Fix Bug !!! Version from phone: 06.10 Version from file: 06.60 Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000352 PUBLIC ID: 04600113E73800580D32C51CDEE25EB5252D760F ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 002F - 0000 6921 [AMD S29NS256N,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x20 bytes). Reading RAP CCC (0x0 bytes). Reading RAP HWC (0x0 bytes). Flash Imei: 35977000567345 NPC_DATA saved OK VARIANT_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35977000XXXXXXX_B ACK.rpl" Processing file: rm115__06.60.mcusw as MCU [BB5,BB5 ALGORITHM] size: 13.00 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000352 PUBLIC ID: 04600113E73800580D32C51CDEE25EB5252D760F ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 002F - 0000 6921 [AMD S29NS256N,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A Total erase size: 14.87 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-002DFFFF] CMT NOR area [002E0000-00EDFFFF] CMT NOR area [00EE0000-00EF7FFF] CMT NOR area [00EF8000-00EFFFFF] erased in 52.875 s Flash programming ... CMT PAPUBKEYS: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A (Rap certificate 21 v1) written. Programming completed in 2 min 1.453 s Processing file: rm115__06.60.ppm_c as PPM [BB5,BB5 ALGORITHM] size: 4.25 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000352 PUBLIC ID: 04600113E73800580D32C51CDEE25EB5252D760F ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 002F - 0000 6921 [AMD S29NS256N,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A Total erase size: 5.37 MB CMT NOR area [00F00000-0145FFFF] erased in 17.641 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00FF4000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 5 min 34.000 s RX Buffer: C7012D0103CD00 not the cable the phone is not a program error, using an old version presents no prolem..... :(:(:( |
same problem with this phone use jaf |
the prolem is not jaf is the program I tried and so n.boxes,are all phones flashing using fbus |
???????????? Mxkey team ?????????? |
hello, thanks for your support. this kind problem,will be fixing by coder already send info about this kind problem hopefully as soon will be fix br, |
and plz tell to coder mainly problem with ufs boxes dont works at all with dct4 and bb5 flash, rpl, in dct4++ unlock and other posteds here , has passed 3 months without solution |
yes.....i agree....mxkey must fix the problem first before release new update......;) |
