================================================== ================================================== Time : 28/05/2013 20:12:19 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 09/05/2013 20:05:14 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1384 MB Free) ================================================== ================================================== 0000B00D |HdrSize: 0x20270D 0000B00D |boot: D9 1 4 0000B00D |boot.dwErr: 0 0000B00D |HdrSize: 0x20270D 0000B00D |BootTryCount: 0 0000B00D |USB_ROM 0000B00D |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 0000045C |USB: BB5 Get terminal challenge request->begin 000004 >CloseDeviceIndex: Nokia USB Flashing Generic:0000045C 1 of 1 > Nokia USB Flashing Generic:FFFFFFFF 1 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000045C 1 of 2 > Nokia USB Flashing Generic:0000045C 1 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000588 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000588 2 of 2 > Nokia USB Flashing Generic:00000588 2 of 2 -> closed >CloseDeviceIndex: :00000000 0 of 3 > :00000000 0 of 3 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 4 of 4 > Nokia USB Flashing Generic:FFFFFFFF 4 of 3 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 4 of 4 > Nokia USB Flashing Generic:FFFFFFFF 4 of 3 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 4 of 3 > Nokia USB Flashing Generic:0000052C 4 of 3 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 4 of 4 > Nokia USB Flashing Generic:0000052C 4 of 4 -> closed >CloseDeviceIndex: :FFFFFFFF 5 of 5 > :FFFFFFFF 5 of 5 -> closed >CloseDeviceIndex: :00000000 0 of 5 > :00000000 0 of 5 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000694 6 of 6 > Nokia USB Flashing Generic:FFFFFFFF 6 of 5 -> closed ss: 0x0801B400, size: 00004000 0000045C |address: 0x0801F400, size: 00004000 0000045C |address: 0x08023400, size: 00004000 0000045C |address: 0x08027400, size: 00004000 0000045C |address: 0x0802B400, size: 00004000 0000045C |address: 0x0802F400, size: 00000180 0000045C |Sending flash loader->end 0000045C |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 0000045C |BB5UsbOpenSendLoader->end 0000045C |+++ 0000045C |[UsbFlashing] Method: Bulk, SingleAsic Cold 0000045C |Reading CERT: CMT NPC 0000045C |Reading CERT: CMT VARIANT 0000045C |Reading CERT: CMT CCC 0000045C |Reading CERT: CMT HWC 0000045C |Reading CERT: CMT R&D 0000045C |Reading CERT: CMT MDM_KEYS 0000045C |Reading CERT: CMT PARTNERC 0000045C |UsbRebootFromFlashMode->begin (D0) 0000045C |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 00000588 |UsbDevice found: \\?\nmwcd#vid_0421&pid_00ab&if_oth#6&bc9fca1&a&01# {4f919102-4adf-11d5-882d-00b0d02fe381} 00000598 |UsbRebootFromFlashMode->end (D1) FFFFFFFF |HdrSize: 0x20270D FFFFFFFF |boot: D9 0 4 FFFFFFFF |boot.dwErr: 0 FFFFFFFF |HdrSize: 0x20270D FFFFFFFF |BootTryCount: 0 FFFFFFFF |USB_ROM FFFFFFFF |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 0000052C |USB: BB5 Get terminal challenge request->begin 0000052C |USB: BB5 Get terminal challenge request->end (0 1) 0000052C |USB: BB5 Get terminal challenge response->begin 0000052C |USB: BB5 Get terminal challenge response->end (1, 96) 0000052C |bootResult: 01 0000052C |BB5UsbOpenSendLoader->begin 0000052C |UsbFlashingMethod: D9 0 0 3 0000052C |HdrSize: 0x20270D 0000052C |SearchSecondaryBoot->begin: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\Usb\ [400C192101031103] 0000052C |BCM21351_usb2nd.fg 0000052C | ->BootL String match (BB5) 0000052C |RAP3Gv40_2nd.fg 0000052C | ->BootL String match (BB5) 0000052C |RAPIDOv11_2nd.fg 0000052C | ->BootL String match (BB5) 0000052C |SearchBootCode ->ok: RAPIDOv11_2nd.fg 0000052C |SearchSecondaryBoot->end: 1 0000052C |ldrVersion: 12.8.0 0000052C |HdrSize: 0x15FCB 0000052C |BCM21351_XSR16_usbalg.fg 0000052C |RAP3Gv40_XSR17_alg.fg 0000052C |RAPIDOv11_XSR15_alg.fg 0000052C | ->ASICID match 0000052C | ->FlashL String match (XSR 1.5) 0000052C |SearchAlgorithm ->ok: RAPIDOv11_XSR15_alg.fg 0000052C |ldrVersion: 12.8.0 0000052C |Sending flash loader->begin 0000052C |address: 0x08005000, size: 00000060 0000052C |CERT: PASUBTOC 0000052C |address: 0x080070C0, size: 00002AC0 0000052C |CERT: ALG 0000052C |address: 0x0800B000, size: 00000400 0000052C |address: 0x0800B400, size: 00004000 0000052C |address: 0x0800F400, size: 00004000 0000052C |address: 0x08013400, size: 00004000 0000052C |address: 0x08017400, size: 00004000 0000052C |address: 0x0801B400, size: 00004000 0000052C |address: 0x0801F400, size: 00004000 0000052C |address: 0x08023400, size: 00004000 0000052C |address: 0x08027400, size: 00004000 0000052C |address: 0x0802B400, size: 00004000 0000052C |address: 0x0802F400, size: 00000180 0000052C |Sending flash loader->end 0000052C |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 0000052C |BB5UsbOpenSendLoader->end 0000052C |+++ 0000052C |[UsbFlashing] Method: Bulk, SingleAsic Cold 0000052C |Reading CERT: CMT NPC 0000052C |Reading CERT: CMT VARIANT 0000052C |Reading CERT: CMT CCC 0000052C |Reading CERT: CMT HWC 0000052C |Reading CERT: CMT R&D 0000052C |Reading CERT: CMT MDM_KEYS 0000052C |Reading CERT: CMT PARTNERC 0000052C |UsbRebootFromFlashMode->begin (D0) FFFFFFFF |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 0000052C |UsbDevice found: \\?