Old 12-14-2011, 22:17   #1 (permalink)
franco127's Avatar
Member: 1232024
Thanks Meter: 9
ERROR when launch MobileEX 3.5 rev 1.6 *ANSWERED
when launch mobileex show me the error in MxKey Executable, after "runtime Error 261 at 1008 cadf",after " a dynamic link library (DLL) process attach failed, after "A dymanic link library (dll) inizialization routine failed (opeation aborted)",after error in Mxkey Executable,after " Exception EINTERROR in module mobileex.exe at 001485f2.Sorry,there was some problem in mobileex.lib please reinstall application or check for updates to fix the problem."
can you help me? i've the same erron in precedent version!thanks
Old 12-14-2011, 22:38   #2 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
uninstall mobileEx
delete folder mobileEx in your hard drive
install again aplication and DO NOT SYNC FILES only update HTI/MXBox
Old 12-14-2011, 22:47   #3 (permalink)
franco127's Avatar
Member: 1232024
Thanks Meter: 9
i have only old orange keyreader form mxkey!no box hti!
Old 12-14-2011, 22:50   #4 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
this version works only with hti
if you have mxkey you must install older version 3.5 ver 1.3 or older
Old 12-14-2011, 22:52   #5 (permalink)
franco127's Avatar
Member: 1232024
Thanks Meter: 9
this versione is outdate and don't work!says please update!
Old 12-14-2011, 22:57   #6 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
propably they blocked older version
you must buy hti or live it and buy another nokia tool.
you can compare your mxkey with new hti without card which is cheaper (49 usd) and use it with new update
Old 12-14-2011, 23:06   #7 (permalink)
franco127's Avatar
Member: 1232024
Thanks Meter: 9
ok ,but if i want to use only the bb,htc o huawey apps?what is the problem?
Old 12-14-2011, 23:14   #8 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
try to uninstall mobileEx and delete hole MobileEx folder
install version which work before you install last version
maybe it will work
Old 12-14-2011, 23:28   #9 (permalink)
franco127's Avatar
Member: 1232024
Thanks Meter: 9
i've already tried but nothing appened!
Old 12-15-2011, 00:55   #10 (permalink)
Member: 543935
Thanks Meter: 59
you need install runtime and netframework 3,5 and 4. or more simply reinstall windows, you have other many problems with windows. clean all registry fragmenteds, ... etc etc ..
Old 12-18-2011, 12:21   #11 (permalink)
franco127's Avatar
Member: 1232024
Thanks Meter: 9
i've tried but nothing appened!shown the same error!i've updated the net. framework at 4. version and runtime but nothing!
Old 12-18-2011, 13:26   #12 (permalink)
Member: 543935
Thanks Meter: 59
copy and paste from ohter pc the mobilex folder and, run mobil ex 2 times the 2 tim will work, if will not work, your hd is bad, have old registries saved in your pc, or ..... i dont now your problem is very rare format the pc i take 1 hour..
Old 12-19-2011, 07:44   #13 (permalink)
Member: 1504377
Thanks Meter: 3
MobileEX 3.5 rev 1.6 athor draiv estol hti problam shol 1000%
Old 12-19-2011, 09:07   #14 (permalink)
Member: 683579
Thanks Meter: 225
same problem here my mx key
Old 12-21-2011, 01:40   #15 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
delete c:\mobileex.
install 3.5rev1.6 with all driver option ticked.
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.21604 seconds with 9 queries
