Old 11-04-2009, 16:03   #1 (permalink)
Member: 162478
Thanks Meter: 13
hai heplmee mx key
my mx key is not working
i flashed 2 or 3 set. aftr for a while i have woked for jaf .then i conected mx key again but it say No Security Dongle detected what will be do , i rstart the sistem, re install the software, i chang the sistem and install but nothing to happen hell pe mee mebers thanku
Old 11-04-2009, 16:17   #2 (permalink)
Member: 162478
Thanks Meter: 13
solved
changed the card reader and solved the problem
Old 11-04-2009, 16:21   #3 (permalink)
JHUNpanabO's Avatar
Member: 265729
Thanks Meter: 144
removed card & clean it,
then insert again, also try other usb port
if the same, between reader or card are
damage....
The Following User Says Thank You to JHUNpanabO For This Useful Post:
Old 11-04-2009, 16:31   #4 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 147
another practical reason, security card me be inserted deep in the reader socket . take it out and insert it carefully checking it may be in the right position that is not more inserted in nor pulled out. at the proper place. sorry for my bad english.
The Following User Says Thank You to rajufzr For This Useful Post:
Old 11-05-2009, 05:18   #5 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
take out your sec card from the dongle clean with tissue paper and also clean connecting pins on the dongle then try
Asghar
The Following User Says Thank You to mobilecitycbk For This Useful Post:
Old 11-05-2009, 05:25   #6 (permalink)
Member: 162478
Thanks Meter: 13
thanku member for u r replay, my problem is solwed, i changed the reder. thanku.
Old 11-05-2009, 05:28   #7 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
dongle problem check card on it
[Update] PhoneIdentity For Mx-Key [Init File For MX-KEY] jubjang MXKEY Nokia Flasher and Unlocker (by Alim Hape) 31 01-24-2011 17:43
how to buy mx key orginal in india please replay mx key teem bijugreat MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 04-27-2010 22:08
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 10:07
plz halp mx key team 6220c not unlok for mx key parmodparmod MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 02-16-2010 11:22
Page generated in 0.15750 seconds with 9 queries
