Old 04-08-2010, 11:11   #1 (permalink)
Member: 496508
Thanks Meter: 59
Flashing RM-504 (5530 XM) Problem With UFS Interface
First i Check with Jaf Interface and result is
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 2090001791810052BEDB1E8526AB2553A4B294F0
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.38.1 revision: 2.0 size: 0x3B40
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
New Protocol is not supported for the current interface (POTATO BOX, FW ver: 01.B1).
And I try With UFS interface and same result here
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.)
but for jaf Interface i can solved with the last box firmware
here result
Using device: POTATO BOX, FW ver: 01.B4
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
TransmissionMode: DDR&TX2
FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,RAP
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.38.1 revision: 2.0 size: 0x70922
RAP PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
RPL saved to "C:\mobileEx\3.2\data\backup\BB5_35825303034060_BA CK.rpl"
Processing file: RM-504_20.0.080_prd.core.C00 as MCU
[BB5,XSR 1.5] size: 101.85 MB
Supported RAP Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Storing certificate ...OK
Partitioning ...OK
Erase size: 158.19 MB
CMT MuxOneNAND area [00040000-00082FFF]
CMT MuxOneNAND area [00083400-003FFFFF]
CMT MuxOneNAND area [00400000-007FFFFF]
CMT MuxOneNAND area [00800000-00D5FFFF]
CMT MuxOneNAND area [00D60000-09E5FFFF]
Format Partition ...
Flash programming ...
CMT PAPUBKEYS: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF (RAP Certificate 168 v.1) written.
Programming completed in 8 min 18.579 s
Processing file: RM-504_20.0.080_prd.rofs2.V11 as PPM
[BB5,XSR 1.5] size: 19.17 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34.00 MB
CMT MuxOneNAND area [07160000-0935FFFF]
Programming completed in 1 min 35.782 s
Processing file: RM-504_20.0.080_C01_prd.rofs3.fpsx as PPM
[BB5,XSR 1.5] size: 5.04 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 11.00 MB
CMT MuxOneNAND area [09360000-09E5FFFF]
Programming completed in 25.343 s
Processing file: RM504_20.0.080_006_000_U001.uda.fpsx as CNT
[BB5,XSR 1.5] size: 4.89 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 88.75 MB
CMT MuxOneNAND area [09E60000-0F71FFFF]
Programming completed in 25.344 s
Flashing completed in 12 min 19.843 s
Phone Type: RM-504 (Nokia 5530 XpressMusic)
SW Version: V ICPR72_09w36.5 25-09-09 RM-504 (c) Nokia
Imei plain: 35825303034060-1
Product Code: 0577064
ApeCoreSw: V 20.0.080
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358253030340601
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 12 min 33.531 s
can any one solved that ufs interface problem
br
rie2n
Old 04-08-2010, 11:34   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
how if try with original UFSHWK , are this phone working good when flashing ?
OLD JAF BOX frimware 01.B0,01.B1 and 01.B2 not supported yet for RAPU
only support with last JAF BOX frimware 01.B4.cos already have protocol to flash RAPU .
SAFE,EASY and SAFE is use USB as interface if want FLASH RAPU
br,
mxkey with ufs interface dct4 flashing problem ..the solution is here ELOY1024 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 12 03-28-2010 02:10
RM-504 5530 Flashing Errror dilip kumar j Cyclonebox 4 03-15-2010 19:47
Page generated in 0.16962 seconds with 9 queries
