E71 security test failed plz help! Phone type: RM-346 (Nokia E71) SW version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia ApeCoreSw: 510.21.009 Imei plain: 35824003924546-9 Product code: 0559571 Battery voltage: 4576 mV, current: 61 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358240039245469 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
Phone type: RM-346 (Nokia E71) SW version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia ApeCoreSw: 510.21.009 Imei plain: 35824003924546-9 Product code: 0559571 Battery voltage: 4550 mV, current: 44 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358240039245469 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Scanning local SX4 Card ... No SX4 Card found. Uncaught exception: Access violation at address 10084132. Read of address B8E0DCCD SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...Wrong response to SD verify request Elapsed: 10.078 s (session timed out after 3 seconds) Retrying ... Authenticating using security server ... Connecting to server[main.mxkey.biz] ...Wrong response to SD verify request Elapsed: 10.078 s (session timed out after 3 seconds) Retrying ... Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Wrong response to SD verify request Elapsed: 10.079 s (session timed out after 3 seconds) Retrying ... Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Wrong response to SD verify request Elapsed: 10.078 s (session timed out after 3 seconds) |
all security test failed 100% solution! Many people posted in this forum about security test failed ! we know that when come security test failed solution 1. super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309) or, 2. sd repair super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309) yes! we have this solution 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory reset your phone must come back from security test failed it is 100% tasted by me. Don't forget to press thanks button ! |