\nmwcd#vid_0421&pid_00ab&if_oth#6&bc9fca1&a&01# {4f919102-4adf-11d5-882d-00b0d02fe381} 00000594 |UsbRebootFromFlashMode->end (D1) 00000594 |boot: D4 0 4 00000594 |boot.dwErr: 0 00000594 |HdrSize: 0x20270D FFFFFFFF |BootTryCount: 0 FFFFFFFF |USB_ROM FFFFFFFF |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 00000694 |USB: BB5 Get terminal challenge request->begin 00000694 |USB: BB5 Get terminal challenge request->end (1 1) 00000694 |USB: BB5 Get terminal challenge response->begin 00000694 |USB: BB5 Get terminal challenge response->end (1, 96) 00000694 |bootResult: 01 00000694 |BB5UsbOpenSendLoader->begin 00000694 |UsbFlashingMethod: D9 0 0 3 00000694 |HdrSize: 0x20270D 00000694 |SearchSecondaryBoot->begin: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\Usb\ [400C192101031103] 00000694 |BCM21351_usb2nd.fg 00000694 | ->BootL String match (BB5) 00000694 |RAP3Gv40_2nd.fg 00000694 | ->BootL String match (BB5) 00000694 |RAPIDOv11_2nd.fg 00000694 | ->BootL String match (BB5) 00000694 |SearchBootCode ->ok: RAPIDOv11_2nd.fg 00000694 |SearchSecondaryBoot->end: 1 00000694 |ldrVersion: 12.8.0 00000694 |HdrSize: 0x15FCB 00000694 |BCM21351_XSR16_usbalg.fg 00000694 |RAP3Gv40_XSR17_alg.fg 00000694 |RAPIDOv11_XSR15_alg.fg 00000694 | ->ASICID match 00000694 | ->FlashL String match (XSR 1.5) 00000694 |SearchAlgorithm ->ok: RAPIDOv11_XSR15_alg.fg 00000694 |ldrVersion: 12.8.0 00000694 |Sending flash loader->begin 00000694 |address: 0x08005000, size: 00000060 00000694 |CERT: PASUBTOC 00000694 |address: 0x080070C0, size: 00002AC0 00000694 |CERT: ALG 00000694 |address: 0x0800B000, size: 00000400 00000694 |address: 0x0800B400, size: 00004000 00000694 |address: 0x0800F400, size: 00004000 00000694 |address: 0x08013400, size: 00004000 00000694 |address: 0x08017400, size: 00004000 00000694 |address: 0x0801B400, size: 00004000 00000694 |address: 0x0801F400, size: 00004000 00000694 |address: 0x08023400, size: 00004000 00000694 |address: 0x08027400, size: 00004000 00000694 |address: 0x0802B400, size: 00004000 00000694 |address: 0x0802F400, size: 00000180 00000694 |Sending flash loader->end 00000694 |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 00000694 |BB5UsbOpenSendLoader->end 00000694 |Reading CERT: CMT NPC ================================================== ================================================== Time : 29/05/2013 19:02:57 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 29/05/2013 19:02:26 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1283 MB Free) ================================================== ================================================== 0000B00D |HdrSize: 0x20270D 0000B00D |boot: D9 1 4 0000B00D |boot.dwErr: 0 0000B00D |HdrSize: 0x20270D 0000B00D |BootTryCount: 0 0000B00D |USB_ROM 0000B00D |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-8 >CloseDeviceIndex: Nokia USB Flashing Generic:00000464 1 of 1 > Nokia USB Flashing Generic:FFFFFFFF 1 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000464 1 of 2 > Nokia USB Flashing Generic:00000464 1 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: :00000000 0 of 1 > :00000000 0 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:0000052C 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed ize: 00004000 00000464 |address: 0x0802B400, size: 00004000 00000464 |address: 0x0802F400, size: 00000180 00000464 |Sending flash loader->end 00000464 |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 00000464 |BB5UsbOpenSendLoader->end 00000464 |+++ 00000464 |[UsbFlashing] Method: Bulk, SingleAsic Cold 00000464 |Reading CERT: CMT NPC 00000464 |Reading CERT: CMT VARIANT 00000464 |Reading CERT: CMT CCC 00000464 |Reading CERT: CMT HWC 00000464 |Reading CERT: CMT R&D 00000464 |Reading CERT: CMT MDM_KEYS 00000464 |Reading CERT: CMT PARTNERC 00000464 |UsbRebootFromFlashMode->begin (D0) 00000464 |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 0000052C |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 0000052C |UsbRebootFromFlashMode->end (D0) ================================================== ================================================== Time : 29/05/2013 19:09:58 Process : C:\mobileEx\3.5\mobileEx.exe Main version: 3.4.0.9454, Date compiled: 29/05/2013 19:02:26 User : User System : Windows XP (NT 5.1 Build 2600 Service Pack 3). Subsystem: x86 Language: English (United States) CPU : Intel(R) Atom(TM) CPU N270 @ 1.60GHz, Memory: 2038 MB (1327 MB Free) ================================================== ================================================== Instance Closed. lash check: 0000B00D |MCU : C:\Program Files\Nokia\Phoenix\Products\RM-346\rm346_510.21.009_prd.c00 0000B00D |PPM : C:\Program Files\No >CloseDeviceIndex: :00000000 0 of 0 > :00000000 0 of 0 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004C8 1 of 1 > Nokia USB Flashing Generic:FFFFFFFF 1 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:000004C8 1 of 2 > Nokia USB Flashing Generic:000004C8 1 of 2 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: :00000000 0 of 1 > :00000000 0 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: Nokia USB Flashing Generic:00000484 2 of 2 > Nokia USB Flashing Generic:FFFFFFFF 2 of 1 -> closed >CloseDeviceIndex: :00000000 0 of 1 > :00000000 0 of 1 -> closed >CloseDeviceIndex: :00000000 0 of 1 > :00000000 0 of 1 -> closed >CloseDeviceIndex: :00000000 0 of 1 > :00000000 0 of 1 -> closed >CloseDeviceIndex: :00000000 0 of 1 > :00000000 0 of 1 -> closed 000202A4 |[USBSTOR]Access violation at address 10085126. Read of address 63306128 |address: 0x0800F400, size: 00004000 000004C8 |address: 0x08013400, size: 00004000 000004C8 |address: 0x08017400, size: 00004000 000004C8 |address: 0x0801B400, size: 00004000 000004C8 |address: 0x0801F400, size: 00004000 000004C8 |address: 0x08023400, size: 00004000 000004C8 |address: 0x08027400, size: 00004000 000004C8 |address: 0x0802B400, size: 00004000 000004C8 |address: 0x0802F400, size: 00000180 000004C8 |Sending flash loader->end 000004C8 |UsbDevice found: \\?\nmwcd#vid_0421&pid_0106&if_oth#6&287d7230&10&0 0#{4f919102-4adf-11d5-882d-00b0d02fe381} 000004C8 |BB5UsbOpenSendLoader->end 000004C8 |RPL backup skipped due to usb limitation 000004C8 |[UsbFlashing] Method: Bulk, SingleAsic, Cold 000004C8 |BeginEraseFlash: 2 000004C8 |> RAP NAND device. 000004C8 |#CMT : 3 sector(s) CMT FLASH,MuxOneNAND area #[00040000-007FFFFF] CMT FLASH,MuxOneNAND area #[00A00000-0759FFFF] CMT FLASH,MuxOneNAND area #[0F1C0000-0F8BFFFF] 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |#CMT : 3 sector(s) CMT FLASH,MuxOneNAND area #[00040000-007FFFFF] CMT FLASH,MuxOneNAND area #[00A00000-0759FFFF] CMT FLASH,MuxOneNAND area #[0F1C0000-0F8BFFFF] 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |Erase complete. 