08-20-2011, 21:05 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | Full flash e5 rm-634 with lasy update 3.5 rev 1.3 (ANSWERED) The state phone before flash was dead, only fibrated. MXKEY Serial: [FT SCRxxxxx] - xxxxxxx Using device: AdvanceBox Turbo Flasher Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: FTDIBUS, ver: 2.6.0.0 , NTMP ver: 2.6.2.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0EA00210D8A40344E0D7BA3DFBD3C9BE1922D87C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 9.50.0 revision: 3.0 size: 0x7F29B Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C Processing MCU file: rm634_071.003_prd.core.fpsx [BB5,XSR 1.6] size: 102.95 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 227.31 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: CCD9F805 [RAP Certificate v1 238] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 2 min 7.984 s Processing PPM file: rm634_071.003_42.01_NA_prd.rofs2.fpsx [BB5,XSR 1.6] size: 54.94 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 71.50 MB CMT FLASH,MuxOneNAND area [08980000-0D0FFFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 1 min 5.000 s Processing PPM file: rm632_071.003_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.43 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 22.50 MB CMT FLASH,MuxOneNAND area [0D100000-0E77FFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 11.000 s Processing CNT file: rm632_071.003_U005_01.000_prd.uda.fpsx [BB5,XSR 1.6] size: 20.76 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 265.75 MB CMT FLASH,MuxOneNAND area [0E780000-1F13FFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... Prog.status for Asic CMT ... NAND: Success Programming completed in 29.547 s Total time for flashing process(boot+erase+write) was 4 min 12.906 s Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia Imei plain: 35339904167735-1 Product code: 0595464 Battery voltage: 4798 mV, current: 189 mA ApeCoreSw: 071.003 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353399041677351 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.672 s |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
