Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-05-2010, 21:16   #1 (permalink)
WILUNLOCK's Avatar
Member: 726741
Sonork: WILUNLOCK >>> 100.1596195
Fix Bug !!!
Version from phone: 06.10
Version from file: 06.60
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000352
PUBLIC ID: 04600113E73800580D32C51CDEE25EB5252D760F
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 002F - 0000 6921 [AMD S29NS256N,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x20 bytes).
Reading RAP CCC (0x0 bytes).
Reading RAP HWC (0x0 bytes).
Flash Imei: 35977000567345
NPC_DATA saved OK
VARIANT_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35977000XXXXXXX_B ACK.rpl"
Processing file: rm115__06.60.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 13.00 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Total erase size: 14.87 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00020000-0007FFFF]
CMT NOR area [00080000-000DFFFF]
CMT NOR area [00100000-001FFFFF]
CMT NOR area [00200000-002DFFFF]
CMT NOR area [002E0000-00EDFFFF]
CMT NOR area [00EE0000-00EF7FFF]
CMT NOR area [00EF8000-00EFFFFF]
erased in 52.875 s
Flash programming ...
CMT PAPUBKEYS: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A (Rap certificate 21 v1) written.
Programming completed in 2 min 1.453 s
Processing file: rm115__06.60.ppm_c as PPM
[BB5,BB5 ALGORITHM] size: 4.25 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Total erase size: 5.37 MB
CMT NOR area [00F00000-0145FFFF]
erased in 17.641 s
Error chk C7012D0103CD
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00FF4000, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 5 min 34.000 s
RX Buffer: C7012D0103CD00
not the cable the phone is not a program error, using an old version presents no prolem
Old 03-05-2010, 21:22   #2 (permalink)
alasmmar's Avatar
Member: 231153
same problem with this phone use jaf
Old 03-05-2010, 21:26   #3 (permalink)
WILUNLOCK's Avatar
Member: 726741
the prolem is not jaf is the program I tried and so n.boxes,are all phones flashing using fbus
Old 03-06-2010, 14:44   #4 (permalink)
WILUNLOCK's Avatar
Member: 726741
???????????? Mxkey team ??????????
Old 03-06-2010, 20:03   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
hello,
thanks for your support.
this kind problem,will be fixing by coder
already send info about this kind problem
hopefully as soon will be fix
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 03-07-2010, 04:47   #6 (permalink)
Member: 1091622
and plz tell to coder mainly problem with ufs boxes dont works at all with dct4 and bb5 flash, rpl, in dct4++ unlock and other posteds here , has passed 3 months without solution
Old 03-07-2010, 05:42   #7 (permalink)
pritech's Avatar
Member: 1194626
Originally Posted by MobileEx-Team View Post
hello,
br,
yes.....i agree....mxkey must fix the problem first before release new update......
FIX FIX FIX bugs ayhen42 Cyclonebox 1 01-03-2010 04:03
When will be update witch fix bug in 7.1 can someone tell ?? wgmmmx Cruiser Suite 11 12-16-2005 08:56
GT please fixed bug flashing 3220 in v.2.0895 hard Griffin 12 08-10-2005 13:56
ALCATEL BE4 FIX BUG SOLUTION - 3 FINGERS PROBLEM, SHUT DOWN DURIND INCOMING CALL ARC Alcatel TCL Hardware Repair Section 0 09-05-2001 12:47
Page generated in 0.30302 seconds with 11 queries
