06-29-2010, 16:06 | #1 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 735092 Status: Offline Thanks Meter: 17 | e72 flashing error fbus logs Version from phone: 023.002 Version from file: 023.002 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35523903670666_BA CK.rpl). RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1A700013E06C03447F7AE5DDFFFD1100E1A4B808 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E TransmissionMode: DDR&TX2 No RAP Flash Chip Detected Processing file: rm530_023.002_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 96.45 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 227.31 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0E77FFFF] Formating Partition ... erased in 1.234 s Flash programming ... CMT PAPUBKEYS: 660D81A4455F6F7F9B81D5D10F5336B14B50635E (RAP Certificate 175 v.1) written. Error while programming [00] at 0x05D80400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 7 min 44.641 s RX Buffer: B372 usb logs Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm530_023.002_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 96.45 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: CFD9B27 RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1A700013E06C03447F7AE5DDFFFD1100E1A4B808 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.48.0 revision: 3.0 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 ERROR: Secondary boot not responding ! Flashing terminated with error(s) in 3.297 s RX Buffer: 37786200 |
06-29-2010, 20:02 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | try change your "Flash Loader" folder to 9.x.x.xxx in config menu then retry your operation br, |
The Following User Says Thank You to Andra For This Useful Post: |
06-29-2010, 20:33 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
BR, curvenger. | |
08-08-2010, 08:35 | #4 (permalink) | |
Freak Poster Join Date: May 2003 Age: 48
Member: 29870 Status: Offline Thanks Meter: 24 | Quote:
I have this problem with new E72 too and I used 09.50.25.2 loader but got error and here is flashing log with MX-KEY Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm530_031.023_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 100.24 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2A100204F58703443245B04362C375EEF3410E75 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E TransmissionMode: DDR&TX2 No RAP Flash Chip Detected Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 227.31 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0E77FFFF] Formating Partition ... erased in 1.203 s Flash programming ... CMT PAPUBKEYS: 660D81A4455F6F7F9B81D5D10F5336B14B50635E (RAP Certificate 175 v.1) written. Error while programming [00] at 0x05CC0400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 7 min 43.219 s RX Buffer: B372 How/where can i get newer flash loader. Thanks for any help. | |
08-08-2010, 09:08 | #5 (permalink) | |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | Quote:
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
