03-29-2010, 12:39 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Failed to write imei..????? ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 009B7DCF:2984DA7E ASIC type: 5 UEM Imei: 35480401321668 Connecting to server ...OK, Login ... Hello C080AA39, you have 2010 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35480401321668.RP L" ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 009B7DCF:2984DA7E Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-51 (Nokia 7610) SW Version: V 2006_wk41 11-10-06 RH-51 (c) Nokia. Imei plain: ??????????????-? Product Code: 0514537 Cellular System: GSM ASIC ID: 0x1081, type: 5 Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCKLIB VERSION 2.29 Counter: 0/3, 0/10 CONFIG_DATA: 1B1B0EB001BEA2A0 PROFILE_BITS: 8F8E0BD76AE79FFB SIMLOCK_DATA corrupted! also simlock currupted....How to solve this ??? |
5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] | x_gsm | Cyclonebox | 22 | 02-14-2010 15:17 |
lg kg110 fail to write imei | rajesh_rajesh | Infinity-Box | 2 | 07-20-2009 23:46 |
X480 Failed To Write Imei????????? | GSMLover2010 | NSPRO | 9 | 05-05-2008 10:05 |
X480 Failed To Write Imei????????? | GSMLover2010 | UST Pro II | 12 | 06-19-2007 13:13 |
Operation failed when trying to write imei on D720 | Burnt Cobba | NSPRO | 0 | 12-20-2006 00:34 |
