Old 03-27-2010, 10:08   #1 (permalink)
Member: 175273
Thanks Meter: 68
ERROR: Missing SD BLOCK or PM corrupted !
when I try to use SD authority the soft gives thisd message :
Using device: J.A.F, FW ver: 01.B4
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12662(19-03-2010)
Product: V 07.23 17-07-09 RM-436 (c) Nokia
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 082002147D6E5750569CCA85709F566C3A0B8D84
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM]  version: 1.31.0 revision: 0.0 size: 0x297E0
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35574302337815
Original Product code: 0566904
Bluetooth ID: 0022FCBA2C37
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35574302337815-7
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3557430xxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 03-27-2010, 10:10   #2 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
Bro first repair sd after super sd and write pm with part [1] and [309]
Yr problem will solve 110%
Ravi Mobile.
The Following User Says Thank You to ravi mobile For This Useful Post:
Old 03-27-2010, 10:23   #3 (permalink)
Member: 175273
Thanks Meter: 68
Ravi Mobile.
how to do please ?
can you give me the processs??
Old 03-27-2010, 11:22   #4 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
Bro. first repair sim lock after repair sd and then repair super sd
The Following 2 Users Say Thank You to ravi mobile For This Useful Post:
(error: Missing sd block or pm corrupted) lets talk about this: Ligalig MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 10-04-2010 12:10
ERROR: Missing SD BLOCK or PM corrupted ravi mobile MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-26-2010 09:07
ERROR: Missing SD BLOCK or PM corrupted ! wyong88 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-16-2010 09:17
5130c ERROR: Missing SP BLOCK or PM corrupted ![Not supported yet] dhanrhage_24 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-20-2010 05:28
GDFS Error: Target GDFS block does not exist mzatara Cruiser Suite 1 08-16-2005 18:19
Page generated in 0.18509 seconds with 9 queries
