Old 09-18-2009, 18:24   #1 (permalink)
Member: 12671
Thanks Meter: 3
Flash RM-493 to RM-346
Is it Posible to Flash RM-493 with EU flash files.
I ready tryed but get Contact retailer.
Could someone help me with this?
BR,
Hakim
Old 09-18-2009, 19:08   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can u add log info here ?
br,
Old 09-18-2009, 19:11   #3 (permalink)
powerplay83's Avatar
Member: 753732
Thanks Meter: 252
First Make FULL Backup of Imei and PM
After select RM-346 Flashfiles and flash by FBUS Cable
Old 09-19-2009, 09:28   #4 (permalink)
Member: 12671
Thanks Meter: 3
The log of flashing the phone.
Version from phone: 100.21.108
Version from file: 200.21.118
Using device: J.A.F, FW ver: 01.B1
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031105
EM1 ID: 00000296
EM2 ID: 00000B22
PUBLIC ID: 12600108F4750052F2063EC5209CABA240E76820
ASIC MODE ID: 00
ROOT KEY HASH: F2D76DFAFD66C7F195F278417DF05888
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0040 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0
RAP PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35682702321431
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.2\data\backup\RPL\BB5_3568270232143 1_BACK.rpl"
Processing file: rm346_200.21.118_prd.c00 as MCU
[BB5,XSR 1.5] size: 64.00 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103
RAP Data :
EM1 ID: 00000296
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 64.00 KB
CMT ONENAND area [00040000-007FFFFF]
CMT ONENAND area [00A00000-0759FFFF]
CMT ONENAND area [0F1C0000-0F8BFFFF]
Format NAND
Format NAND
Format NAND
erased in 0.813 s
Flash programming ...
Valid PAPUB key found
CMT PAPUBKEYS, RAP Certificate 101 v1 written.
Programming completed in 4 min 23.484 s
Processing file: rm346_200.21.118_prd.v01 as PPM
[BB5,XSR 1.5] size: 28.78 MB
RAP Data :
EM1 ID: 00000296
EM2 ID: 00000B22
ASIC MODE ID: 00
CMT ONENAND area [05420000-0759FFFF]
Format NAND
erased in 0.328 s
Programming completed in 2 min 1.781 s
Processing file: RM346_ENO_0741.10.N32.fpsx as CNT
[BB5,XSR 1.5] size: 1.53 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103
RAP Data :
EM1 ID: 00000296
EM2 ID: 00000B22
ASIC MODE ID: 00
APE SOSENO
erased in 0.063 s
Programming completed in 7.109 s
Processing file: leevi_erase_y_drive.fpsx as CNT
[BB5,XSR 1.5] size: 244 Bytes
Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 400C192101031105
RAP Data :
EM1 ID: 00000296
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 1.62 MB
CMT ONENAND area [0F020000-0F1BFFFF]
erased in 0.063 s
Programming completed in 0.437 s
Processing file: rm346_200.21.118.02U as CNT
[BB5,XSR 1.5] size: 7.85 MB
RAP Data :
EM1 ID: 00000296
EM2 ID: 00000B22
ASIC MODE ID: 00
Format NAND
erased in 1.406 s
Programming completed in 33.015 s
Flashing completed in 8 min 44.672 s
Phone Type: RM-346 (Nokia E71)
SW Version: V ICPR71_08w44.2 19-11-08 RM-346 (c) Nokia
Imei plain: 35682702321431-1
Product Code: 0568863
ApeCoreSw: 200.21.118
VariantId: 200.21.118200.21.118_v01
Language Pack:
- not available.
SIMLOCK_DATA corrupted!
Total time to process is 9 min 29.813 s
BR,
HAKIM
Old 09-19-2009, 10:10   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
before flash this phone already have this kind error ??
Language Pack:
- not available.
br,
Old 09-19-2009, 11:08   #6 (permalink)
Member: 12671
Thanks Meter: 3
No, the phone was working perfect hase only no EU lang.
I you can see the phone is coming from Version "Version from phone: 100.21.108" RM-493
I only flash with 200.21.110 RM-346 EU.
But now the phone only blink and say Simlock data error.
BR,
Hakim
Old 09-19-2009, 12:18   #7 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
can u tell me why u reflashed ur cnt many time
first with eno file
sc with erase as i think from this name
the last only right one
wbr
E71 RM-357 to RM-346 meisam MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-25-2010 11:24
RM-357 to RM-346 possible? meisam Nokia Base Band 5 ( BB-5 ) 2 07-26-2009 18:22
converting rm-407 to rm-346? lakshi Nokia Base Band 5 ( BB-5 ) 2 06-13-2009 19:07
NokiaE71 from RM-357 to RM-346 Roni1976 Nokia Base Band 5 ( BB-5 ) 1 08-02-2008 10:43
Page generated in 0.24385 seconds with 9 queries
