07-20-2011, 16:41 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 43
Member: 167500 Status: Offline Thanks Meter: 16 | E72 Dead after usb flashing.. (ANSWERED) I have an E72 which I needed to flash for the problem of restarting frequently.. I download the latest flash and flash the phone via selecting files from market.. After flash ends phone just vibrates and does not power on. I do not have rj45 cable for E72.. What should I do? Flash version was the same before I flashed.. Here is the log > Code: MXKEY Serial: [FT SCR2000 0] - C081922C Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Processing MCU file: rm530_054.005_prd.core.fpsx [BB5,XSR 1.6] size: 37.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: C8844EB CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 07F00118BA8C034417D11B883972CBF05B38343B CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: C8844EB Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.4\data\backup\BB5_35272404353273_CERT.rpl). CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 227.31 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 660D81A4455F6F7F9B81D5D10F5336B14B50635E (RAP Certificate 175 v.1) sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent Programming completed in 8.594 s Processing PPM file: rm530_054.005_04.01_German_QW1_prd.rofs2.fpsx [BB5,XSR 1.6] size: 76.43 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 81 MB CMT MuxOneNAND area [07CC0000-0CDBFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 17.203 s Processing PPM file: rm530_054.005_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.55 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 25.75 MB CMT MuxOneNAND area [0CDC0000-0E77FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 1.735 s Processing CNT file: RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx [BB5,XSR 1.6] size: 2.58 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Erase size: 4 MB CMT MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.641 s Processing CNT file: rm530_054.005_U007.000_prd.uda.fpsx [BB5,XSR 1.6] size: 9.99 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 265.75 MB CMT MuxOneNAND area [0E780000-1F13FFFF] Flash programming ... Programming completed in 3.766 s Total time for flashing process(boot+erase+write) was 1 min 2.203 s Waiting for device boot up ... Device found: nmwcdc\Nokia E72 USB Phonet, PORT_ID: 12D1836E Verifying communication to device OK. Phone Type: RM-530 (Nokia E72-1) SW Version: V ICPR82_10w22.10.1 01-02-11 RM-530 (c) Nokia Imei plain: ------------------(protected) Product Code: 0587336 Battery voltage: 3728 mV, current: 166 mA ApeCoreSw: 054.005 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: ------------------(protected) Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
07-21-2011, 13:36 | #4 (permalink) | |
Registered User Join Date: Mar 2005 Location: kolkata , india Age: 41
Member: 128335 Status: Offline Thanks Meter: 8 | Quote:
boss u cant do it only with the mxkey as E72 is a high end model and so the hashs which are needed to be calculated will not be possible in ufs or jaf via mxkey but the same can be done easily on the mxbox without any problem so basically all of us would end up buying the mxbox for the new hashes as the ufs and other interfaces are still behind schedule for their support for the new hashes. This is the reason even i am buying a mxbox so that atleast for flashing nokia my life would be simple . all the best | |
The Following User Says Thank You to rss3183 For This Useful Post: |
07-21-2011, 14:49 | #5 (permalink) | |
Member: 167500 Status: Offline Thanks Meter: 16 | Quote:
Thankss again. | |
07-25-2011, 10:16 | #6 (permalink) |
Member: 167500 Status: Offline Thanks Meter: 16 | Hello again.. I received my HTi box and E72 fbus cable.. Here is the log of scan : Code: Phone Type: RM-530 (Nokia E72-1) SW Version: V ICPR82_10w22.10.1 01-02-11 RM-530 (c) Nokia Imei plain: 35272404353273-7 Product Code: 0587336 Battery voltage: 4451 mV, current: 85 mA ApeCoreSw: 054.005 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35272404353**** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
07-25-2011, 10:31 | #7 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | press repair SD, follow all on screen... make sure you are using CURRENT version, 3.5 rev.1.2 and synced. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
07-25-2011, 10:39 | #8 (permalink) |
Member: 167500 Status: Offline Thanks Meter: 16 | Thanks for answer here ıs the log of Repair SD : Code: MXKEY Serial: [MxKey HTI FLASHER INTERFACE 4] - C081922C Using device: HTI BOX, FW ver: 00.08 Driver: uhci:hub:ccgp:HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Product: V ICPR82_10w22.10.1 01-02-11 RM-530 (c) Nokia ApeCoreSw: 054.005 Using cached productData. PUBLIC ID: 07F00118BA8C034417D11B883972CBF05B38343B PRIVATE ID: 0037E00BFD92DA779CF1FFDE0A1C187F4BF9317E Updating SUPERDONGLE_KEY ...OK Authenticating to SUPERDONGLE ... SUPERDONGLE authorized :)! Code: Phone Type: RM-530 (Nokia E72-1) SW Version: V ICPR82_10w22.10.1 01-02-11 RM-530 (c) Nokia Imei plain: 35272404353---- Product Code: 0587336 Battery voltage: 4488 mV, current: 73 mA ApeCoreSw: 054.005 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35272404353---- Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
07-25-2011, 11:05 | #9 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, ok, this is your final step. example based on different rapu based phones. ignore any difference logs. - if problem still remain, flash the phone once more. - if problem still remain after flash, i have no idea. check phone HW. BR |
07-25-2011, 12:10 | #10 (permalink) |
Member: 167500 Status: Offline Thanks Meter: 16 | This is the log of nand erase Code: CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 07F00118BA8C034417D11B883972CBF05B38343B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.16.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.16.0 revision: 3.0 size: 0xC66A1 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flash programming ... Programming completed in 1.796 s I try to flash the phone but it stops at the half of the mcu. Here is the log: Code: MXKEY Serial: [MxKey HTI FLASHER INTERFACE 4] - C081922C Using device: HTI BOX, FW ver: 00.08 Driver: uhci:hub:ccgp:HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Processing MCU file: rm530_054.005_prd.core.fpsx [BB5,XSR 1.6] size: 37.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 07F00118BA8C034417D11B883972CBF05B38343B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.16.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.16.0 revision: 3.0 size: 0xC66A1 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 227.31 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 660D81A4 [RAP Certificate 175 v.1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent Error while programming [00] at 0x02E80400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: 82 10 6D 80 CMT PAPUBKEYS is blank/erased. Is there a way to rewrite it.. Thanks for your help my friend. Good support.Good team.. |
07-25-2011, 12:36 | #11 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, all dead phone caused by incomplete mcu flashing will get this logs "CMT PAPUBKEYS is blank/erased." nothing to worry. !! you didn't synchronize your mxkey software. please do it first. !! you didn't update your HTI firmware, please do it first. - try to flash by usb. un mark 'safe flash', mark 'fast flash' all should be OK.. unless your flash chip is dying BR |
07-26-2011, 01:32 | #14 (permalink) | |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
the main thing on such corrupted fs area , is rap3nand erase. hwk fix after you did nand erase by mxkey. always use the latest version. anyway, your problem is fixed, congratulation BR | |
07-26-2011, 21:16 | #15 (permalink) | |
I have an 5130c(RM-495) which says contact service and simlock data corrupted. I know that I need Rpl for this but I do not know where to buy it and is it possible to make it with mxkey? Thanks.. | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
