04-21-2012, 10:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | e75 SECURITY_TEST failed! (ANSWERED) SW version: V ICPR72_10w04.vic02 18-06-10 RM-412 (c) Nokia ApeCoreSw: 211.12.01 Imei plain: 35955701859580-7 Product code: 0575867 Battery voltage: 4660 mV, current: 33 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359557018595807 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Phone type: RM-412 (Nokia E75) SW version: V ICPR72_10w04.vic02 18-06-10 RM-412 (c) Nokia ApeCoreSw: 211.12.01 Using cached productData. PUBLIC ID: 0920010BE2950052FB6DAB4380902F7B47EB06B2 PRIVATE ID: E3063B663DA2E0FE41ECD9F579B5B5C5EB2FADC8 SUPERDONGLE authorized ! vWriting PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 10 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 10 bytes written. - Key: 7, size 214 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 10 bytes written. - Key: 16, size 208 bytes written. - Key: 18, size 208 bytes written. - Key: 20, size 208 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 10 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 208 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 376 bytes written. - Key: 35, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 39, size 36 bytes written. - Key: 40, size 16 bytes written. - Key: 41, size 182 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 36 bytes written. - Key: 44, size 182 bytes written. - Key: 45, size 182 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 3.484 s |
04-21-2012, 10:21 | #2 (permalink) |
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | but still same LPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359557018595807 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
04-21-2012, 15:31 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - try other PM. Load PM, press Super SD Auth. Pop-up confirmation; answer is NO. Press Write. On any failed, post self test logs and BB5 certificate validation logs |
The Following User Says Thank You to gbluez For This Useful Post: |
04-21-2012, 17:34 | #5 (permalink) |
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.50.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: C29DF97EC55AABC28ACB9029D2E577CA237E7179 Reading CMT NPC (0x190 bytes). Original Product Code: 0577045 Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Product Code: 0577045 CCC seems to be valid Reading CMT HWC (0xD4 bytes). Product Code: 0577045 HWC seems to be valid |
04-21-2012, 20:14 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
3330 v 412 fail with dfs 211 | denn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-19-2001 22:06 |
In wintesla 3310, what does cobba parrarel failed means | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-18-2001 16:05 |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
