10-05-2012, 04:29 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 806190 Status: Offline Thanks Meter: 0 | Nokia 6275i not flashing MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0***** Using device: HTI, FW ver: 00.50, SN: 01***** Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 002D8A6A:3B8ADA60 ASIC type: 6 UEM Imei: 0111***** Flash Imei: 0111***** RPL saved to "C:\mobileEx\3.5\data\backup\RPL\01111011109_BACK. rpl" Processing MCU file: BL190V0500_rus_ruim.nep [TIKU BT2,TIKU ALGORITHM] size: 12.28 MB Supported Ids: 1051, 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 002D8A6A:3B8ADA60 Area [00000000-0001FFFF] erased in 0.875 s Area [00020000-00DFFFFF] erased in 1 min 34.515 s Flash programming ... Programming completed in 1 min 6.344 s File processed in 2 min 51.984 s Processing CNT file: BL190_05w21_58_02_01_REL04_rus_ruim.image_fa [TIKU BT2,TIKU MON CSM] size: 7.83 MB Supported Ids: 1051, 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Превышен таймаут семафора Error while programming [2E] at 0x00000020, Result: 0000 flashing terminated ! I can`t flash... Any help? |
10-05-2012, 04:47 | #2 (permalink) |
No Life Poster Join Date: Dec 2007 Location: DHARAMPUR<GUJRAT>INDIA
Member: 646646 Status: Offline Sonork: 100.1664464 Thanks Meter: 240 | i think hardware problem ram and flash light hit or clean pcb any try to sucseess .... chk voltage of vflash this is cdma phone dear |
