Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 05-13-2010, 15:01   #1 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
experts give solution
7210c sl repair give following error.
Plz give solution
The Following User Says Thank You to J@zz For This Useful Post:
Old 05-13-2010, 15:45   #2 (permalink)
curvenger's Avatar
Member: 1014781
Plz give solution
bro, do you get this error everytime or just once, once i faced this same error and restarting Mxkey helps.
Old 05-13-2010, 15:49   #3 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
thanks for support,
gives error at sl repair.
thanks
Old 05-13-2010, 16:23   #4 (permalink)
Member: 759477
Sonork: 100.1618763
bro i sugest you to reinstall window & use latest version
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Old 05-13-2010, 16:38   #5 (permalink)
Y.P.Y's Avatar
Member: 1010502
Sonork: whats this?!
thanks for support,
thanks
Copy Backup data
Uninstall MXkey Suite
Delete MobileEx Folder from C:\MobileEx
install MobileEx 3.4 Again
The Following User Says Thank You to Y.P.Y For This Useful Post:
Old 05-13-2010, 19:09   #6 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
@ Y.P.Y & sumayia_khan
TRIED NOT WORKING.....
ANY OTHER SOLUTION
Old 05-13-2010, 19:23   #7 (permalink)
wisdom001's Avatar
Member: 676315
First of all which version how you using, if is lower version use 3.4rev1 and if the same problem still occur check cable if still, uninstall setup and delete from c:mobileex and restart pc and install and try, if problem persist try other box like hwk mt box or use usb flashing through jaf,mx key and mt box i believe your problem will be solve, if not try hardware.
Old 05-13-2010, 19:37   #8 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
IT IS CLEARLY SEEN IN 1ST POST THAT I M USING 3.4rev1. TRY WITH JAF, MAX KEY ALSO. NOT WORKING...
GIVE SOLUTION ONLY AFTER READING MY 1st POST......
AND I M SURE ACCESS VIOLATION ERROR IS NOT HARDWARE PROBLEM MAN.......
Old 05-13-2010, 20:20   #9 (permalink)
alasmmar's Avatar
Member: 231153
just tick make sim lock rpl and try
Old 05-13-2010, 20:23   #10 (permalink)
wisdom001's Avatar
Member: 676315
Try mx key with another pc or try another mx key dongle to know weather your mx key or pc and post.
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
Pic Solution jan Nokia Hardware & Hardware-Repair Area 8 10-11-2010 10:56
5110 version 5.24 solution lampin Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-14-1999 06:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-08-1999 09:14
Page generated in 0.30782 seconds with 12 queries
