02-16-2010, 10:49 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Manila
Member: 1079935 Status: Offline Thanks Meter: 511 | (error: Missing sd block or pm corrupted) lets talk about this: WHERES THE PROBLEM??? WHAT DO YOU THINK??? (ERROR: MISSING SD BLOCK OR PM CORRUPTED) * SERVER * JAF BOX * BUGS i need your opinion or suggestion about this and kindly correct me if i am wrong.. THANKZ GSMFORUM! THIS IS MY HOME.... |
02-16-2010, 11:05 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | brother if wanna to repair sd then go imei and securty option and click imei rebuild and click om sd auth this is right way to repair sd after sd repair u need to write pm with super sd auth |
02-16-2010, 11:09 | #5 (permalink) |
02-16-2010, 11:11 | #6 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1150025 Status: Offline Thanks Meter: 70 | TRY wiyh UFS interface!!!! if you are using JAF as interface then sd will not process properly.. AM i Correct! |
The Following User Says Thank You to beanbagtit For This Useful Post: |
02-16-2010, 11:12 | #7 (permalink) | |
Member: 1079935 Status: Offline Thanks Meter: 511 | Quote:
i already repair this sir and its done. its finish... evrytime i use jaf box got this error or message but when i change it and use UFS box its work all fine. i want to know is, where's the problem or where's from come this error? server? jaf box? still bugs? comments... comments... comments... i am confusing. | |
02-16-2010, 11:16 | #9 (permalink) |
Member: 1150025 Status: Offline Thanks Meter: 70 | sometimes it also function to jaf but it a matter of conn`ecting and reconnecting those boxes... to process properly.. maybe that is the restriction of jaf new update... but for flashing still jaf is best because of its bootloader property unlike ufs. |
ERROR: Missing SD BLOCK or PM corrupted ! | ROMAB | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-27-2010 11:22 |
ERROR: Missing SD BLOCK or PM corrupted | ravi mobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-26-2010 09:07 |
ERROR: Missing SD BLOCK or PM corrupted ! | wyong88 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-16-2010 09:17 |
5130c ERROR: Missing SP BLOCK or PM corrupted ![Not supported yet] | dhanrhage_24 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-20-2010 05:28 |
