Old 07-06-2012, 09:27   #1 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
GPG UFC 2012 need assistence to use mxbox
i have problems when i connect this to my mxbox
i also ask for the power adapter for the GPG UFC what voltage that it use?
i need to unlock with my N73-1
Old 07-06-2012, 09:35   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. UFC needs 5 Volts, so It uses 5 Volts as i think.
BR,
Zuber
Old 07-07-2012, 13:20   #3 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
You can use nokia charger for this.
Old 07-08-2012, 01:09   #4 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
ok i try it with the usb cable that for charger only and i have question what this show on the GPG UFC 2012
3.3K
6.1K
7.5K
10K
15K
Old 07-08-2012, 03:17   #5 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
i have try to unlock my N73-1 please let me know what correct to connect the GND & BSI to phone and also where to i connect the pin to the phone board
Old 07-08-2012, 03:26   #6 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
i need help here?
after update
» Begin transaction ...
Initializing HTI ...
HTI initialized.
Boot version: 01.09
Serial: 0xxxxxxxx
Receive firmware from server ...
SERVER->MXKEY - BLADE Z at upd, agent version 1.2 revision 0.3
Firmware version on server: 00.50
changes:
added: boot mode switch function
improved: serial and flash bus communication routine
added: dct4 product data calc algorithm
added: broadcom sec.repair algorithm
minor bug fixed.
Received buff checksum verified OK.
Waiting for HTI in boot mode ...
Reinitializing HTI ...
Updating HTI firmware, please WAIT ...
HTI firmware update OK.
» End transaction (status: 0, Successfull)
Waiting HTI in application mode ...Done.
Old 07-08-2012, 03:33   #7 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
need help here
Old 07-08-2012, 03:36   #8 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
help with this Error ask to reset.
thanks
Old 07-08-2012, 04:50   #9 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
Using device: HTI PLUS Flasher Interface
Connection status: UHCI:HUB:USB 2.00 Full-speed
WARNING: Device drivers might not work properly !
[err0] required OHCI(1.1)/EHCI(2.0)/xHCI(3.0) controller, connect your device to a different USB port !
Interface: MXBOX/HTI (Powered by MXKEY)
OTP ID: 180D1313620B4E533A8E564B020000F5
Boot ver: 01.09, Box SN: 0xxxxxxx
FW version: 00.50
HTI PLUS Flasher Interface ready.
i have change to different usb port but error still appears
Old 07-08-2012, 05:54   #10 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
Please help with this error try to unlock my N73-1
Counter: 0/3, 0/10
CONFIG_DATA: 5050300014981890
PROFILE_BITS: 0000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ]
BLOCK2: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ]
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: Cxxxxxxx
Using device: HTI, FW ver: 00.50, SN: 0xxxxxxx
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
Phone type: RM-133 (Nokia N73)
SW version: V 05wk47v34.1 05-10-06 RM-133 (c) Nokia.
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 9CDFD427F6E13830EC3D7B8B897AC4437514E7CE
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B21
PUBLIC ID: 0740010ADBA401542D1AE298C2F0C10BA4486CF7
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
ERROR: Configuration request failed !
Unknown ID !
Error getting boot info !
ERROR: bootstrap failed!
Reading Simlock info ...
Imei net: 353xxxxxxxxxxxx
Version: SIMLOCK SERVER VERSION 63
Provider: Vodafone Network Pty. Ltd. , Country: Australia
Counter: 0/3, 0/10
Old 07-08-2012, 06:43   #11 (permalink)
Member: 762819
Thanks Meter: 232
Dear it is very easy, just follow the isntructions of unlock. goto IMEI & Security and Simlock and update Simlock. all will be fine.
Old 07-08-2012, 06:44   #12 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
i download the lastest version 4.850.43.0.1 to flash it so it may unlock via simlock?
thanks
Old 07-08-2012, 06:47   #13 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
the above log where the same way that i try to unlock it but you check the log it give error on it
Unknown ID !
Old 07-08-2012, 07:33   #14 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
i have an error and need to know what that error
//connected HTI PLUS Flasher Interface
Boot ver: 01.09, Box SN: xxxxxxxxxx
FW version: 00.50
//Bus Check
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
ERROR: Packet Error(0xAA), code 0x4A000001
Old 07-08-2012, 21:15   #15 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
Phone success fully unlock this morning
Imei plain: 35xxxxxxxxxxxxxxxx
Product code: 0539397
Battery voltage: 4657 mV, current: 36 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35xxxxxxxxxxxxxx
Counter: 0/3, 0/10
Imei net: 35xxxxxxxxxxxxxxx
Counter: 0/3, 0/10
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0873A97
Using device: HTI, FW ver: 00.50, SN: 010089EB
Using cached productData.
PRIVATE ID: E640D20376439F86F91419D4FFDC088B6CBB620A
Updating SIMLOCK ...OK
Imei net: 35xxxxxxxxxxxxxxxxx
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.35486 seconds with 10 queries
