Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 02-27-2010, 12:04   #1 (permalink)
Member: 1066865
ERROR: could not connect to server!
Connecting to server[main.mxkey.biz] ...Connection refused
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
The Following User Says Thank You to sunny_luthras99 For This Useful Post:
Old 02-27-2010, 12:07   #2 (permalink)
Riz000's Avatar
Member: 777415
Sonork: 1589702
No SX4 Card found.
server problem wait again try after some time
Old 02-27-2010, 12:07   #3 (permalink)
great4nara's Avatar
Member: 352189
Yes Same Problem here.
Calculating SUPERDONGLE using security server ...
Connection refused
Connection refused
Connection refused
Old 02-27-2010, 14:47   #4 (permalink)
Member: 462076
Sonork: 100.1586314
Same Problem to me also sir
Old 02-27-2010, 14:50   #5 (permalink)
Riz000's Avatar
Member: 777415
Sonork: 1589702
check erver list and select online SX4 server and try again
The Following 2 Users Say Thank You to Riz000 For This Useful Post:
Old 02-27-2010, 15:12   #6 (permalink)
TURNING POINT's Avatar
Member: 71721
Sonork: 100.106320
check server sx4#2 china(chinanet) working fine
The Following User Says Thank You to TURNING POINT For This Useful Post:
Old 02-27-2010, 15:36   #7 (permalink)
fflyx's Avatar
Member: 1208833
Sonork: 100.1590402
Give that error
Old 02-27-2010, 16:24   #8 (permalink)
nawaz_ideal's Avatar
Member: 633558
Sonork: 100.1606487
same problem here.......................
Old 02-27-2010, 17:36   #9 (permalink)
Member: 219015
Yes china server work fine.
Old 02-27-2010, 17:53   #10 (permalink)
nbaster's Avatar
Member: 428223
Sonork: 100.1578585
Connection refused
Connection refused
Connection refused
same problem here
Old 02-27-2010, 19:47   #11 (permalink)
dharyadi's Avatar
Member: 369678
yes use china server
Using cached productData[0B500009B5757F56DDEA4B128A3D133DEEE2DFC1] ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 12 bytes written.
- Key: 1, size 70 bytes written.
- Key: 2, size 70 bytes written.
- Key: 3, size 70 bytes written.
- Key: 4, size 70 bytes written.
- Key: 5, size 276 bytes written.
- Key: 6, size 276 bytes written.
- Key: 7, size 276 bytes written.
- Key: 8, size 276 bytes written.
- Key: 9, size 384 bytes written.
- Key: 10, size 384 bytes written.
- Key: 11, size 384 bytes written.
- Key: 12, size 384 bytes written.
- Key: 13, size 384 bytes written.
- Key: 14, size 384 bytes written.
- Key: 15, size 384 bytes written.
- Key: 16, size 384 bytes written.
- Key: 17, size 32 bytes written.
- Key: 19, size 16 bytes written.
- Key: 20, size 32 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 4.391 s
Old 02-27-2010, 20:21   #12 (permalink)
Member: 242933
yes china server work fine
Old 02-27-2010, 20:35   #13 (permalink)
fflyx's Avatar
Member: 1208833
Sonork: 100.1590402
Can you unlock BlackBerry by china server?
Old 02-27-2010, 21:46   #14 (permalink)
ELILSON RAMOS's Avatar
Member: 961994
oque should be now, straight off the server, how can they solve it?
Calculating NCK using security server ...
Connection refused
Connection refused
Connection refused
Old 02-28-2010, 03:24   #15 (permalink)
Member: 741567
how can you select china server manually??
also need to repair sd now
tnx
ERROR: could not connect to server! (Fixed) Sinta MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 10 03-09-2010 12:24
ERROR: could not connect to server! (Solved) ayaz ali MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 3 03-02-2010 12:13
ERROR: could not connect to server! laduka MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-28-2010 07:51
HELP.. Could not connect to server, please check connection or firewall ! n2roy MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 12-21-2009 15:36
Page generated in 0.35348 seconds with 11 queries
