02-10-2010, 10:40 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Comilla Age: 42
Member: 304260 Status: Offline Sonork: 100.1593127 Thanks Meter: 355 | 6210 Navigator (RM-408) No certificate found in the database ! ERROR: No certificate found in the database ! Scan Phone: ----------- Code: Phone Type: RM-408 (Nokia 6210 Navigator) SW Version: V 08w35.13 10-02-09 RM-408 (c) Nokia Imei plain: 35683102141651-4 Product Code: 0570079 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! Recover CERT: -------------- Code: RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A80010ABE4A8B52FF14F3F63878069F8E56A314 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 4AA07663215C623237BF8A43EC71D55819B7DC6E Reading RAP NPC (0x168 bytes) Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! |
02-10-2010, 11:35 | #2 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | must repair this first Quote:
Code: REPAIR SIMLOCK - Determind first what SL level you got > Choose Repair SIMLOCK > Tick make SIMLOCK RPL > Click Repair SPLock Code: Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. You got Only NPC? NO PROBLEMO! Code: Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! Just in case if Recovery via Server doesn't work....... need more file about CCC,HWC and VARIANT [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, | |
ERROR: No certificate found in the database | WAJID PNR | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-13-2010 21:57 |
ERROR: No certificate found in the database ! | sumon.bd | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-01-2010 23:12 |
ERROR: No certificate found in the database ! | neo_2005 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 18 | 01-28-2010 16:18 |
no certificate found in database | rajufzr | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-26-2010 12:27 |
Invalid account. ERROR: No certificate found in the database ![old post] | vistasamir | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-21-2010 21:36 |
