03-09-2012, 13:56 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Error while flash a wd2 phone 6600 NHL-10 (ANSWERED) Using device: HTI, FW ver: 00.50, SN: 0000B580 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 06000000-067FFFFF ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: w3_st_i.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5818 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 004101EA:2984DA7E ASIC type: 5 UEM Imei: 35664000****** Flash Imei: 35664000****** RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35664000463871_BA CK.rpl" Processing MCU file: NHL105530.C1 [WD2 BT2,WD2 ALGORITHM,WD2 CBUS BT] size: 22.21 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 06000000-067FFFFF ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: w3_st_i.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5818 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 004101EA:2984DA7E Algorithm: w3_cbusb.fia [WD2 CBUS BT] version: 4.76.0 revision: 0.7 size: 0x27 Supported Ids: 1080, 1081 flashing terminated ! Phone was okey before flashing but hang some time so i decide to flash it and now phone is dead completely here is bus check logo MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C085A4D1 Using device: HTI, FW ver: 00.50, SN: 0000B580 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 06000000-067FFFFF ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: w3_st_i.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5818 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 004101EA:2984DA7E ASIC type: 5 UEM Imei: 35664000******* Flash Imei: 35664000******* MasterCode: 5250064510 RPL saved to "C:\mobileEx\3.5\data\backup\35664000******_BACK.r pl" |
03-11-2012, 02:02 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | initial problem: your phone is hang while opening gallery, right? mark: skip BT. flashing will be done, but gallery problem will be still there. you will need to fix BT module (hardware) |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
