12-04-2009, 09:30 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: venezuela Age: 32
Member: 1027249 Status: Offline Thanks Meter: 24 | Failed to Get key |
12-04-2009, 10:33 | #3 (permalink) |
Freak Poster Join Date: Dec 2006 Location: gsmworld of moderetso .
Member: 410890 Status: Offline Thanks Meter: 88 | post your logs......but i suggest to check you nk library if its up to date because even you use a new version library is not updated so need to update is manualy......to get stable communication...... |
12-10-2009, 06:04 | #4 (permalink) | |
Member: 1027249 Status: Offline Thanks Meter: 24 | Quote:
Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 7340400023927779 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 73404F, DATA=73404F BLOCK 2: 1=LOCKED (MCC+MNC): 74807F, DATA=74807F BLOCK 3: 1=LOCKED (MCC+MNC): 21407F, DATA=21407F BLOCK 4: 1=LOCKED (MCC+MNC): 21402F, DATA=21402F BLOCK 5: 1=LOCKED (MCC+MNC): 33403F, DATA=33403F BLOCK 6: 1=LOCKED (MCC+MNC): 70503F, DATA=70503F BLOCK 7: 1=LOCKED (MCC+MNC): 74000F, DATA=74000F BLOCK 8: 1=LOCKED (MCC+MNC): 71030F, DATA=71030F BLOCK 9: 1=LOCKED (MCC+MNC): 71402F, DATA=71402F BLOCK 10: 1=LOCKED (MCC+MNC): 73002F, DATA=73002F BLOCK 11: 1=LOCKED (MCC+MNC): 732123, DATA=732123 BLOCK 12: 1=LOCKED (MCC+MNC): 72207F, DATA=72207F BLOCK 13: 1=LOCKED (MCC+MNC): 70604F, DATA=70604F BLOCK 14: 1=LOCKED (MCC+MNC): 71606F, DATA=71606F Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11472, Date: 27-11-2009 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[main.mxkey.biz] ...OK, Login ... failed to get key! Reading Simlock info ... Imei net: 359348020148144 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 7340400023927779 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 73404F, DATA=73404F BLOCK 2: 1=LOCKED (MCC+MNC): 74807F, DATA=74807F BLOCK 3: 1=LOCKED (MCC+MNC): 21407F, DATA=21407F BLOCK 4: 1=LOCKED (MCC+MNC): 21402F, DATA=21402F BLOCK 5: 1=LOCKED (MCC+MNC): 33403F, DATA=33403F BLOCK 6: 1=LOCKED (MCC+MNC): 70503F, DATA=70503F BLOCK 7: 1=LOCKED (MCC+MNC): 74000F, DATA=74000F BLOCK 8: 1=LOCKED (MCC+MNC): 71030F, DATA=71030F BLOCK 9: 1=LOCKED (MCC+MNC): 71402F, DATA=71402F BLOCK 10: 1=LOCKED (MCC+MNC): 73002F, DATA=73002F BLOCK 11: 1=LOCKED (MCC+MNC): 732123, DATA=732123 BLOCK 12: 1=LOCKED (MCC+MNC): 72207F, DATA=72207F BLOCK 13: 1=LOCKED (MCC+MNC): 70604F, DATA=70604F BLOCK 14: 1=LOCKED (MCC+MNC): 71606F, DATA=71606F | |
12-10-2009, 06:05 | #5 (permalink) |
Member: 1027249 Status: Offline Thanks Meter: 24 | Imei net: 359348020148144 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 7340400023927779 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 73404F, DATA=73404F BLOCK 2: 1=LOCKED (MCC+MNC): 74807F, DATA=74807F BLOCK 3: 1=LOCKED (MCC+MNC): 21407F, DATA=21407F BLOCK 4: 1=LOCKED (MCC+MNC): 21402F, DATA=21402F BLOCK 5: 1=LOCKED (MCC+MNC): 33403F, DATA=33403F BLOCK 6: 1=LOCKED (MCC+MNC): 70503F, DATA=70503F BLOCK 7: 1=LOCKED (MCC+MNC): 74000F, DATA=74000F BLOCK 8: 1=LOCKED (MCC+MNC): 71030F, DATA=71030F BLOCK 9: 1=LOCKED (MCC+MNC): 71402F, DATA=71402F BLOCK 10: 1=LOCKED (MCC+MNC): 73002F, DATA=73002F BLOCK 11: 1=LOCKED (MCC+MNC): 732123, DATA=732123 BLOCK 12: 1=LOCKED (MCC+MNC): 72207F, DATA=72207F BLOCK 13: 1=LOCKED (MCC+MNC): 70604F, DATA=70604F BLOCK 14: 1=LOCKED (MCC+MNC): 71606F, DATA=71606F Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11472, Date: 27-11-2009 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[main.mxkey.biz] ...OK, Login ... failed to get key! Reading Simlock info ... Imei net: 359348020148144 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 7340400023927779 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 73404F, DATA=73404F BLOCK 2: 1=LOCKED (MCC+MNC): 74807F, DATA=74807F BLOCK 3: 1=LOCKED (MCC+MNC): 21407F, DATA=21407F BLOCK 4: 1=LOCKED (MCC+MNC): 21402F, DATA=21402F BLOCK 5: 1=LOCKED (MCC+MNC): 33403F, DATA=33403F BLOCK 6: 1=LOCKED (MCC+MNC): 70503F, DATA=70503F BLOCK 7: 1=LOCKED (MCC+MNC): 74000F, DATA=74000F BLOCK 8: 1=LOCKED (MCC+MNC): 71030F, DATA=71030F BLOCK 9: 1=LOCKED (MCC+MNC): 71402F, DATA=71402F BLOCK 10: 1=LOCKED (MCC+MNC): 73002F, DATA=73002F BLOCK 11: 1=LOCKED (MCC+MNC): 732123, DATA=732123 BLOCK 12: 1=LOCKED (MCC+MNC): 72207F, DATA=72207F BLOCK 13: 1=LOCKED (MCC+MNC): 70604F, DATA=70604F BLOCK 14: 1=LOCKED (MCC+MNC): 71606F, DATA=71606F |
12-10-2009, 06:46 | #7 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Quote:
mobileEx_setup_v3.2_rev5.4.exe ur problem will 100% solve. i had same problem in unlocking 5800. an i solved by unlocl with this version/. | |
fail to get key problem for unlocking n79/ n96 | ashvin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 10-29-2011 10:53 |
Nokia E71 Unlock Failed - BB5 Unlock Failed -> Failed to get Lock Key (6, 5) | ronzinio | Cyclonebox | 6 | 01-15-2010 14:34 |
N85 failed to get key! | rvs | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 01-05-2010 18:20 |
nokia 5800-d can not unlock failed to get key! | m_tahir1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-22-2009 17:23 |
n96 failed to get key! | k-emal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-06-2009 15:29 |
