02-08-2010, 17:18 | #1 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Bosnia and Hercegovina @ Saraj Age: 40
Member: 45907 Status: Offline Thanks Meter: 8 | Again can not unlock SL2 phones after update to 1.4 simple 6220c can not unlock tried on 2 pcd once used JAF once UFS no luck Code: Imei net: 356398024424739 Version: SIMLOCK SERVER Provider: One Connect, Country: Austria Counter: 0/3, 0/10 CONFIG_DATA: 2320500000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23205F, DATA=23205F Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V ICPR72_08w46.1 12-12-08 RM-328 (c) Nokia ApeCoreSw: 04.13 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot [rapidov11_2nd.fg](0x3AC0 bytes) ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating using security server ... Reading Simlock info ... Imei net: 356398024424739 Version: SIMLOCK SERVER Provider: One Connect, Country: Austria Counter: 0/3, 0/10 CONFIG_DATA: 2320500000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23205F, DATA=23205F |
02-09-2010, 04:55 | #4 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Australia, HK. Age: 39
Member: 538861 Status: Offline Sonork: 100.1578309 Thanks Meter: 117 | why change it if was working perfect? yesterday I unlocked many 6120c, e63 and 6300 all perfect unlock quick without needing cyclone box however today after update already my first 2 of the 6120 SIMLOCK CORRUPTED I will not be putting codes into 1000+ handsets, direct unlock should be more stable. looks like its back to cyclone box for me. |
02-09-2010, 05:13 | #5 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | Quote:
check how many sl damaged etc etc in mxkey section lately beore u risk that bro | |
02-09-2010, 05:33 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
how many phone have repaired by MXKEY still crab to drop MXKEY ? have i show link on our sticky post ?? better leave our thread area,if dont want support our user . please cry in other section. @ppl who have problem with UNLOCK please know your problem first before execute . br, | |
The Following 2 Users Say Thank You to Andra For This Useful Post: |
02-09-2010, 05:42 | #10 (permalink) |
Member: 538861 Status: Offline Sonork: 100.1578309 Thanks Meter: 117 | As i said before, yesterday before I update mxkey these unlocks work perfect but after update when I do exact same unlock procedure as before the soft give me error and tell me my simlock is corrupted. The update is the only thing that has changed during this time. Handsets are all same batch, 100% brand new and all in perfect working order before unlock. How can I now fix these phones? |
02-09-2010, 05:42 | #11 (permalink) | |
thanks br | |
02-09-2010, 05:47 | #12 (permalink) | |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | your are old people in forum and know where is "sticky" post last i told about Quote:
[MXKEY - INFO] Successfully Unlocked/repaired Phones By MXKey can u check by your self, are in your screen doesn't have "search" button there ? br, | |
02-09-2010, 05:51 | #13 (permalink) |
Member: 538861 Status: Offline Sonork: 100.1578309 Thanks Meter: 117 | I already tried solution posted by another product supporter in regards to 6300 corrupt simlock before posting on here but this procedure did not work for me. |
02-09-2010, 07:35 | #14 (permalink) | |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | post with details info please, log info or other,that make easy to analisys REPAIR SIMLOCK - Determind first what SL level you got > Choose Repair SIMLOCK > Tick make SIMLOCK RPL > Click Repair SPLock note : SIMLOCK repair not supported SL3 phone Quote:
2.Just in case if Recovery via Server doesn't work....... 3.[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, | |
02-09-2010, 08:47 | #15 (permalink) |
Member: 538861 Status: Offline Sonork: 100.1578309 Thanks Meter: 117 | I dont have log anymore unless the soft make this in txt document somewhere? the phones are 6120c (SL2) I will try again to repair the phones and post result shortly. Thanks. |
Motorola A1000 can not unlock ...Phone not detected | kosta25 | Motorola P2k | 0 | 10-29-2009 08:08 |
Can not unlock any phone give me this error | MUTUAL | Cyclonebox | 11 | 07-30-2009 18:42 |
mt-box team 6500s-1 i can not unlock it with new sl2 | uburo22 | MT-BOX | 3 | 03-07-2009 06:49 |
Toshiba 803T - 902T - 903T - 904T unlocker can not unlock 2006 Phones | POP_JUB | VygisToolbox | 3 | 07-26-2007 18:00 |