000004C8 |Begin flash programming: C:\Program Files\Nokia\Phoenix\Products\RM-346\rm346_510.21.009_prd.c00 000004C8 |fileSize: 0x43D41C8 000004C8 |availMem: 0x4E1D3000 000004C8 |[WriteBlock] Handling file with huge size 000004C8 |Master ASIC set to CMT 000004C8 |CMT NAND writing block [00000000], size 0x200 000004C8 |CMT NAND writing block [00000200], size 0x200 000004C8 |CMT NAND writing block [00020000], size 0x200 000004C8 |CMT NAND writing block [00080000], size 0x400 000004C8 |CMT NAND writing block [00080800], size 0x2200 000004C8 |CMT NAND writing block [00083600], size 0x600 000004C8 |CMT NAND writing block [00084400], size 0x15800 000004C8 |38F312750F686F9FC9B1B3778774A195,52570A2086C79E69 65175815B5388535CDD5C6F7 000004C8 |CAEEBB65D3C48E6DC73B49DC5063A2EE,52570A2086C79E69 65175815B5388535CDD5C6F7 000004C8 |CMT Writing PaPubKeysHash (PAPUBKEYS, RAP Certificate 101 v1) 000004C8 |F2D76DFAFD66C7F195F278417DF05888,52570A2086C79E69 65175815B5388535CDD5C6F7 000004C8 |479C6DDE3942E12C429C1D6ADED80371,52570A2086C79E69 65175815B5388535CDD5C6F7 000004C8 |B8C3ADECFC997FCD8081D3DEAF870B8C,52570A2086C79E69 65175815B5388535CDD5C6F7 000004C8 |CMT NAND writing block [000C0400], size 0x200 000004C8 |CMT NAND writing block [00400400], size 0x20000 000004C8 |CMT NAND writing block [00420400], size 0x20000 000004C8 |CMT NAND writing block [00440400], size 0x20000 000004C8 |CMT NAND writing block [00460400], size 0x20000 000004C8 |CMT NAND writing block [00480400], size 0x20000 000004C8 |CMT NAND writing block [004A0400], size 0x20000 000004C8 |CMT NAND writing block [004C0400], size 0x20000 000004C8 |CMT NAND writing block [004E0400], size 0x15A00 000004C8 |CMT NAND writing block [00500400], size 0x20000 000004C8 |CMT NAND writing block [00520400], size 0x20000 000004C8 |CMT NAND writing block [00540400], size 0x20000 000004C8 |CMT NAND writing block [00560400], size 0x20000 000004C8 |CMT NAND writing block [00580400], size 0x20000 000004C8 |CMT NAND writing block [005A0400], size 0x20000 000004C8 |CMT NAND writing block [005C0400], size 0x20000 000004C8 |CMT NAND writing block [005E0400], size 0x20000 000004C8 |CMT NAND writing block [00600400], size 0x20000 000004C8 |CMT NAND writing block [00620400], size 0x20000 000004C8 |CMT NAND writing block [00640400], size 0x20000 000004C8 |CMT NAND writing block [00660400], size 0x20000 000004C8 |CMT NAND writing block [00680400], size 0x20000 000004C8 |CMT NAND writing block [006A0400], size 0x20000 000004C8 |CMT NAND writing block [006C0400], size 0x20000 000004C8 |CMT NAND writing block [006E0400], size 0x20000 000004C8 |CMT NAND writing block [00700400], size 0x20000 000004C8 |CMT NAND writing block [00720400], size 0x20000 000004C8 |CMT NAND writing block [00740400], size 0x20000 000004C8 |CMT NAND writing block [00760400], size 0x10200 000004C8 |CMT NAND writing block [00A00400], size 0x20000 000004C8 |CMT NAND writing block [00A20400], size 0x20000 000004C8 |CMT NAND writing block [00A40400], size 0x20000 000004C8 |CMT NAND writing block [00A60400], size 0x20000 000004C8 |CMT NAND writing block [00A80400], size 0x20000 000004C8 |CMT NAND writing block [00AA0400], size 0x20000 000004C8 |CMT NAND writing block [00AC0400], size 0x20000 000004C8 |CMT NAND writing block [00AE0400], size 0x20000 000004C8 |CMT NAND writing block [00B00400], size 0x20000 000004C8 |CMT NAND writing block [00B20400], size 0x20000 000004C8 |CMT NAND writing block [00B40400], size 0x20000 000004C8 |CMT NAND writing block [00B60400], size 0x20000 000004C8 |CMT NAND writing block [00B80400], size 0x20000 000004C8 |CMT NAND writing block [00BA0400], size 0x20000 000004C8 |CMT NAND writing block [00BC0400], size 0x20000 000004C8 |CMT NAND writing block [00BE0400], size 0x20000 000004C8 |CMT NAND writing block [00C00400], size 0x20000 000004C8 |CMT NAND writing block [00C20400], size 0x20000 000004C8 |CMT NAND writing block [00C40400], size 0x20000 000004C8 |CMT NAND writing block [00C60400], size 0x20000 000004C8 |CMT NAND writing block [00C80400], size 0x20000 000004C8 |CMT NAND writing block [00CA0400], size 0x20000 000004C8 |CMT NAND writing block [00CC0400], size 0x20000 000004C8 |CMT NAND writing block [00CE0400], size 0x20000 000004C8 |CMT NAND writing block [00D00400], size 0x20000 000004C8 |CMT NAND writing block [00D20400], size 0x20000 000004C8 |CMT NAND writing block [00D40400], size 0x20000 000004C8 |CMT NAND writing block [00D60400], size 0x20000 000004C8 |CMT NAND writing block [00D80400], size 0x20000 000004C8 |CMT NAND writing block [00DA0400], size 0x20000 000004C8 |CMT NAND writing block [00DC0400], size 0x20000 000004C8 |CMT NAND writing block [00DE0400], size 0x20000 000004C8 |CMT NAND writing block [00E00400], size 0x20000 000004C8 |CMT NAND writing block [00E20400], size 0x20000 000004C8 |CMT NAND writing block [00E40400], size 0x20000 000004C8 |CMT NAND writing block [00E60400], size 0x20000 000004C8 |CMT NAND writing block [00E80400], size 0x20000 000004C8 |CMT NAND writing block [00EA0400], size 0x20000 000004C8 |CMT NAND writing block [00EC0400], size 0x20000 000004C8 |CMT NAND writing block [00EE0400], size 0x20000 000004C8 |CMT NAND writing block [00F00400], size 0x20000 000004C8 |CMT NAND writing block [00F20400], size 0x20000 000004C8 |CMT NAND writing block [00F40400], size 0x20000 000004C8 |CMT NAND writing block [00F60400], size 0x20000 000004C8 |CMT NAND writing block [00F80400], size 0x20000 000004C8 |CMT NAND writing block [00FA0400], size 0x20000 000004C8 |CMT NAND writing block [00FC0400], size 0x20000 000004C8 |CMT NAND writing block [00FE0400], size 0x20000 000004C8 |CMT NAND writing block [01000400], size 0x20000 000004C8 |CMT NAND writing block [01020400], size 0x20000 000004C8 |CMT NAND writing block [01040400], size 0x20000 000004C8 |CMT NAND writing block [01060400], size 0x20000 000004C8 |CMT NAND writing block [01080400], size 0x20000 000004C8 |CMT NAND writing block [010A0400], size 0x20000 000004C8 |CMT NAND writing block [010C0400], size 0x20000 000004C8 |CMT NAND writing block [010E0400], size 0x20000 000004C8 |CMT NAND writing block [01100400], size 0x20000 000004C8 |CMT NAND writing block [01120400], size 0x20000 000004C8 |CMT NAND writing block [01140400], size 0x20000 000004C8 |CMT NAND writing block [01160400], size 0x20000 000004C8 |CMT NAND writing block [01180400], size 0x20000 000004C8 |CMT NAND writing block [011A0400], size 0x20000 000004C8 |CMT NAND writing block [011C0400], size 0x20000 000004C8 |CMT NAND writing block [011E0400], size 0x20000 000004C8 |CMT NAND writing block [01200400], size 0x20000 000004C8 |CMT NAND writing block [01220400], size 0x20000 000004C8 |CMT NAND writing block [01240400], size 0x20000 000004C8 |CMT NAND writing block [01260400], size 0x20000 000004C8 |CMT NAND writing block [01280400], size 0x20000 000004C8 |CMT NAND writing block [012A0400], size 0x20000 000004C8 |CMT NAND writing block [012C0400], size 0x20000 000004C8 |CMT NAND writing block [012E0400], size 0x20000 000004C8 |CMT NAND writing block [01300400], size 0x20000 000004C8 |CMT NAND writing block [01320400], size 0x20000 000004C8 |CMT NAND writing block [01340400], size 0x20000 000004C8 |CMT NAND writing block [01360400], size 0x20000 000004C8 |CMT NAND writing block [01380400], size 0x20000 000004C8 |CMT NAND writing block [013A0400], size 0x20000 000004C8 |CMT NAND writing block [013C0400], size 0x20000 000004C8 |CMT NAND writing block [013E0400], size 0x20000 000004C8 |CMT NAND writing block [01400400], size 0x5600 000004C8 |CMT NAND writing block [01600400], size 0x20000 000004C8 |CMT NAND writing block [01620400], size 0x20000 000004C8 |CMT NAND writing block [01640400], size 0x20000 000004C8 |CMT NAND writing block [01660400], size 0x20000 000004C8 |CMT NAND writing block [01680400], size 0x20000 000004C8 |CMT NAND writing block [016A0400], size 0x20000 000004C8 |CMT NAND writing block [016C0400], size 0x20000 000004C8 |CMT NAND writing block [016E0400], size 0x20000 000004C8 |CMT NAND writing block [01700400], size 0x20000 000004C8 |CMT NAND writing block [01720400], size 0x20000 000004C8 |CMT NAND writing block [01740400], size 0x20000 000004C8 |CMT NAND writing block [01760400], size 0x20000 000004C8 |CMT NAND writing block [01780400], size 0x20000 000004C8 |CMT NAND writing block [017A0400], size 0x20000 000004C8 |CMT NAND writing block [017C0400], size 0x20000 000004C8 |CMT NAND writing block [017E0400], size 0x20000 000004C8 |CMT NAND writing block [01800400], size 0x20000 000004C8 |CMT NAND writing block [01820400], size 0x20000 000004C8 |CMT NAND writing block [01840400], size 0x20000 000004C8 |CMT NAND writing block [01860400], size 0x20000 000004C8 |CMT NAND writing block [01880400], size 0x20000 000004C8 |CMT NAND writing block [018A0400], size 0x20000 000004C8 |CMT NAND writing block [018C0400], size 0x20000 000004C8 |CMT NAND writing block [018E0400], size 0x20000 000004C8 |CMT NAND writing block [01900400], size 0x20000 000004C8 |CMT NAND writing block [01920400], size 0x20000 000004C8 |CMT NAND writing block [01940400], size 0x20000 000004C8 |CMT NAND writing block [01960400], size 0x20000 000004C8 |CMT NAND writing block [01980400], size 0x20000 000004C8 |CMT NAND writing block [019A0400], size 0x20000 000004C8 |CMT NAND writing block [019C0400], size 0x20000 000004C8 |CMT NAND writing block [019E0400], size 0x20000 000004C8 |CMT NAND writing block [01A00400], size 0x20000 000004C8 |CMT NAND writing block [01A20400], size 0x20000 000004C8 |CMT NAND writing block [01A40400], size 0x20000 000004C8 |CMT NAND writing block [01A60400], size 0x20000 000004C8 |CMT NAND writing block [01A80400], size 0x20000 000004C8 |CMT NAND writing block [01AA0400], size 0x20000 000004C8 |CMT NAND writing block [01AC0400], size 0x20000 000004C8 |CMT NAND writing block [01AE0400], size 0x20000 000004C8 |CMT NAND writing block [01B00400], size 0x20000 000004C8 |CMT NAND writing block [01B20400], size 0x20000 000004C8 |CMT NAND writing block [01B40400], size 0x20000 000004C8 |CMT NAND writing block [01B60400], size 0x20000 000004C8 |CMT NAND writing block [01B80400], size 0x20000 000004C8 |CMT NAND writing block [01BA0400], size 0x20000 000004C8 |CMT NAND writing block [01BC0400], size 0x20000 000004C8 |CMT NAND writing block [01BE0400], size 0x20000 000004C8 |CMT NAND writing block [01C00400], size 0x20000 000004C8 |CMT NAND writing block [01C20400], size 0x20000 000004C8 |CMT NAND writing block [01C40400], size 0x20000 000004C8 |CMT NAND writing block [01C60400], size 0x20000 000004C8 |CMT NAND writing block [01C80400], size 0x20000 000004C8 |CMT NAND writing block [01CA0400], size 0x20000 000004C8 |CMT NAND writing block [01CC0400], size 0x20000 000004C8 |CMT NAND writing block [01CE0400], size 0x20000 000004C8 |CMT NAND writing block [01D00400], size 0x20000 000004C8 |CMT NAND writing block [01D20400], size 0x20000 000004C8 |CMT NAND writing block [01D40400], size 0x20000 000004C8 |CMT NAND writing block [01D60400], size 0x20000 000004C8 |CMT NAND writing block [01D80400], size 0x20000 000004C8 |CMT NAND writing block [01DA0400], size 0x20000 000004C8 |CMT NAND writing block [01DC0400], size 0x20000 000004C8 |CMT NAND writing block [01DE0400], size 0x20000 000004C8 |CMT NAND writing block [01E00400], size 0x20000 000004C8 |CMT NAND writing block [01E20400], size 0x20000 000004C8 |CMT NAND writing block [01E40400], size 0x20000 000004C8 |CMT NAND writing block [01E60400], size 0x20000 000004C8 |CMT NAND writing block [01E80400], size 0x20000 000004C8 |CMT NAND writing block [01EA0400], size 0x20000 000004C8 |CMT NAND writing