Old 10-18-2012, 00:32   #1 (permalink)
Member: 376659
Thanks Meter: 5
flash nokia rm-809
someone help me flash rm-809 nokia lumina
by navifirm downloaded the flash, the flash will until the end, but the cell
only vibrates
see picture below if I'm right with flash
thank you
claudemir
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0857xxx
Using device: Nokia DLOAD (Recovery)
Connection status: No device connected
Driver: WinUsb, ver: 1.0.0.4
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Recovery mode started.
Remove USB cable from device.
Turn off the phone
Make sure to have fully charged battery.
Press and hold 'Volume Up' button, Press 'power' button and insert USB cable.
Waiting for Nokia DLOAD device ...
OSBL Alive !
Performing hand shake...
OSBL Protocol: 1.0.1.0, version: 5.0.1.1, build: 10, timestamp: 29/9/2011 13:38:56
Processing file: OSBL, RM803_12w12_2_prod_generic_nokia_osbl.esco
Loading programming files...
certificate: nokia_osbl.mbn.cert, size: 480 Bytes
image: nokia_osbl.mbn, size: 936.54 KB
Programming data to mobile device ...
Hash block count: 1, type: Sha256
Programming completed in 1.313 s
File processed in 1.375 s, status: 0
Processing file: ModemSw, RM803_12w12_2_prod_generic_amss.esco
certificate: amss.mbn.cert, size: 477 Bytes
file: amss.mbn.enc, size: 15.86 MB
Programming completed in 27.250 s
File processed in 27.313 s, status: 0
Processing file: ModemSw, RM803_12w12_2_prod_generic_adsp.esco
certificate: adsp.mbn.cert, size: 477 Bytes
file: adsp.mbn.enc, size: 5.36 MB
Programming completed in 8.703 s
File processed in 8.782 s, status: 0
Processing file: WindowsPhone, RM809_12122_prod_201_01_boot.esco
certificate: boot.img.cert, size: 1.59 KB
image: boot.img, size: 383.12 MB
Hash block count: 25, type: Sha256
Programming completed in 3 min 39.734 s
File processed in 3 min 39.828 s, status: 0
Processing file: UserArea, RM803_12w12_2_prod_generic_user_area_erase.esco
certificate: user_area_erase.cert, size: 424 Bytes
Erasing image area done.
File processed in 2.750 s, status: 0
Restoring modem SW...
Modem SW restored.
Total time for flashing process was 4 min 21.297 s
Restart mobile device...OK
Waiting for device after restart ...
Old 10-18-2012, 19:21   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,137
Right way But use newest firmware same product code.
BR.
Arsalan gsm2000.
Old 11-20-2012, 09:08   #3 (permalink)
kxach85's Avatar
Member: 888943
Sonork: 100.1615584
Thanks Meter: 239
rm 809 can be downgraded to rm 803 and unlocked lumia 710 rm-809 unlock done by this steps!!!!!!'
Page generated in 0.17812 seconds with 7 queries
