Old 11-18-2009, 09:37   #1 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
Thumbs up <<<<<E71x at&t contact retailer help!!!>>>>
i have E71x at&t with phone start-up failed contact retailer can i use MX-key to repair?????
Thanks
Old 11-18-2009, 10:23   #2 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
please post bus check info here if u want good help
*if ur security is invalid,make SX4 & write pm have 1,309 and dont have 308 data after that
br
The Following 2 Users Say Thank You to mohA™ For This Useful Post:
Old 11-18-2009, 13:35   #3 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
br
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.10913, Date: 05-11-2009
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 02700111747200528E7FA1D389B18DD932D67950
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: F2C758A8B961B6FD13D988AFB6FD3C100D0D3F42
Original Imei: 35687502011332
Original Product code: 0564434
Phone Type: RM-462 (Nokia E71)
SW Version: V 08w35.03.26 04-03-09 RM-462 (c) Nokia
Imei plain: 3568750++++++++++
Product Code: 0564434
ApeCoreSw: 03.27
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356875+++++++++++
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=OPEN, DATA=00101F
sir this is bus check logs..
Old 11-18-2009, 13:41   #4 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
br
and check this also sir......
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 41.210.9.35
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
It can not connect....
Thanks
Old 11-18-2009, 13:50   #5 (permalink)
Member: 1024839
Sonork: 100.1592057
Thanks Meter: 64
try to flash with same product code again which is written behind phone and make backup rpl and pm before flashing
The Following User Says Thank You to bluerays For This Useful Post:
Old 11-18-2009, 13:55   #6 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
This phone can not be repaired without a Full RPL.
rest tries are weightless.
The Following User Says Thank You to .:SUBRATA:. For This Useful Post:
Old 11-18-2009, 13:58   #7 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
u have problem in super dongle key,so u cant access server for SX4
allready u not need SX4 or pm cause ur security is OK
but u have problem with watch dog,phone will turn off after few minutes
what u did??
whats original case ?
r u have 308 backup or any backup?
The Following User Says Thank You to mohA™ For This Useful Post:
Old 11-18-2009, 14:21   #8 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Thanks
Hello!
Make backups first PM and RPL then reset NPC and write PM file without 120 and 308 fields. Also format the handset !
BR, Ali
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
HELP 5800 startup failed contact retailer..help [ Solved ] un1x Cyclonebox 20 03-16-2010 21:26
E71x AT&T contact retailer. Can i repair? help! karikari Universalbox 6 11-20-2009 04:49
7610 contact retailer help... kecoa Nokia Hardware & Hardware Repair 3 11-16-2006 08:33
6600 Contact retailer Help???????????? wina rahman Nokia Hardware & Hardware Repair 6 11-13-2006 07:26
Contact retailer HELP ics_igrec_zet WD2 & APE (Symbian Phones) 9 09-27-2004 16:25
Page generated in 0.18526 seconds with 9 queries