block [01EC0400], size 0x20000 000004C8 |CMT NAND writing block [01EE0400], size 0x20000 000004C8 |CMT NAND writing block [01F00400], size 0x20000 000004C8 |CMT NAND writing block [01F20400], size 0x20000 000004C8 |CMT NAND writing block [01F40400], size 0x20000 000004C8 |CMT NAND writing block [01F60400], size 0x20000 000004C8 |CMT NAND writing block [01F80400], size 0x20000 000004C8 |CMT NAND writing block [01FA0400], size 0x20000 000004C8 |CMT NAND writing block [01FC0400], size 0x20000 000004C8 |CMT NAND writing block [01FE0400], size 0x20000 000004C8 |CMT NAND writing block [02000400], size 0x20000 000004C8 |CMT NAND writing block [02020400], size 0x20000 000004C8 |CMT NAND writing block [02040400], size 0x20000 000004C8 |CMT NAND writing block [02060400], size 0x20000 000004C8 |CMT NAND writing block [02080400], size 0x20000 000004C8 |CMT NAND writing block [020A0400], size 0x20000 000004C8 |CMT NAND writing block [020C0400], size 0x20000 000004C8 |CMT NAND writing block [020E0400], size 0x20000 000004C8 |CMT NAND writing block [02100400], size 0x20000 000004C8 |CMT NAND writing block [02120400], size 0x20000 000004C8 |CMT NAND writing block [02140400], size 0x20000 000004C8 |CMT NAND writing block [02160400], size 0x20000 000004C8 |CMT NAND writing block [02180400], size 0x20000 000004C8 |CMT NAND writing block [021A0400], size 0x20000 000004C8 |CMT NAND writing block [021C0400], size 0x20000 000004C8 |CMT NAND writing block [021E0400], size 0x20000 000004C8 |CMT NAND writing block [02200400], size 0x20000 000004C8 |CMT NAND writing block [02220400], size 0x20000 000004C8 |CMT NAND writing block [02240400], size 0x20000 000004C8 |CMT NAND writing block [02260400], size 0x20000 000004C8 |CMT NAND writing block [02280400], size 0x20000 000004C8 |CMT NAND writing block [022A0400], size 0x20000 000004C8 |CMT NAND writing block [022C0400], size 0x20000 000004C8 |CMT NAND writing block [022E0400], size 0x20000 000004C8 |CMT NAND writing block [02300400], size 0x20000 000004C8 |CMT NAND writing block [02320400], size 0x20000 000004C8 |CMT NAND writing block [02340400], size 0x20000 000004C8 |CMT NAND writing block [02360400], size 0x20000 000004C8 |CMT NAND writing block [02380400], size 0x20000 000004C8 |CMT NAND writing block [023A0400], size 0x20000 000004C8 |CMT NAND writing block [023C0400], size 0x20000 000004C8 |CMT NAND writing block [023E0400], size 0x20000 000004C8 |CMT NAND writing block [02400400], size 0x20000 000004C8 |CMT NAND writing block [02420400], size 0x20000 000004C8 |CMT NAND writing block [02440400], size 0x20000 000004C8 |CMT NAND writing block [02460400], size 0x20000 000004C8 |CMT NAND writing block [02480400], size 0x20000 000004C8 |CMT NAND writing block [024A0400], size 0x20000 000004C8 |CMT NAND writing block [024C0400], size 0x20000 000004C8 |CMT NAND writing block [024E0400], size 0x20000 000004C8 |CMT NAND writing block [02500400], size 0x20000 000004C8 |CMT NAND writing block [02520400], size 0x20000 000004C8 |CMT NAND writing block [02540400], size 0x20000 000004C8 |CMT NAND writing block [02560400], size 0x20000 000004C8 |CMT NAND writing block [02580400], size 0x20000 000004C8 |CMT NAND writing block [025A0400], size 0x20000 000004C8 |CMT NAND writing block [025C0400], size 0x20000 000004C8 |CMT NAND writing block [025E0400], size 0x20000 000004C8 |CMT NAND writing block [02600400], size 0x20000 000004C8 |CMT NAND writing block [02620400], size 0x20000 000004C8 |CMT NAND writing block [02640400], size 0x20000 000004C8 |CMT NAND writing block [02660400], size 0x20000 000004C8 |CMT NAND writing block [02680400], size 0x20000 000004C8 |CMT NAND writing block [026A0400], size 0x20000 000004C8 |CMT NAND writing block [026C0400], size 0x20000 000004C8 |CMT NAND writing block [026E0400], size 0x20000 000004C8 |CMT NAND writing block [02700400], size 0x20000 000004C8 |CMT NAND writing block [02720400], size 0x20000 000004C8 |CMT NAND writing block [02740400], size 0x20000 000004C8 |CMT NAND writing block [02760400], size 0x20000 000004C8 |CMT NAND writing block [02780400], size 0x20000 000004C8 |CMT NAND writing block [027A0400], size 0x20000 000004C8 |CMT NAND writing block [027C0400], size 0x20000 000004C8 |CMT NAND writing block [027E0400], size 0x20000 000004C8 |CMT NAND writing block [02800400], size 0x20000 000004C8 |CMT NAND writing block [02820400], size 0x20000 000004C8 |CMT NAND writing block [02840400], size 0x20000 000004C8 |CMT NAND writing block [02860400], size 0x20000 000004C8 |CMT NAND writing block [02880400], size 0x20000 000004C8 |CMT NAND writing block [028A0400], size 0x20000 000004C8 |CMT NAND writing block [028C0400], size 0x20000 000004C8 |CMT NAND writing block [028E0400], size 0x20000 000004C8 |CMT NAND writing block [02900400], size 0x20000 000004C8 |CMT NAND writing block [02920400], size 0x20000 000004C8 |CMT NAND writing block [02940400], size 0x20000 000004C8 |CMT NAND writing block [02960400], size 0x20000 000004C8 |CMT NAND writing block [02980400], size 0x20000 000004C8 |CMT NAND writing block [029A0400], size 0x20000 000004C8 |CMT NAND writing block [029C0400], size 0x20000 000004C8 |CMT NAND writing block [029E0400], size 0x20000 000004C8 |CMT NAND writing block [02A00400], size 0x20000 000004C8 |CMT NAND writing block [02A20400], size 0x20000 000004C8 |CMT NAND writing block [02A40400], size 0x20000 000004C8 |CMT NAND writing block [02A60400], size 0x20000 000004C8 |CMT NAND writing block [02A80400], size 0x20000 000004C8 |CMT NAND writing block [02AA0400], size 0x20000 000004C8 |CMT NAND writing block [02AC0400], size 0x20000 000004C8 |CMT NAND writing block [02AE0400], size 0x20000 000004C8 |CMT NAND writing block [02B00400], size 0x20000 000004C8 |CMT NAND writing block [02B20400], size 0x20000 000004C8 |CMT NAND writing block [02B40400], size 0x20000 000004C8 |CMT NAND writing block [02B60400], size 0x20000 000004C8 |CMT NAND writing