Old 01-09-2010, 08:03   #1 (permalink)
ashvin's Avatar
Member: 106700
Thanks Meter: 47
fail to get key problem for unlocking n79/ n96
Imei net: 356387025537110
Version: SIMLOCK SERVER
Provider: Virgin, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2343000000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F
Backup already exist.
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11472, Date: 27-11-2009
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
Sending SecondaryBoot(0x3AC0 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x190C bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x190 bytes) ...OK
Sending Certificate(0x1A20 bytes) ...OK
Calculating NCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, Login ...
failed to get key!
Reading Simlock info ...
Counter: 0/3, 0/10
pls sort this out
The Following User Says Thank You to ashvin For This Useful Post:
Old 01-09-2010, 09:04   #2 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
both the models are not sopurted yet by mxkey
Old 01-09-2010, 09:10   #3 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
Thumbs up Faild to get key
Originally Posted by ashvin View Post
imei net: 356387025537110
version: Simlock server
provider: Virgin, country: United kingdom
counter: 0/3, 0/10
config_data: 2343000000000000
profile_bits: 8000000000000000
block 1: 1=locked (mcc+mnc): 23430f, data=23430f
backup already exist.
Using device: J.a.f, fw ver: 01.b1
library version: 1.0.0.11472, date: 27-11-2009
root key hash: Caeebb65d3c48e6dc73b49dc5063a2ee
rom id: A8c1d6713e691ff8
sending secondaryboot(0x3ac0 bytes) ...ok
sending preloader(0x2e4 bytes) ...ok
sending rom(0x190c bytes) ...ok
sending securityblock(0x2000 bytes) ...ok
sending simlockbinary(0x190 bytes) ...ok
sending certificate(0x1a20 bytes) ...ok
calculating nck using security server ...
Connecting to server[main.mxkey.biz] ...ok, login ...
Failed to get key!
Reading simlock info ...
counter: 0/3, 0/10
pls sort this out
hi brother u need to old setup
this problem is face by manu users
solve with old exe
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 01-09-2010, 09:18   #4 (permalink)
jr astigin's Avatar
Member: 757159
Thanks Meter: 467
just try with old mx-key which is 3.2.........and try again the unlock
Old 01-10-2010, 15:11   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
reupdate module,
br,
Old 01-10-2010, 15:26   #6 (permalink)
princegsm's Avatar
Member: 82815
Thanks Meter: 160
Exclamation i can unlock 5800
Originally Posted by MobileEx-Team View Post
reupdate module,
br,
i have update but not unlock 5800 plais help me
Imei net: 357988031866903
Provider: Orange + France Telecom Itineris, Country: France
Counter: 0/3, 0/10
CONFIG_DATA: 2080100000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 20801F, DATA=20801F
BLOCK 2: 1=LOCKED (MCC+MNC): 20801F, DATA=20801F
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
ROM ID: 4B9B75103E691FF8
WriteDevice failed: Failed to read/write device
Sending NCK code ...
Trying NCK lock 7 ...
Old 06-18-2010, 05:19   #7 (permalink)
dilshann's Avatar
Member: 1093564
Thanks Meter: 326
help plz n79 not unlocked
Imei net: 356387025******
Counter: 0/3, 0/10
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
Product: V ICPR72_08w44.1 24-11-08 RM-348 (c) Nokia
ApeCoreSw: 11.049
Old 10-29-2011, 09:44   #8 (permalink)
fadhel's Avatar
Member: 39196
Thanks Meter: 126
use older mx-key firmware
Old 10-29-2011, 10:53   #9 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
see the post date before giving any reply
N85 failed to get key! rvs MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 01-05-2010 18:20
nokia 5800-d can not unlock failed to get key! m_tahir1 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 12-22-2009 17:23
Failed to Get key a38 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 12-10-2009 06:50
n96 failed to get key! k-emal MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 12-06-2009 15:29
N96 unlock: Failed to get Lock Key (6, 5) [SOLVED] CooLer55555 Cyclonebox 38 09-11-2009 09:35
Page generated in 0.21065 seconds with 9 queries
