06-18-2012, 17:41 | #3 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | why theres only mcu and ppm no cnt? MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: xxxxxx Using device: HTI, FW ver: 00.50, SN: 010057F2 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012) APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 81A44CA298B3A69650624930ACAB2CDAC84DE441 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000341 PUBLIC ID: 02F0000C81914651FF6DC4AE1F6917051EBE9AA5 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 eBB5ProtocolType: OLD Storage0: 0001 0002 - 0000 0111 [AMD NA] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 Storage0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: FLASH,NAND, asic:APE Suggested algorithm: OMAP1610 GBBM-1.8.1 ALG Storage content: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Selected firmware certificate matched. Original Imei: 35709300506971 Original Product code: 0530763 Bluetooth ID: 0015A081C7B5 Last edited by manule; 06-18-2012 at 17:46. |
06-18-2012, 18:11 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. There is no CNT for N70, for MCU it's CORE file & for PPM in 2nd, no other file for flashing N70. BR, Zuber |
06-18-2012, 18:51 | #9 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. You already massed up with Flash Files seen from you above 2 Images, Go to Quick Fix tab>Tick Rap3NandErase & Click Do Selected Job will solve your Problem. BR, Zuber |
06-18-2012, 19:03 | #11 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | NOR: OK NAND: OK Flash programming ... Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 50.016 s Total time for flashing process(boot+erase+write) was 3 min 11.649 s Phone type: RM-84 (Nokia N70) SW version: V 05wk07v47 30-01-07 RM-84 (c) Nokia. Imei plain: 12345610654321-? Battery voltage: 4595 mV, current: 100 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
06-18-2012, 19:11 | #12 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | bro help here SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 357093005069715 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F |
06-18-2012, 19:20 | #13 (permalink) | |
Insane Poster Join Date: May 2012 Location: JTAG TOOLS
Member: 1755599 Status: Offline Thanks Meter: 20 | Quote:
or write full pm via SX4 your problem will be solved | |
06-18-2012, 19:38 | #14 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | pls uploade one here wrote full pm but same here Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 357093005069715 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Last edited by manule; 06-18-2012 at 19:45. |
06-18-2012, 20:12 | #15 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Check BB5 Certificate Validation, Click Recover Certificate & then Load PM Click Repair SD>Click No to Pop Up Window for RFBB & Click Write will solve you Problem. BR, Zuber |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