block [02B80400], size 0x20000 000004C8 |CMT NAND writing block [02BA0400], size 0x20000 000004C8 |CMT NAND writing block [02BC0400], size 0x20000 000004C8 |CMT NAND writing block [02BE0400], size 0x20000 000004C8 |CMT NAND writing block [02C00400], size 0x20000 000004C8 |CMT NAND writing block [02C20400], size 0x20000 000004C8 |CMT NAND writing block [02C40400], size 0x20000 000004C8 |CMT NAND writing block [02C60400], size 0x20000 000004C8 |CMT NAND writing block [02C80400], size 0x20000 000004C8 |CMT NAND writing block [02CA0400], size 0x20000 000004C8 |CMT NAND writing block [02CC0400], size 0x20000 000004C8 |CMT NAND writing block [02CE0400], size 0x20000 000004C8 |CMT NAND writing block [02D00400], size 0x20000 000004C8 |CMT NAND writing block [02D20400], size 0x20000 000004C8 |CMT NAND writing block [02D40400], size 0x20000 000004C8 |CMT NAND writing block [02D60400], size 0x20000 000004C8 |CMT NAND writing block [02D80400], size 0x20000 000004C8 |CMT NAND writing block [02DA0400], size 0x20000 000004C8 |CMT NAND writing block [02DC0400], size 0x20000 000004C8 |CMT NAND writing block [02DE0400], size 0x20000 000004C8 |CMT NAND writing block [02E00400], size 0x20000 000004C8 |CMT NAND writing block [02E20400], size 0x20000 000004C8 |CMT NAND writing block [02E40400], size 0x20000 000004C8 |CMT NAND writing block [02E60400], size 0x20000 000004C8 |CMT NAND writing block [02E80400], size 0x20000 000004C8 |CMT NAND writing block [02EA0400], size 0x20000 000004C8 |CMT NAND writing block [02EC0400], size 0x20000 000004C8 |CMT NAND writing block [02EE0400], size 0x20000 000004C8 |CMT NAND writing block [02F00400], size 0x20000 000004C8 |CMT NAND writing block [02F20400], size 0x20000 000004C8 |CMT NAND writing block [02F40400], size 0x20000 000004C8 |CMT NAND writing block [02F60400], size 0x20000 000004C8 |CMT NAND writing block [02F80400], size 0x20000 000004C8 |CMT NAND writing block [02FA0400], size 0x20000 000004C8 |CMT NAND writing block [02FC0400], size 0x20000 000004C8 |CMT NAND writing block [02FE0400], size 0x20000 000004C8 |CMT NAND writing block [03000400], size 0x20000 000004C8 |CMT NAND writing block [03020400], size 0x20000 000004C8 |CMT NAND writing block [03040400], size 0x20000 000004C8 |CMT NAND writing block [03060400], size 0x20000 000004C8 |CMT NAND writing block [03080400], size 0x20000 000004C8 |CMT NAND writing block [030A0400], size 0x20000 000004C8 |CMT NAND writing block [030C0400], size 0x20000 000004C8 |CMT NAND writing block [030E0400], size 0x20000 000004C8 |CMT NAND writing block [03100400], size 0x20000 000004C8 |CMT NAND writing block [03120400], size 0x20000 000004C8 |CMT NAND writing block [03140400], size 0x20000 000004C8 |CMT NAND writing block [03160400], size 0x20000 000004C8 |CMT NAND writing block [03180400], size 0x20000 000004C8 |CMT NAND writing block [031A0400], size 0x20000 000004C8 |CMT NAND writing block [031C0400], size 0x20000 000004C8 |CMT NAND writing block [031E0400], size 0x20000 000004C8 |CMT NAND writing block [03200400], size 0x20000 000004C8 |CMT NAND writing block [03220400], size 0x20000 000004C8 |CMT NAND writing block [03240400], size 0x20000 000004C8 |CMT NAND writing block [03260400], size 0x20000 000004C8 |CMT NAND writing block [03280400], size 0x20000 000004C8 |CMT NAND writing block [032A0400], size 0x20000 000004C8 |CMT NAND writing block [032C0400], size 0x20000 000004C8 |CMT NAND writing block [032E0400], size 0x20000 000004C8 |CMT NAND writing block [03300400], size 0x20000 000004C8 |CMT NAND writing block [03320400], size 0x20000 000004C8 |CMT NAND writing block [03340400], size 0x20000 000004C8 |CMT NAND writing block [03360400], size 0x20000 000004C8 |CMT NAND writing block [03380400], size 0x20000 000004C8 |CMT NAND writing block [033A0400], size 0x20000 000004C8 |CMT NAND writing block [033C0400], size 0x20000 000004C8 |CMT NAND writing block [033E0400], size 0x20000 000004C8 |CMT NAND writing block [03400400], size 0x20000 000004C8 |CMT NAND writing block [03420400], size 0x20000 000004C8 |CMT NAND writing block [03440400], size 0x20000 000004C8 |CMT NAND writing block [03460400], size 0x20000 000004C8 |CMT NAND writing block [03480400], size 0x20000 000004C8 |CMT NAND writing block [034A0400], size 0x20000 000004C8 |CMT NAND writing block [034C0400], size 0x20000 000004C8 |CMT NAND writing block [034E0400], size 0x20000 000004C8 |CMT NAND writing block [03500400], size 0x20000 000004C8 |CMT NAND writing block [03520400], size 0x20000 000004C8 |CMT NAND writing block [03540400], size 0x20000 000004C8 |CMT NAND writing block [03560400], size 0x20000 000004C8 |CMT NAND writing block [03580400], size 0x20000 000004C8 |CMT NAND writing block [035A0400], size 0x20000 000004C8 |CMT NAND writing block [035C0400], size 0x20000 000004C8 |CMT NAND writing block [035E0400], size 0x20000 000004C8 |CMT NAND writing block [03600400], size 0x20000 000004C8 |CMT NAND writing block [03620400], size 0x20000 000004C8 |CMT NAND writing block [03640400], size 0x20000 000004C8 |CMT NAND writing block [03660400], size 0x20000 000004C8 |CMT NAND writing block [03680400], size 0x20000 000004C8 |CMT NAND writing block [036A0400], size 0x20000 000004C8 |CMT NAND writing block [036C0400], size 0x20000 000004C8 |CMT NAND writing block [036E0400], size 0x20000 000004C8 |CMT NAND writing block [03700400], size 0x20000 000004C8 |CMT NAND writing block [03720400], size 0x20000 000004C8 |CMT NAND writing block [03740400], size 0x20000 000004C8 |CMT NAND writing block [03760400], size 0x20000 000004C8 |CMT NAND writing block [03780400], size 0x20000 000004C8 |CMT NAND writing block [037A0400], size 0x20000 000004C8 |CMT NAND writing block [037C0400], size 0x20000 000004C8 |CMT NAND writing block [037E0400], size 0x20000 000004C8 |CMT NAND writing block [03800400], size 0x20000 000004C8 |CMT NAND writing block [03820400], size 0x20000 000004C8 |CMT NAND