02-04-2011, 15:56 | #1 (permalink) |
Insane Poster Join Date: Feb 2008 Location: algeria Age: 49
Member: 709218 Status: Offline Thanks Meter: 2 | help 3110 security test failed Product: V 07.21 05-11-08 RM-237 (c) Nokia. Using cached productData[1AB0020217E47D5666A818C7009F3A33FAF00633] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 5.594 s |
02-04-2011, 15:58 | #2 (permalink) |
Member: 709218 Status: Offline Thanks Meter: 2 | please help me Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35193903576991-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351939035769912 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-04-2011, 15:59 | #3 (permalink) | |
Banned Join Date: Dec 2009 Location: Bhutan
Member: 1178270 Status: Offline Sonork: 007 Thanks Meter: 18 | Quote:
Try this out Bro SIMLOCK valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! how to solve this problem ? 1. First of all u need good pm with SX4 ( do SX4/super SX4 after that pm1 and pm309 ) 2. if not solved than check CCC and HWC certificates How to repair CCC and HWC certificates ? backup RPL than open it in notepad there u will see NPC data after that CCC data and HWC data just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model ) http://rapidshare.com/files/34542441...e_by_MxKey.zip Free File Hosting Made Simple - MediaFire 4shared.com - free file sharing and storage MEGAUPLOAD - The leading online storage and file delivery service 3. if still not solved than recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON ) 4. if still same than Repair SL REPAIR SD SUPER SD AUTH write PM1 and PM309 5. if still same than make RPL backup full erase than flash than rpl than Repair SL than SD repair than super AUTH than PM 6. after all these steps if still same than i am here for don't worry __________________________________________________ ____________ FOR SL3 LIKE 5130 , 6700c ,................. 1. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! Block1 : open Block 2 pen Block 3 : open in this case just do SX4 and than pm1 and pm309 2. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SL data corrupted in this case u need Nokia RPL ( not supported by MXkey yet ) __________________________________________________ _______________________ PM FILES OF BB5 : just download them from this link and enjoy MEGAUPLOAD - The leading online storage and file delivery service | |
The Following User Says Thank You to mintubtn For This Useful Post: |
02-04-2011, 16:00 | #4 (permalink) |
Member: 1178270 Status: Offline Sonork: 007 Thanks Meter: 18 | Try This out SIMLOCK valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! how to solve this problem ? 1. First of all u need good pm with SX4 ( do SX4/super SX4 after that pm1 and pm309 ) 2. if not solved than check CCC and HWC certificates How to repair CCC and HWC certificates ? backup RPL than open it in notepad there u will see NPC data after that CCC data and HWC data just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model ) http://rapidshare.com/files/34542441...e_by_MxKey.zip Free File Hosting Made Simple - MediaFire 4shared.com - free file sharing and storage MEGAUPLOAD - The leading online storage and file delivery service 3. if still not solved than recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON ) 4. if still same than Repair SL REPAIR SD SUPER SD AUTH write PM1 and PM309 5. if still same than make RPL backup full erase than flash than rpl than Repair SL than SD repair than super AUTH than PM 6. after all these steps if still same than i am here for don't worry __________________________________________________ ____________ FOR SL3 LIKE 5130 , 6700c ,................. 1. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! Block1 : open Block 2 pen Block 3 : open in this case just do SX4 and than pm1 and pm309 2. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SL data corrupted in this case u need Nokia RPL ( not supported by MXkey yet ) __________________________________________________ _______________________ PM FILES OF BB5 : just download them from this link and enjoy MEGAUPLOAD - The leading online storage and file delivery service |
02-04-2011, 18:47 | #8 (permalink) | |
Freak Poster Join Date: Dec 2010 Location: sadulshahar rajsthan india
Member: 1462478 Status: Offline Thanks Meter: 32 | Quote: | |
The Following User Says Thank You to rupesh22 For This Useful Post: |
02-04-2011, 19:02 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2009 Location: CH,BD,HK
Member: 1179761 Status: Offline Sonork: 100.1602000 Thanks Meter: 1,834 | try browse full pm,then go- ppm auth or contact me |
The Following User Says Thank You to nerobdms™ For This Useful Post: |
02-06-2011, 15:09 | #12 (permalink) |
Member: 709218 Status: Offline Thanks Meter: 2 | thank you for reply but steel same problem how i can solve this problem please help Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.5 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 41.100.174.230 SUPERDONGLE authorized ! SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.5 Updating RFBB data ... Writing section 1... Writing section 309... Error 0 Done. Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35193903576991-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351939035769912 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
