07-19-2012, 08:12 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Indonesia Age: 40
Member: 1687184 Status: Offline Sonork: 100.1621473 Thanks Meter: 24 | failed flash 6600s RM-414 try to restore backup failed. Now if I buschek just shows : Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085**** Using device: HTI, FW ver: 00.50, SN: 0001**** Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1910000C66365750125F1D6F0185D54BE866D2A8 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Original Imei: 00000000000000 Original Product code: Code: TransmissionMode: DDR&TX2 Processing MCU file: rm414__06.55.mcusw [BB5,XSR 1.5] size: 23.30 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Storing certificate [NPC, R&D, CCC, HWC] ...OK Erase size: 25.37 MB CMT FLASH,NOR area [00000000-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [01780000-0197FFFF] CMT FLASH,NOR area [00140000-0177FFFF] erased in 5.839 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 03 CD 00 |
07-19-2012, 10:09 | #6 (permalink) |
Member: 1687184 Status: Offline Sonork: 100.1621473 Thanks Meter: 24 | when restore npc.rpl just show like this : Code: Imei: 35638302789949 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085**** Using device: HTI, FW ver: 00.50, SN: 0001**** Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1910000C66365750125F1D6F0185D54BE866D2A8 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Prog.status for Asic CMT ... NAND: Status reported bad blocks. |
07-20-2012, 04:08 | #13 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
http://forum.gsmhosting.com/vbb/f626...t-you-1354385/ But from the logs, i also almost sure you have cable problem. Please verify with other good working phone to check that your cable is 101% working. BR | |
07-20-2012, 07:45 | #14 (permalink) | |
Member: 1687184 Status: Offline Sonork: 100.1621473 Thanks Meter: 24 | Quote:
still try with other cable ... | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
