flash nokia rm-809 someone help me flash rm-809 nokia lumina by navifirm downloaded the flash, the flash will until the end, but the cell only vibrates see picture below if I'm right with flash thank you claudemir MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0857xxx Using device: Nokia DLOAD (Recovery) Connection status: No device connected Driver: WinUsb, ver: 1.0.0.4 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Recovery mode started. Remove USB cable from device. Turn off the phone Make sure to have fully charged battery. Press and hold 'Volume Up' button, Press 'power' button and insert USB cable. Waiting for Nokia DLOAD device ... OSBL Alive ! Performing hand shake... OSBL Protocol: 1.0.1.0, version: 5.0.1.1, build: 10, timestamp: 29/9/2011 13:38:56 Processing file: OSBL, RM803_12w12_2_prod_generic_nokia_osbl.esco Loading programming files... certificate: nokia_osbl.mbn.cert, size: 480 Bytes image: nokia_osbl.mbn, size: 936.54 KB Programming data to mobile device ... Hash block count: 1, type: Sha256 Programming completed in 1.313 s File processed in 1.375 s, status: 0 Processing file: ModemSw, RM803_12w12_2_prod_generic_amss.esco Loading programming files... certificate: amss.mbn.cert, size: 477 Bytes file: amss.mbn.enc, size: 15.86 MB Programming data to mobile device ... Hash block count: 1, type: Sha256 Programming completed in 27.250 s File processed in 27.313 s, status: 0 Processing file: ModemSw, RM803_12w12_2_prod_generic_adsp.esco Loading programming files... certificate: adsp.mbn.cert, size: 477 Bytes file: adsp.mbn.enc, size: 5.36 MB Programming data to mobile device ... Hash block count: 1, type: Sha256 Programming completed in 8.703 s File processed in 8.782 s, status: 0 Processing file: WindowsPhone, RM809_12122_prod_201_01_boot.esco Loading programming files... certificate: boot.img.cert, size: 1.59 KB image: boot.img, size: 383.12 MB Programming data to mobile device ... Hash block count: 25, type: Sha256 Programming completed in 3 min 39.734 s File processed in 3 min 39.828 s, status: 0 Processing file: UserArea, RM803_12w12_2_prod_generic_user_area_erase.esco Loading programming files... certificate: user_area_erase.cert, size: 424 Bytes Erasing image area done. File processed in 2.750 s, status: 0 Restoring modem SW... Modem SW restored. Total time for flashing process was 4 min 21.297 s Restart mobile device...OK Waiting for device after restart ... |
Right way But use newest firmware same product code. BR. Arsalan gsm2000. |
rm 809 can be downgraded to rm 803 and unlocked http://forum.gsmhosting.com/vbb/f550...ghlight=rm-809' |