writing block [03840400], size 0x20000 000004C8 |CMT NAND writing block [03860400], size 0x20000 000004C8 |CMT NAND writing block [03880400], size 0x20000 000004C8 |CMT NAND writing block [038A0400], size 0x20000 000004C8 |CMT NAND writing block [038C0400], size 0x20000 000004C8 |CMT NAND writing block [038E0400], size 0x20000 000004C8 |CMT NAND writing block [03900400], size 0x20000 000004C8 |CMT NAND writing block [03920400], size 0x20000 000004C8 |CMT NAND writing block [03940400], size 0x20000 000004C8 |CMT NAND writing block [03960400], size 0x20000 000004C8 |CMT NAND writing block [03980400], size 0x20000 000004C8 |CMT NAND writing block [039A0400], size 0x20000 000004C8 |CMT NAND writing block [039C0400], size 0x20000 000004C8 |CMT NAND writing block [039E0400], size 0x20000 000004C8 |CMT NAND writing block [03A00400], size 0x20000 000004C8 |CMT NAND writing block [03A20400], size 0x20000 000004C8 |CMT NAND writing block [03A40400], size 0x20000 000004C8 |CMT NAND writing block [03A60400], size 0x20000 000004C8 |CMT NAND writing block [03A80400], size 0x20000 000004C8 |CMT NAND writing block [03AA0400], size 0x20000 000004C8 |CMT NAND writing block [03AC0400], size 0x20000 000004C8 |CMT NAND writing block [03AE0400], size 0x20000 000004C8 |CMT NAND writing block [03B00400], size 0x20000 000004C8 |CMT NAND writing block [03B20400], size 0x20000 000004C8 |CMT NAND writing block [03B40400], size 0x20000 000004C8 |CMT NAND writing block [03B60400], size 0x20000 000004C8 |CMT NAND writing block [03B80400], size 0x20000 000004C8 |CMT NAND writing block [03BA0400], size 0x20000 000004C8 |CMT NAND writing block [03BC0400], size 0x20000 000004C8 |CMT NAND writing block [03BE0400], size 0x20000 000004C8 |CMT NAND writing block [03C00400], size 0x20000 000004C8 |CMT NAND writing block [03C20400], size 0x20000 000004C8 |CMT NAND writing block [03C40400], size 0x20000 000004C8 |CMT NAND writing block [03C60400], size 0x20000 000004C8 |CMT NAND writing block [03C80400], size 0x20000 000004C8 |CMT NAND writing block [03CA0400], size 0x20000 000004C8 |CMT NAND writing block [03CC0400], size 0x20000 000004C8 |CMT NAND writing block [03CE0400], size 0x20000 000004C8 |CMT NAND writing block [03D00400], size 0x20000 000004C8 |CMT NAND writing block [03D20400], size 0x20000 000004C8 |CMT NAND writing block [03D40400], size 0x20000 000004C8 |CMT NAND writing block [03D60400], size 0x20000 000004C8 |CMT NAND writing block [03D80400], size 0x20000 000004C8 |CMT NAND writing block [03DA0400], size 0x20000 000004C8 |CMT NAND writing block [03DC0400], size 0x20000 000004C8 |CMT NAND writing block [03DE0400], size 0x20000 000004C8 |CMT NAND writing block [03E00400], size 0x20000 000004C8 |CMT NAND writing block [03E20400], size 0x20000 000004C8 |CMT NAND writing block [03E40400], size 0x20000 000004C8 |CMT NAND writing block [03E60400], size 0x20000 000004C8 |CMT NAND writing block [03E80400], size 0x20000 000004C8 |CMT NAND writing block [03EA0400], size 0x20000 000004C8 |CMT NAND writing block [03EC0400], size 0x20000 000004C8 |CMT NAND writing block [03EE0400], size 0x20000 000004C8 |CMT NAND writing block [03F00400], size 0x20000 000004C8 |CMT NAND writing block [03F20400], size 0x20000 000004C8 |CMT NAND writing block [03F40400], size 0x20000 000004C8 |CMT NAND writing block [03F60400], size 0x20000 000004C8 |CMT NAND writing block [03F80400], size 0x20000 000004C8 |CMT NAND writing block [03FA0400], size 0x20000 000004C8 |CMT NAND writing block [03FC0400], size 0x20000 000004C8 |CMT NAND writing block [03FE0400], size 0x20000 000004C8 |CMT NAND writing block [04000400], size 0x20000 000004C8 |CMT NAND writing block [04020400], size 0x20000 000004C8 |CMT NAND writing block [04040400], size 0x20000 000004C8 |CMT NAND writing block [04060400], size 0x20000 000004C8 |CMT NAND writing block [04080400], size 0x20000 000004C8 |CMT NAND writing block [040A0400], size 0x20000 000004C8 |CMT NAND writing block [040C0400], size 0x20000 000004C8 |CMT NAND writing block [040E0400], size 0x20000 000004C8 |CMT NAND writing block [04100400], size 0x20000 000004C8 |CMT NAND writing block [04120400], size 0x20000 000004C8 |CMT NAND writing block [04140400], size 0x20000 000004C8 |CMT NAND writing block [04160400], size 0x20000 000004C8 |CMT NAND writing block [04180400], size 0x20000 000004C8 |CMT NAND writing block [041A0400], size 0x20000 000004C8 |CMT NAND writing block [041C0400], size 0x20000 000004C8 |CMT NAND writing block [041E0400], size 0x20000 000004C8 |CMT NAND writing block [04200400], size 0x20000 000004C8 |CMT NAND writing block [04220400], size 0x20000 000004C8 |CMT NAND writing block [04240400], size 0x20000 000004C8 |CMT NAND writing block [04260400], size 0x20000 000004C8 |CMT NAND writing block [04280400], size 0x20000 000004C8 |CMT NAND writing block [042A0400], size 0x20000 000004C8 |CMT NAND writing block [042C0400], size 0x20000 000004C8 |CMT NAND writing block [042E0400], size 0x20000 000004C8 |CMT NAND writing block [04300400], size 0x20000 000004C8 |CMT NAND writing block [04320400], size 0x20000 000004C8 |CMT NAND writing block [04340400], size 0x20000 000004C8 |CMT NAND writing block [04360400], size 0x20000 000004C8 |CMT NAND writing block [04380400], size 0x20000 000004C8 |CMT NAND writing block [043A0400], size 0x20000 000004C8 |CMT NAND writing block [043C0400], size 0x20000 000004C8 |CMT NAND writing block [043E0400], size 0x20000 000004C8 |CMT NAND writing block [04400400], size 0x20000 000004C8 |CMT NAND writing block [04420400], size 0x20000 000004C8 |CMT NAND writing block [04440400], size 0x20000 000004C8 |CMT NAND writing block [04460400], size 0x20000 000004C8 |CMT NAND writing block [04480400], size 0x20000 000004C8 |CMT NAND writing block [044A0400], size 0x20000 000004C8 |CMT NAND writing block [044C0400], size 0x20000 000004C8 |CMT NAND writing block [044E0400], size 0x20000 000004C8 |CMT NAND