Old 11-25-2011, 09:10   #1 (permalink)
achintya's Avatar
Member: 553420
Sonork: 100.1624012
Thanks Meter: 129
flashing error with nokia x1-01 >checksum mismatch
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN:xxxxxxxx
Using device: HTI, FW ver: 00.24, SN: xxxxxxxx
Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12923(10-10-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 8804 [ST 58LR128U,128 Mbits]
Processing file: rm713_005.440
Downloading item CODE:hw_b1_rm713_r05.440.fls, num block: 3, size: 5.58 MB
Erasing area 0x00000000-0x00005FFE ...OK
Programming completed in 1.094 s
Erasing area 0x00800000-0x00BEFFFE ...OK
Programming completed in 2 min 6.141 s
Erasing area 0x00C5D000-0x00DFB6FE ...OK
Programming completed in 52.219 s
Checksum mismatch: Phone calculated 0x48F6, software calculated 0xCD0A
Processing file: rm713_005.44mg
Downloading item CUST:hw_b1_rm713_005.44mg.fls, num block: 1, size: 5.01 MB
Erasing area 0x00100000-0x0060257E ...OK
Programming completed in 2 min 40.828 s
Checksum mismatch: Phone calculated 0x30D2, software calculated 0xD828
Processing file: rm7130_nai05.44mg_nlt
Downloading item CUST:hw_b1_rm7130_nai05.44mg_nlt.fls, num block: 1, size: 1015.45 KB
Erasing area 0x00E60000-0x00F5D0BE ...OK
Programming completed in 31.922 s
Checksum mismatch: Phone calculated 0xA7E4, software calculated 0xBCDC
Total time for flashing process(boot+erase+write) was 8 min 23.672 s
plz help>>>>>>>>>>>>>>>
Old 11-25-2011, 16:49   #2 (permalink)
achintya's Avatar
Member: 553420
Sonork: 100.1624012
Thanks Meter: 129
any solution?????????????????????
Old 11-25-2011, 18:05   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
i have only one solution:
please update your mobileex:
http://forum.gsmhosting.com/vbb/f550...hread-1378774/
you are still using old buggy version.
Old 11-26-2011, 05:30   #4 (permalink)
achintya's Avatar
Member: 553420
Sonork: 100.1624012
Thanks Meter: 129
thanks for reply...i will try ur advice sir
Old 11-26-2011, 09:05   #5 (permalink)
achintya's Avatar
Member: 553420
Sonork: 100.1624012
Thanks Meter: 129
After installing new version v3.5 rev1.5>> problem is same... checksum mismatch
and phone current condition is dead and not entering in local mode(no response)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxxx
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL ...OK
Boot mode: 0xCC
Programming completed in 0.750 s
Programming completed in 1 min 30.609 s
Programming completed in 37.469 s
Programming completed in 1 min 54.984 s
Programming completed in 23.078 s
Total time for flashing process(boot+erase+write) was 6 min 38.235 s
Old 11-26-2011, 17:25   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
OK, you're on current version now. I see you still got the same exact error. You can try to tick / untick " Use Embedded SBL from MCU" on config.
If end up with the same error, final judge: bad flash chip. reheat, reball.
Page generated in 0.16902 seconds with 9 queries
