04-27-2012, 12:45 | #1 (permalink) |
Product Supporter Join Date: Mar 2011 Location: ..::INDIA::.. Andhra Pradesh Age: 41
Member: 1528548 Status: Offline Sonork: 100.1613286(Offline) Thanks Meter: 2,243 | Hello mx box team see this error (ANSWERED) After flash i press Reset All button Show this error pls explain why comes this error problem in only 3110 c mobiles another mobiles not show this error i am tested maximum 6 mobiles totaly same error mobile working fine but show this error i tried 3.5_1.9 And 3.5_2.0 |
04-27-2012, 14:13 | #3 (permalink) |
Freak Poster Join Date: Jul 2007 Location: deveselu
Member: 543935 Status: Offline Thanks Meter: 59 | [email protected]. not work, @sony try to select full factory, and press reset selected, and then reset all. |
04-27-2012, 14:42 | #4 (permalink) |
Freak Poster Join Date: Jun 2006 Location: PAKISTAN
Member: 290794 Status: Offline Thanks Meter: 31 | just change the mobile mode from local to test mode and it will work fine BR, RANA_TANVEER |
The Following User Says Thank You to rana_jee For This Useful Post: |
04-27-2012, 19:59 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
br, zuberchowdhry | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
04-28-2012, 09:26 | #8 (permalink) |
Member: 290794 Status: Offline Thanks Meter: 31 | your phone is on local mode so i dont think its cable problem it will be solved just if phone is in test mode and plz give the result if it is solved how you solved it so it may be helpful BR, RANA_TANVEER |
04-28-2012, 09:32 | #9 (permalink) | |
br, | |
04-28-2012, 09:43 | #10 (permalink) |
Member: 290794 Status: Offline Thanks Meter: 31 | thanks for the advice brother you are right but i faced this problem many times with mx-key and hwk also but when i changed the mode manually it worked for me so i told it here i just wanted to help and i want the result also so if next time i get this error i can solve it by this result BR, RANA_TANVEER |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