writing block [04500400], size 0x20000 000004C8 |CMT NAND writing block [04520400], size 0x20000 000004C8 |CMT NAND writing block [04540400], size 0x20000 000004C8 |CMT NAND writing block [04560400], size 0x20000 000004C8 |CMT NAND writing block [04580400], size 0x20000 000004C8 |CMT NAND writing block [045A0400], size 0x20000 000004C8 |CMT NAND writing block [045C0400], size 0x20000 000004C8 |CMT NAND writing block [045E0400], size 0x20000 000004C8 |CMT NAND writing block [04600400], size 0x20000 000004C8 |CMT NAND writing block [04620400], size 0x20000 000004C8 |CMT NAND writing block [04640400], size 0x20000 000004C8 |CMT NAND writing block [04660400], size 0x20000 000004C8 |CMT NAND writing block [04680400], size 0x20000 000004C8 |CMT NAND writing block [046A0400], size 0x20000 000004C8 |CMT NAND writing block [046C0400], size 0x20000 000004C8 |CMT NAND writing block [046E0400], size 0x20000 000004C8 |CMT NAND writing block [04700400], size 0x20000 000004C8 |CMT NAND writing block [04720400], size 0x20000 000004C8 |CMT NAND writing block [04740400], size 0x20000 000004C8 |CMT NAND writing block [04760400], size 0x20000 000004C8 |CMT NAND writing block [04780400], size 0x20000 000004C8 |CMT NAND writing block [047A0400], size 0x20000 000004C8 |CMT NAND writing block [047C0400], size 0x20000 000004C8 |CMT NAND writing block [047E0400], size 0x20000 000004C8 |CMT NAND writing block [04800400], size 0x20000 000004C8 |CMT NAND writing block [04820400], size 0x20000 000004C8 |CMT NAND writing block [04840400], size 0x20000 000004C8 |CMT NAND writing block [04860400], size 0x20000 000004C8 |CMT NAND writing block [04880400], size 0x20000 000004C8 |CMT NAND writing block [048A0400], size 0x20000 000004C8 |CMT NAND writing block [048C0400], size 0x20000 000004C8 |CMT NAND writing block [048E0400], size 0x20000 000004C8 |CMT NAND writing block [04900400], size 0x20000 000004C8 |CMT NAND writing block [04920400], size 0x20000 000004C8 |CMT NAND writing block [04940400], size 0x20000 000004C8 |CMT NAND writing block [04960400], size 0x20000 000004C8 |CMT NAND writing block [04980400], size 0x20000 000004C8 |CMT NAND writing block [049A0400], size 0x20000 000004C8 |CMT NAND writing block [049C0400], size 0x20000 000004C8 |CMT NAND writing block [049E0400], size 0xEC00 000004C8 |Programming completed. 000004C8 |Processing file: #rm346_510.21.009_prd.v26 000004C8 |HdrSize: 0x169 000004C8 |Sector to Erase: 000004C8 |BeginEraseFlash: 2 000004C8 |> RAP NAND device. 000004C8 |#CMT : 1 sector(s) CMT FLASH,MuxOneNAND area #[05420000-0759FFFF] 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |#CMT : 1 sector(s) CMT FLASH,MuxOneNAND area #[05420000-0759FFFF] 000004C8 |#CMT : 1 sector(s) Format Partition(NAND) 000004C8 |Erase complete. 000004C8 |Begin flash programming: C:\Program Files\Nokia\Phoenix\Products\RM-346\rm346_510.21.009_prd.v26 000004C8 |fileSize: 0x1FF5A74 000004C8 |availMem: 0x4E1D3000 000004C8 |[WriteBlock] Handling file with huge size 000004C8 |Master ASIC set to CMT 000004C8 |CMT NAND writing block [05420400], siz |
06-04-2013, 22:43 | #5 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | after this i flash with old jaf and it can't turn on also, later on i use nokia care suite, it can turn ON but only hang on Nokia logo... 28:05:2013 18:37 -> JAF version 1.98.66 beta5 Detected PKEY: 9000AAFB 28:05:2013 18:37 -> P-key nokia module version 01.02 28:05:2013 18:37 -> Detected JAF INTERFACE version: 01.B4, Driver version: 40000, Library version: 30107 28:05:2013 18:37 -> JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ 28:05:2013 18:37 -> JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ 28:05:2013 18:37 -> JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ 28:05:2013 18:37 -> JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ 28:05:2013 18:37 -> USB Cable Driver version: 7.1.101.0 28:05:2013 18:37 -> Changing mode...28:05:2013 18:37 -> Done! 28:05:2013 18:37 -> FILES SET FOR FLASHING: 28:05:2013 18:37 -> MCU Flash file: NONE 28:05:2013 18:37 -> PPM Flash file: NONE 28:05:2013 18:37 -> CNT Flash file: NONE 28:05:2013 18:37 -> APE Variant file: NONE 28:05:2013 18:37 -> Switching to serial... 28:05:2013 18:37 -> Powering the phone... 28:05:2013 18:37 -> Reading... 28:05:2013 18:37 -> MCU SW version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia 28:05:2013 18:37 -> HW version: 0910 28:05:2013 18:37 -> PCI version: 28:05:2013 18:37 -> RFIC version: 28:05:2013 18:37 -> DSP version: 28:05:2013 18:37 -> Retu version: 15 28:05:2013 18:37 -> Tahvo version: 22 28:05:2013 18:37 -> Production serial number: MMI828183 28:05:2013 18:37 -> Product code: 0560656 28:05:2013 18:37 -> Module code: 28:05:2013 18:37 -> Basic production code: 0552256 28:05:2013 18:37 -> Flash code: 28:05:2013 18:37 -> Order number: 28:05:2013 18:37 -> Product specific data: 28:05:2013 18:37 -> Long production SN: 0 28:05:2013 18:37 -> ATO: 28:05:2013 18:37 -> Default SN type: 28:05:2013 18:37 -> IMEI plain: 12345610654321? 28:05:2013 18:37 -> IMEI spare to net: 1A 32 54 16 60 45 23 01 28:05:2013 18:37 -> IMEI SV to net: 13 32 54 16 60 45 23 61 F4 28:05:2013 18:37 -> as you can see the imei is now gone... Last edited by frosted; 06-04-2013 at 22:49. |
06-04-2013, 22:49 | #6 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | and this is the scan logs : Phone type: RM-346 (Nokia E71) SW version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia ApeCoreSw: 510.21.009 Imei plain: 12345610654321-? Product code: 0560656 Battery voltage: 3844 mV, current: 82 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
06-13-2013, 22:52 | #7 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | is there any possibilities/chances if i downgrade it to the original firmware before upgrade and i get back the imei? if i have to purchase rpl could you help me find where to purchase? thanks for helping me find solutions |
