01-17-2010, 17:06 | #1 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | ::good newz 1202/1203 rpl done:: checked by me 100000% ok Here is log. Code: ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00B6AF25:DA3BDA66 ASIC type: 11 UEM Imei: 35801603370343 Connecting to server ...OK, Login ... Hello C0805733, you have 910 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35801603370343.RPL" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00B6AF25:DA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35801603370343-4 Product Code: 0562271 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35801603370343 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.CORRUPTED (00) 2.CORRUPTED (00) 3.CORRUPTED (00) 4.CORRUPTED (00) 5.CORRUPTED (00) BLOCK 7: 1.CORRUPTED (00) 2.CORRUPTED (00) 3.CORRUPTED (00) 4.CORRUPTED (00) 5.CORRUPTED (0 Best regard MX-key team ..::S@JID::.. |
The Following 2 Users Say Thank You to sajidashraf For This Useful Post: |
New Nokia Care Suite For 1202/1203 Flashing | jafsupport.com | J.A.F. By Jafsupport.com | 3 | 03-02-2009 21:44 |
I Have MobilMb for 1202-1203-1207 | sonojee | Nokia Multimedia | 5 | 03-01-2009 14:19 |
Mobimb 1202 1203 By JafarPsx | jafarpsx | Nokia Multimedia | 6 | 02-16-2009 11:29 |
