Old 04-04-2010, 06:40   #1 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Error Flashing Dead 6300
Got this error while trying to flash 6300 dead usb.
any ideas about it ?
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
Processing file: rm217__07.30.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3
RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
RAP EM0 ID: 00000232
RAP EM1 ID: 00000352
RAP PUBLIC ID: 19B00212ED2C8C56311C66C530AB09B5FBAAF5B1
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
RAP ROM ID: 191EC665DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x38C0 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 3252BC99
[ADL] Verifying communication to device OK.
Erase skipped.
Flash programming ...
Error while programming [00] at 0x00000400, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 23.953 s
TIA
Old 04-04-2010, 08:41   #2 (permalink)
Member: 163788
Thanks Meter: 20
reinstall latest nokia drive
Old 04-04-2010, 08:49   #3 (permalink)
nepoleanl's Avatar
Member: 836540
Thanks Meter: 71
use new flashloader which flash loader version are you using?
Old 04-04-2010, 09:14   #4 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
i did that, even tried with phoenix, error on after flash process.....
Old 04-04-2010, 09:15   #5 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Tried with, 7.21, 7.30 and 57.20... same with all.
what specific hardware shall i check if its hw problem??
Old 04-04-2010, 09:23   #6 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Below is log from phoenix:-
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
All operations completed
Product flashing failed.
Old 04-04-2010, 10:39   #7 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
Try with good quality fbus cable or use ufc cable.
Old 04-04-2010, 10:57   #8 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Tried with 3 cables already and UFC is not available around me yet .
Old 04-04-2010, 10:59   #9 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
just flash with jaf
it will be ok
Old 04-04-2010, 11:15   #10 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Originally Posted by rakesh15 View Post
just flash with jaf
it will be ok
With JAF
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Sending CMT HASH for PMM_CONF
Sending CMT HASH for SBIF_CONF
Processing F:\Mobiles\Nokia\MX Flash BB5\RM-217\rm217__07.30.ppm_mea1...
Processing F:\Mobiles\Nokia\MX Flash BB5\RM-217\rm217__07.30.image_b_white_era_pl_white_v3_128 _128...
Error sending cmd data...
Error writing cmt..
Old 04-04-2010, 11:36   #11 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Bro, you are talking about the phones firmware here, flashloader is different from the phones firmware, first change youre flashloader like this, in Nokia Module go to Config->Directory->Flash update directory and click .. beside it. in the flash folder, select 09.50.25.2 or 8.30.12.34536 whichever you're not using. BTW don't flash you're phone with firmware version 57.20 unless it is the original firmware or else you will end up with SL3 phone which is which is impossible to unlock at the moment.
Erase skipped.
TIA
First change youre flashloader and if the problem still exist, it seems like a hardware problem, check flash ic first.
Old 04-04-2010, 11:40   #12 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
With JAF
Error writing cmt..
Bro.its hardwer problem...... rehot flash ic. hope your problem solve.
Old 04-04-2010, 11:51   #13 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Erase skipped.
TIA
Old 04-04-2010, 11:59   #14 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Thanks for the info bro, after changing the boot loader it foes a litle further and shows this msg now:-
Erase skipped.
Error while programming [00] at 0x00020000, Result: 0000
Flashing terminated with error(s) in 22.328 s
Old 04-04-2010, 12:02   #15 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Erase skipped.
TIA
Big Help Error flashing Dead K550im said4 FuriousGold 4 02-15-2008 12:38
Page generated in 0.27262 seconds with 9 queries
