ExtBusc "DEAD DEAD DEAD DEAD" DCT4 (ANSWERED) If you can interpret the following, please I need your help in reviving these 2 phones. Seems like ExtBusc is saying "DEAD DEAD DEAD". Are these phones really dead beyond repair? Scan button cannot receive signal from phone. I retrieve the logs from using Bus Check button. ** Model 3120/RH-19 ** Using device: HTI BOX, FW ver: 00.08 Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011) ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: DEAD DEAD DEAD DEAD DEAD DEAD DEAD DEAD Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C0B2ED:2984DA60 ASIC type: 2 UEM Imei: 35624400xxxxxx Flash Imei: 356244xxxxxxxx MasterCode: 7A632BF89E RPL saved to "C:\mobileEx\3.5\data\backup\356244001xxxxx_BACK.r pl" Phone not responding ! **************************************** ** Model: 1661 2b/RH-121 ** Using device: HTI BOX, FW ver: 00.08 Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: DEDE DEAD ADDE DEAD DEDE DEDE FFFF FFFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0003BCBA:DA3BDA66 ASIC type: 11 UEM Imei: 012447006xxxxx Flash Imei: 01244700690501 MasterCode: 1165437225 RPL saved to "C:\mobileEx\3.5\data\backup\012447006xxxxx_BACK.r pl" Phone not responding ! Anybody? Thanks....:confused: |
just reflash again :p bad post from stupid user :p |
How can it flash when "Phone is not responding!"? |
Sorry bro.... u got mah patience...! |
look here u can save rpl UEM Imei: 35624400xxxxxx Flash Imei: 356244xxxxxxxx MasterCode: 7A632BF89E RPL saved to "C:\mobileEx\3.5\data\backup\356244001xxxxx_BA CK.r pl" Phone not responding ! and here ASIC type: 11 UEM Imei: 012447006xxxxx Flash Imei: 01244700690501 MasterCode: 1165437225 RPL saved to "C:\mobileEx\3.5\data\backup\012447006xxxxx_BA CK.r pl" Phone not responding ! u phones no dead use auther tools flash it with . jaf . universal . hwk and post resultat saved rpl = accept flash = alive ok welcome |
** Model 3120/RH-19 ** I tried that already.. recovering from backup rpl. Same thing. Model 1661 2b/RH-121... Please refer to THIS post! thanks.... |
bro you did not try to flash your two phones. only scan works if your phone fully on only. flash with mcu, ppm and cnt good luck |
hi, ExtBUSC: DEAD DEAD DEAD DEAD DEAD DEAD DEAD DEAD means, you or some one else did "reset data1" to this phone by using mxkey. it's kind of signature from us ;) to revive: - full erase by 'get addr', select all, don't tick 'safe erase' do 'erase'. - flash the phone fully. - rebuild imei, write pm, unlock. |
Wakakakakak..... Just did what you said gbluez. All is well now. A Lesson learned. Fastest way to do things right is to learn from your own mistakes. Yes I did reset data and full erase w/out completing the process. Thanks to you all.... I'll be back for more Q's. this thing is fun.... |
