Old 01-17-2012, 22:32   #1 (permalink)
Member: 82807
Thanks Meter: 18
ERROR: RSA PublicKey is not available ! (ANSWERED)
im trying to read hash of nokia c6 from usb and im following all steps as i DONT have a fbus cable so im getting this error
Phone type: RM-612 (Nokia C6-00)
Product code: 059B6W6
SW version: v 10.0.024
LanguagePkg version: v 10.0.02410.0.024.10.0110.0.024.203.04
Waiting for USB device removal ...
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1DF0010AD16302527FA4E4D7B6B553832CEFD4F7
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.1 size: 0x37C0
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
PRIVATE ID: 23AA29DA3FD72D3435189E1A766C974D6EB2D17E
SEC ROM CRC: 3E691FF8
Waiting for Phonet device ...
Waiting for device boot up ...
Phone not found, retrying ...
Device connected: nmwcdc\Nokia C6-00 USB Phonet, PORT_ID: 2B747549
Verifying communication to device OK.
Verifying secure data ...OK
HASH: D2F106899C9B346747611AB62E157C9E171A63D8
Please use FBUS connection
Old 01-18-2012, 13:19   #2 (permalink)
Member: 768239
Thanks Meter: 3
Please use FBUS connection !
i am having same problem but i just installed older version mx key asd worked ok
Old 01-20-2012, 00:07   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Hi,
i can not reproduce the same error on my pc. i do not know what could be the problem.
reported this case to Alim.
- older version doesn't have RSA verification, on RARE case, sha could be wrong.
Old 01-20-2012, 01:49   #4 (permalink)
Member: 543935
Thanks Meter: 59
i have to many same errors,,, now i not have screenshots or logs, but dayling i haved this error, ERROR: RSA PublicKey is not available !
or
phone not supported in this interface.
Old 01-23-2012, 15:44   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
yes,
can try to use FBUS. but i see this message also on RAPU phones posted by users.
- on RAPIDO:
buscheck first with "HOT BOOT" set from config, unmark cold boot.
try to read sha again.
many users didn't noticed, which is UNLOCKING and which is repairing.
need to see buscheck logs, please post it
http://forum.gsmhosting.com/vbb/f550...ailed-1417515/
Old 02-13-2012, 10:48   #6 (permalink)
Member: 768239
Thanks Meter: 3
Originally Posted by gbluez View Post
Hi,
hi
the problem only shows up on ver 3.5 1.7. when reading sha by usb if i uninstall 3.5 1.7 and install 3.5 1.6 i can read phones ok with usb and it gives me sha file ok .
its a but of a pain in the but having to keep installing old version to read sha and then installing new version to calculate code . there must be a problem its been with the last 6 phones i have tryed with usb to read sha file.
logs below for latest atempt
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C080BBD5
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 000016BF
Connection status: EHCI:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.73
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Phone type: RM-618 (Nokia X2-00)
SW version: V 04.80 03-08-10 RM-618 (c) Nokia
Product code: 059B8Q2
SW version: V 04.80 - 03-08-10 - RM-618 - (c) Nokia
LanguagePkg version: 0 - 03-08-10 - RM-618 - (c) Nokia - C
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000007E4B7A42DF53CBBD6AD6B5358B1457
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.34.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.34.0 revision: 2.1 size: 0x98F18
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 100CCF7
FUR: Adding Asic CMT as client OK.
PRIVATE ID: 75FE445524CCFF341AA1116E9D8B029A89C6778F
E-FUSE: 2180B300
SEC ROM CRC: BDDE7A3A
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Device connected: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 3188EA5
Verifying secure data ...HASH: B26F33998F0B262D27FC0B366300B2C59B019CA5
Old 02-13-2012, 10:57   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
- connect the phone on USB (Alive), choose Phonet device as interface., press scan.
- backup rpl first.
- read sha after. will be done OK
Old 02-21-2012, 18:04   #8 (permalink)
Member: 768239
Thanks Meter: 3
- backup rpl first.
hi gave this a try, connet phonet , read phone , backup simlock rpl,
but got same error .
any other ideas apart from me reinstalling 3.5 1.6 and reading it that way .
Old 02-23-2012, 16:53   #9 (permalink)
Member: 768239
Thanks Meter: 3
yes,
- on RAPIDO:
bus check log as req
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Battery voltage: 3874 mV
Phone type: RM-721 (Nokia C2-01)
Product code: 059G527
SW version: V 10.50 - 07-01-11 - RM-721 - (c) Nokia
LanguagePkg version: 0 - 07-01-11 - RM-721 - (c) Nokia - C
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 2C50020AF3EF104994CD8E106EDB4F1FC9AEAFBD
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D3F88FD
CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
Original Imei: 35865004013211
Original Product code: 059G527
Bluetooth ID: 6CA780AB671A
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Device connected: nmwcdc\Nokia C2-01 USB Phonet, PORT_ID: 20A1FB31
SW version: V 10.50 07-01-11 RM-721 (c) Nokia
Imei plain: 35865004013211-0
Battery voltage: 3840 mV, current: 202 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00IIIIRR0301035602, ver: 001.002
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358650040132110
Version: SIMLOCK SERVER
Provider: Hutchison 3G UK Ltd. , Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 8000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=23420F [United Kingdom-Hutchison 3G UK Ltd. ]
BLOCK2: 1=CLOSED(MCCMNC), DATA=23594F [United Kingdom-Hutchison 3G UK Ltd ]
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Page generated in 0.24750 seconds with 10 queries
