Old 02-06-2010, 02:06   #1 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
easy way to repair your Superdongle Key with MXkey
hi to all my friends
here is an easy way to repair SD key without getting SECURITY_TEST failed!" and "warning: SD authorized but verify failed!" problem
maybe this can help a lot of our forum users
1- make backup RPL Imei (only NPC value)
2- reset NPC
3- repair SD
4- restore Backup imei
good luck
and here is a proof for full procedure with N73
http://www.zshare.net/download/722031470daf832f/
WBR adelkaha25
The Following 11 Users Say Thank You to adelkaha25 For This Useful Post:
Old 02-06-2010, 02:25   #2 (permalink)
Crazy Poster
Member: 574515
Thanks Meter: 7
Can you post the log here ?
Old 02-06-2010, 02:27   #3 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
sir you have a video proof not only log
but if you need this proof I will reproduce the problem and give you all log
see the video and you will be happy believe me
WBR adelkaha25
Old 02-06-2010, 02:33   #4 (permalink)
DJ Morgan's Avatar
Member: 120827
Thanks Meter: 130
not working with e65 (rm-208)
Old 02-06-2010, 02:35   #5 (permalink)
Registered User
Member: 232346
Thanks Meter: 28
Please post logs...to see is to believe
Old 02-06-2010, 02:39   #6 (permalink)
Crazy Poster
Member: 574515
Thanks Meter: 7
But not working with 5200 :
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Old 02-06-2010, 02:42   #7 (permalink)
Member: 1133675
Sonork: 100.1604417
Thanks Meter: 18
MXKEY repair SD is fake
Old 02-06-2010, 02:46   #8 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
I will reproduce the problem in my phone and i will post all log so be patient an you will see.
i have all backup
Old 02-06-2010, 02:54   #9 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
ok here is log
first time
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v38.1 19-01-07 RM-133 (c) Nokia.
Imei plain: 35956801522545-4
Product Code: 0541312
ApeCoreSw: V 3.0704.1.0.1 19-01-2007 RM-133
ApeVariant: V 3.0704.1.0.1-01 19-01-2007 RM-133
Language Pack:
English,02 Uk
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359568015225454
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
making backup rpl (only NPC)
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 3102E267AF2FFCA97293F5366B47732E4D61B5A1
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 20700116E3F10154120F51193AB6CF074670859B
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Flash Imei: 35956801522545
NPC_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35956801522545_BA CK.rpl"
log after reset NPC
Imei plain: 12345610654321-?
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei plain is invalid !!!
Imei net: 12345610654321?
Counter: 0/3, 0/10
SD repair
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 05wk47v38.1 19-01-07 RM-133 (c) Nokia.
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 8.641 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_12345610654321-_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
log after SD repair
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
log write imei backup
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT VARIANT ...OK
Certificate programmed successfully !
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
here is all log my friends
WBR adelkaha25
The Following 10 Users Say Thank You to adelkaha25 For This Useful Post:
Old 02-06-2010, 02:54   #10 (permalink)
Member: 616091
Thanks Meter: 27
how about for 5220xm, its the same solution.?
Old 02-06-2010, 02:56   #11 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
after reset NPC write full PM and all will be fine
try and poste because this is the way i solve my problem
good luck
Old 02-06-2010, 02:58   #12 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
you can try this solution maybe it will work.
good luck
Old 02-06-2010, 02:59   #13 (permalink)
Member: 328416
Thanks Meter: 42
Not working to 7210c......
Old 02-06-2010, 03:04   #14 (permalink)
Member: 175542
Thanks Meter: 8
2- reset NPC
3- repair SD
good luck
WBR adelkaha25
not working.test by me..still security test failed
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1260001885620058ABCCB4C7031AAD682DB03859
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
FlashID0: 00EC 22FE - 0000 6921 [Samsung K8S5615ETA,256 Mbits] type: NOR,RAP
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
NPC verified Ok.
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.00 19-08-08 RM-217 (c) Nokia.
Imei plain: 356960---------
Product Code: 0537677
Language Pack:
- not available.
SIMLOCK_TEST passed
TimeStamp: 2008-09-23T13:43:03Z
SW Version: 07.00
Variant Version: 020
ProductProfile: RM217_0537677_07.00_020.spr
Simlock: 0537677_simlock.bin
Imei net: 356960---------
Counter: 0/3, 0/10
Old 02-06-2010, 03:08   #15 (permalink)
Member: 1028136
Thanks Meter: 18
mx-key is, can maximize their performance or not ..?
easy way to repair config key 0000 SL1/SL2/SL3 without rpl RamSon83 Nokia Base Band 5 ( BB-5 ) 270 12-08-2011 23:13
easy way to repair config key 0000 SL1/SL2/SL3 without rpl hello mats the easy way t sureshplaza Nokia Base Band 5 ( BB-5 ) 12 05-23-2010 22:46
easy way to repair config key 0000 SL1/SL2/SL3 without rpl hello mats the easy way t h_mobiles Nokia Base Band 5 ( BB-5 ) 6 01-13-2010 20:53
::: Easy way to repair config key 0000 SL1/SL2/SL3 without rpl ::: indikait Nokia Base Band 5 ( BB-5 ) 2 10-02-2009 21:39
Page generated in 0.27953 seconds with 9 queries
